#1 (permalink) |
Cavity layout?
Hello everyone..
Okay, like many of you, I have been in my guitars cavity more than can be counted on my hands, and I have just done it again.. Soldering wires, changing pots etc.. Now, I have come to a point where I would really like to "clean" up the mess I have done, and was thinking about a good way to do this, and this is where I hope some of you guys can point me in the right direction.. I want to completely remove everything and the resolder everything and make it super neat and super sexy, but what I was thinking was to solder (almost) everything *before* putting it in the cavity.. So do any of you have, or can point me to a cavity layout.. A layout of the cavity where i can see exacly how big it is, where the holes are etc.. I want to use this to make a little wooden/plastic/whatever plate to put all my pots into and solder everything on, and after that just take all 4 pots from the plate, and just neatly fit it inside the cavity.. It's a gibson les paul 1958 reissue from 2008, but i guess most les paul cavities are the same? Any help would be appreciated.. Thanks guys, David |
#2 (permalink) |
Re: Cavity layout?
Yes, it is much easier and neater to work outside.
I just make them as requred. Pull the knobs of your guitar. Get a piece of cardboard. Impress it onto the pots. Remove and make holes. Mount the pots to cardboard, or transpose hole markings to a pice of craftwood or whatever. |
#3 (permalink) |
Re: Cavity layout?
yep No Static is right... working in the hole can be a bitch lol. cardboard works great.
2007 Gibson Les Paul R8 "Jamie Leigh" OTPG'd 2001 Gibson Les Paul R6 "Aimi" '53 Soapbars 2007 PRS Hollowbody Spruce " Clara" Skatterbrane'd 2001 Fender AmStd Telecaster "Sharon" Lollar'd 1960's Gibson J50 "Imogene" Phaez 15 Watt 6v6 "Rising Sun" all pots, caps, and harnesses by Jonesy@ tonemojo
#4 (permalink) |
Re: Cavity layout?
cardboard.. of course..
for some reason I was thinking about a wooden plate, but a cardboard cutout would be just as good.. one more thing: are wires with one or 5 leads best to use, and is it possible to solder some.. hmm.. what are they called in english? shoes? It's a sort of connecter that you solder on to the wires, which fits on the pots legs, so you dont have to solder the wire onto the pots but can just plug them on instead.. (does it make sense?) EDIT: sort of like these ![]() Cheers.. -David Last edited by -Zion-; 11-13-2010 at 07:34 AM. |
#5 (permalink) |
Re: Cavity layout?
one or five wire leads- youre stuck with what the p/up is equipped with unless you fancy opening the p/up and modifying it.
Using connectors- dont see why not, it might require some messing about to get earths on the back of the pots. It also can get a bit tight in there and the connectors will add bulk. If ease of removal or change over is the goal, it be tempted to solder connections to the posts as per normal and fit male/female connectors to the wires from pots anmd from pickups and switch. |
#6 (permalink) |
![]() Join Date: Jan 2008
Re: Cavity layout?
Connectors are fine if you are constantly switching pickups, different wiring, etc., but can wiggle loose or be susceptible to 'cold' solder joints. It's best just to solder directly to your pots.
