#1 (permalink) |
Brightness on split-coil setup
I have a split coil setup. When I switch over to single-coil, I tend to roll my tone down to take off some of the extra brightness (at least it seems bright to me, I assumed it was my 500k pots). Are there any thoughts on a good wiring setup to help me make the best of both my push and pull?
(I'm thinking in terms of caps, wiring schemes e.g., more of a 50's wiring vs modern, etc.) |
#2 (permalink) |
Disciple-of-RobotOverlord
![]() Join Date: Apr 2008
Re: Brightness on split-coil setup
maybe a higher value cap so more of the highs are rolled off but thats about all i can think of
2005 Ibanez H.R. Giger Iceman |
#3 (permalink) |
If you have a 4 conductor pickup, try wiring it to use the opposite coil when running in split mode. For example, I just put in a new pup in the bridge, but when I wired it to split the coil as per the winder's instructions, it sounded waaay too thin. It was because the recommended wiring scheme used the back coil of the humbucker (the coil closest to the bridge) when in split coil mode. I rewired it to use the front coil, which is a bit further from the bridge, and it sounded worlds better. This can be important if the coils inside the humbucker are unevenly wound, which some winders do to get a different or vintage tone.
Just a thought.
'79 Cherry Sunburst Custom '01 Dickey Betts Goldie - 80 of 114 '00 Chandler Lectraslide '70 Marshall 1959 Super Lead '00 Marshall 1987x 4x12 - JBL D120s '64 Vibroverb - JBL D130F '66 Super Reverb - CTS Alnico '75 Peavey Deuce (120W of pain - great for melting stubborn ear wax) |
#4 (permalink) |
Also, try the two coils wired in parallel instead of a split. It gives a brighter sound than a standard HB, but not quite as thin as a split. Balances better with another HB as well.
Green: the new Red
#5 (permalink) |
You can add a cap to the push pull switch, so that it gets into the circuit when you split. I gotta take a look at some switches to check if this would be possible though. This would compensate for the brightness, but wouldn't be adjustable...
Cheers André |
| Question about the Split-Diamond Inlay | Stealth | Vintage Les Pauls | 7 | 08-05-2008 08:04 PM |
| difference in sound of a split humbucker and a true single coil? | EEF13 | Pickups | 6 | 07-15-2008 10:58 PM |
| Anybody split a P100 before? | kspeed | Pickups | 6 | 07-12-2008 10:00 AM |
| Coil Split Help | noslen1968 | The Custom Shop | 3 | 06-27-2008 06:22 AM |
| Coil splitting a LP | Rock Johnson | Tonefreaks | 19 | 06-22-2007 03:17 PM |
