#1 (permalink) |
Pots flush to the body Yes strange
Is it possible to have the pots flush to the body.
I don't want the knobs (dont ask) I want to have the shaft of the pot all the way in the guitar. No knobs but I want access to them so I'm not going to pull the pots out completly |
#3 (permalink) |
Re: Pots flush to the body Yes strange
I do wonder why you'd want to do this. Here are two suggestions if you want to go all radical: No pots at all. Wire everything straight using the toggle switch as a neck/off/bridge selector. Drill the cavity plate and run them through the back.
Why in the world would you not want knobs on your guitar?
http://soundcloud.com/torren61/prs-santana-se-demo "There must exist certain words in certain specific order that would explain all of this. I just can’t ever seem to find them." Walter White
#4 (permalink) |
Tim Mason
![]() Join Date: Jan 2010
Id cut a piece of wood to fit snug in the cavity, so it wont rattle in there. Drill pot holes in you template to a size just shy of the thread diameter so you can screw the pots into your wooden cavity template followed by a small drop of glue to hold them still, place the template/pots in the cavity, your pots wont come through and should be nice and firm. Am i making sense?
Quote: Roman Rist on "natural highs" whilst playing It's not just endorphins you feel... No, you are connecting with the spiritual world.............you're just not sure exactly what it is.... But you are in the spirit world, that's what Hendrix was trying to tell us. |
#5 (permalink) | |
I was hoping to find something that would extend the threaded part of the pot like a threaded tube that would screw onto the pot ending at top of turning part of the pot. It would have a enough room for a washer and the nut reason for this right lefty plus with split shaft could use the pick to turn the shafts and dial in what I want and its locked... this is not for a live guitar but a guitar only for home and studio |
#6 (permalink) |
Tim Mason
Mmm, i see, id prob just write the settings in a book, bourns also make a low torque pot that is alot stiffer to turn if that helps, not a bad taper on them either.
But the plastic tubing sounds like a quick, easy solution. Screw some onto the pot shaft and bingo. Still i recommend your own book of tone and knobs on the pots.
