Go Back   Les Paul Forums > Music Gear > Tonefreaks
Like Tree1Likes
  • 1 Post By Carl17
Unread 07-27-2012, 01:48 PM   #1 (permalink)
Help: 50's wiring Epi tribute - Series/Parallel
Can anyone tell me what I need to do (if it's possible) to convert this to 50's wiring? I want to keep the push/pull pots and series/parallel wiring.
Sorry for the poor diagram, but it's clearer than photos of the cavity.
Carl17 is offline   Reply With Quote
Unread 07-27-2012, 11:20 PM   #2 (permalink)
TONE FREAK
jonesy's Avatar
Re: Help: 50's wiring Epi tribute - Series/Parallel
If I am reading your diagram correctly you could unsolder the cap leads from the back of the tone pots and connect them to the center lug of the volume pots (same as the switch lead) and you should have 50's wiring.
"Pro Guitar Wiring Upgrades Built & Designed by a Guitar Player with over 33 years of Experience"
Jonesyblues.com for Professional Guitar Wiring Upgrades & DIY Kits
Questions? Email to: jonesyblues@yahoo.com or Call 1- 574-249-8816
Aged Parts, Vintage Tone Caps & Wire in my ebay store
Jonesyblues Youtube channel
Jimmy Page Wiring.com
GOD ROCKS!
Unread 07-28-2012, 05:22 AM   #3 (permalink)
That's easier than I thought it would be. I'll give it a shot later and let you know what happens, thanks.
jonesy likes this.
Unread 07-28-2012, 07:23 AM   #4 (permalink)
TONE FREAK
jonesy's Avatar
You're welcome. Yeah it's a pretty simple mod. Have fun and I hope it works out for you.
GOD ROCKS!
Unread 08-19-2012, 03:48 PM   #5 (permalink)
Just tried that and now my tone controls seem to do nothing. But when I turn the volume control down I can hear the tone control making a difference but it's almost like it's working in reverse. When I turn the tone down the sound gets fuller and when I turn it up it gets a lot cleaner, more quiet, and just doesn't sound good.
Any suggestions?
The volume control doesn't seem to be having much of an effect either. When I turn it up or down, the difference isn't that much. I'm pretty sure it wasn't like this before.
I was thinking of just buying 4 CTS pots and going normal 50s style if this doesn't work out because I never really use the push/pulls anyway but it would still be nice to have it there.
Unread 08-19-2012, 04:04 PM   #6 (permalink)
TONE FREAK
jonesy's Avatar
Any suggestions?
Well it's hard to tell what's going on without actually seeing clear pics of the wiring controls. It could be a grounding issue, if you want to post some pics I would be glad to look at them and see if I can spot what the trouble is.
GOD ROCKS!
Unread 08-19-2012, 04:09 PM   #7 (permalink)
Ok thanks, going away tomorrow so I'll post the pics next week.
Also, the long blue wire from the pickups that goes around the tone pot (in the above diagram) is actually the black wire (on pup) soldered to the back of the pot, then there's another small black wire coming from the back of the pot, to the lug on the push/pull. When I first saw it, I though it was one long wire going around the pot.
The bare wire is also soldered to the back of pot.
Unread 08-19-2012, 04:38 PM   #8 (permalink)
I know you have a lot more knowledge on this than me, but should the cap not be soldered to the outer lug of the tone pot too? This seems to be how it's usually done with 50's wiring.
Right now each end of the cap is on the middle lug of tone and vol pots.
Unread 08-19-2012, 06:05 PM   #9 (permalink)
TONE FREAK
jonesy's Avatar
The cap can be soldered to either lug on the tone pot and it will work and sound the same, that is not a factor for 50's wiring. The lug the cap goes to on the volume is what changes it from modern to 50's because of where it puts the cap in the signal chain.
GOD ROCKS!
Tags
50s wiring, epiphone tribute
