Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 09-04-2008, 01:05 AM   #1 (permalink)
WB pickup 4 wire color code
I just got a set of WB Firewaters and I had the bridge pickup setup for 4 wire wiring. Can someone tell me if the color codes match Dimarzio, Duncan or something else?
Can't wait to try them out.
lhrocker is offline   Reply With Quote
Old 09-04-2008, 01:12 AM   #2 (permalink)
Re: WB pickup 4 wire color code
I just called Will and Laura answered. She said it's standard Gibson color coded.
Nar Dog is offline   Reply With Quote
Old 09-04-2008, 01:21 AM   #3 (permalink)
TheMrsWB's Avatar
Hello! The 4 wire is like Gibsons.
Red = Hot
Black & Loose Wire = Ground
Green & White Together for Standard Humbucker or they can be used as your coil cuts.
Laura
TheMrsWB is offline   Reply With Quote
Old 09-04-2008, 01:31 AM   #4 (permalink)
Thanx Nardog and Laura. Please let Will know that I can't wait to install them into my G0!!! Mandatory pictures will post when I get them installed!!!!
Why would Gibson wire the pickup leads & switch to the same lug ? JohnK24 Tonefreaks 2 09-01-2008 06:02 PM
Pickup wire length (New pups, is it long enough?) ARch Gibson Les Pauls 7 07-20-2008 12:00 AM
what is this code ? loaded six string The Backstage 13 06-30-2008 08:20 PM
? about CTS pot code Csharp The Custom Shop 8 03-16-2008 08:55 PM
Pickup Color Question matt1987 Epiphone Les Pauls 6 12-31-2007 03:40 AM
Powered by vBulletin® Version 3.8.4
