Go Back   Les Paul Forums > Music Gear > Tonefreaks
Unread 11-26-2010, 10:48 AM   #1 (permalink)
pup probem
how can i tell if my pick-up is goosed or if it's the selector switch.
i fitted a Dimarzio at the bridge a few years back and it suddenly stopped working, ie, no sound.....
i have a five way selector, four work fine it's when i switch to the bridge i get nothing.....the funny thing is though when i tap it with a screwdriver or something i can hear it fine through the amp,
help please...
with friends like this who needs enemas..
stevie777 is offline   Reply With Quote
Unread 11-26-2010, 11:35 AM   #2 (permalink)
Mac Guitars
lukemacauley's Avatar
Re: pup probem
Check your solder joints, Stevie. It will most likely be a cold or broken solder joint on the switch. If it's not a Switchcraft/CRL/Oak Grigsby switch then it might be faulty.
I very much doubt the pickup has blown or anything like that.
Mac Guitars - Custom Wiring & Electronic Upgrades.
Sign up to the mailing list for an update on new products as they become available.
My eBay store: drumbrae4.
10% Sale—Mac Guitars—Guitar Electronics and Celluloid Nitrate Inlays.
lukemacauley is offline   Reply With Quote
Unread 11-27-2010, 03:15 AM   #3 (permalink)
Re: pup probem
cheers luke, might get it into you at some point get some new pots and caps fitted. old guitar, but found a new lease of life with it of late....
i'll pm you with the details...
pssst....not even playing my LP's at the mo
Unread 11-27-2010, 12:22 PM   #4 (permalink)
TeleDog's Avatar
Re: pup probem
Easiest way to check a pup, if you don't have a multimeter, is to hook it up to a jack, plug it in and then tap on the pole pieces with a screwdriver or some other metal object, you'll hear it through the amp if you're pickup works.
And Switchcraft switches break, I just replaced one.
Some member comes here asking for help, a simple question, and this guy jumps in for the sale. Amazing.
“Teledog. Telecasterus Fanaticus Dogius".
Got a Mac or iPod? Join our Apple Dogs group!
TeleDog is offline   Reply With Quote
Unread 12-03-2010, 06:57 AM   #5 (permalink)
Re: pup probem
when i run a screw driver over the pole pieces i can hear it through the amp clear as day, the pup appears to be working fine, but i'm still not getting any sound when the switch is set to that pick-up.....strange one
