Go Back   Les Paul Forums > Music Gear > Tonefreaks
Unread 07-17-2012, 05:47 AM   #1 (permalink)
Bigshot ABY Bypass
Hello All
Hope someone can help on the following, when i do larger gigs i rig 2 Fender Blues Jnr's together using a Bigshot ABY Bypass, when i play my Fender Tele through it, it sounds Great, however when i use my Gibson Les Paul it dosent sound good, i have tried all kinds of settings on my Amps but it makes no difference, do i need to upgrade to more expensive ABY switch?.
Does the Bypass not like Humbucker Pickups?.
Thanks
Allan
AllanDR is offline   Reply With Quote
Unread 07-17-2012, 11:05 AM   #2 (permalink)
Sinster's Avatar
Re: Bigshot ABY Bypass
Originally Posted by AllanDR View Post
Hello All
Thanks
Allan
If you read your manual it states in there that the tone will change going through channel "B".
GIBSON LES PAUL, THE OTHER CRACK!!!
BFG Owner Group
Sinster is online now   Reply With Quote
Unread 07-17-2012, 12:33 PM   #3 (permalink)
Thanks for your reply, however the tone dosent change on the Telecaster.
Regards
Allan
Unread 07-17-2012, 06:42 PM   #4 (permalink)
SuiteAmpCo's Avatar
What do you mean by "it doesn't sound good"? Are you getting noise? The output drop? Does the eq seems off? Can't help you from the info provided so far.
]ack be nimble, Jack be quick...Big Effing Deal. Can he ROCK???
http://thesmokinguitar.com/
SuiteAmpCo is offline   Reply With Quote
Unread 07-18-2012, 10:47 AM   #5 (permalink)
The Lp sounds dull and lifeless through the Bigshot, yet the tele sonds the same as if i was one a single amp, hope this helps.
Thanks
Allan
