Go Back   My Les Paul Forums > Music Gear > Tonefreaks
Old 06-03-2008, 10:40 PM   #1 (permalink)
Mercutio's Avatar
Send a message via AIM to Mercutio
Need some effects chain/loop help
Howdy!
Ok gang, i got a bit of a dilemma here. Basically, here's my rig: Gibby LP Custom in my SKB pedal board which is: Crybaby 535Q, Turbo Tube Screamer, Boss Metalizer, Boss EQ, Ernie Ball volume, Boss tuner; then from the board, directly into the input on the amp, a Mesa Boogie F50 combo, which has its own footswitch for clean/gain channels.
The problem is that I have the Tube Screamer and EQ in the line as boosts for solos. However, when I am using the amp distortion channel, the EQ and tube screamer have little to no effect at boosting the volume. They add a touch of gain, but nothing else. On the clean channel, they will boost the volume as much as I want. But when switched to the Mesa's distortion channel, i get nothing.
Now, if I run these effects through the amp's effects loop, I can get the desired effect, but it is a parallel effects loop and doesnt sound as full (only 90% cause thats as high as the effects loop mix goes). Plus, it makes my wah sound like crap cause it mixes AFTER the distortion. So that's kind of a no-go.
Does anyone have any idea why the EQ/Tube screamer will boost on the clean channel and not the distortion when directly in line? I'm at a loss as to figure out why. I tried switching the pedals around, removing some, etc. Nothing works. The only solution I see to get the sound i want is to run half the pedal board through the effects loop and the other half directly in line. I'd rather not do that cause it would be a cable nightmare, but I really dont see any other way unless someone can tell me how to get the boost to work on the distortion channel.
Any thoughts? Thanks in advance...
2007 Gibson Les Paul Custom - Alpine White
2000 Gibson Les Paul Classic w/Seymour Duncan Alnico II's - Honey Burst
2004 Gibson SG Standard - Ebony
2005 Gibson Songwriter Deluxe - Natural
1996 Fender American Standard Telecaster - Surf Green
Live Amp: Marshall JVM 210H/JCM 2000 DSL 50 and 1960A Lead Cab
Home: Mesa/Boogie F50 1x12 combo
Mercutio is offline   Reply With Quote
Old 06-04-2008, 06:38 AM   #2 (permalink)
toka_ares's Avatar
Send a message via AIM to toka_ares
Re: Need some effects chain/loop help
not sure whats wrong but the same thing happened when i plugged my PODxt into the front of my marshall, i just use the effects loops religiously now. good luck!
toka_ares is offline   Reply With Quote
Old 06-04-2008, 01:57 PM   #3 (permalink)
it is because the preamp is has no more room left to go when you are on the distortion channel and thus you only get more distortion. it was already clipping to begin with.
on the clean channel you have a lot more headroom.
kissfanps is offline   Reply With Quote
Old 06-05-2008, 05:16 AM   #4 (permalink)
toka_ares's Avatar
i can see clearly now the rain isss gonnneeeee
Old 06-05-2008, 08:00 AM   #5 (permalink)
Mercutio's Avatar
i can accept that, but why does it work on the effects loop then? is that because it probably routs in AFTER the preamp?
Old 06-05-2008, 02:10 PM   #6 (permalink)
exactly! you are driving the power amp instead of the preamp. be careful not to boost TOO much or things can be damaged. that is why the new Marshall Vintage Modern has LED limiters in the FX loop.
Old 06-05-2008, 02:10 PM   #7 (permalink)
JW123's Avatar
If your amp switch has a effects switch. You might place the EQ in the loop and kick it in with the switch on your amp board.
I have a tube screamer on my pedal board and it really doesnt raise the volume much on my rectifier head. If you can lower the gain some on your amp you may see some rise in volume when you kick in the Tube Screamer. I also have a Rocktron Black Jack booster/distortion pedal and it will raise the volume some, but its still not enough to be called a lead boost.
JW123 is offline   Reply With Quote
Old 06-05-2008, 02:19 PM   #8 (permalink)
that reminds me of a cool technique
My Marshall TSL has a parallel FX loop with an adjustable mix.. If you pop a cable into the return (with no connection on the other end) of the loop it breaks the normal to engage the loop. Keep in mind that there is no signal returning. Adjust the master to your "lead" level and FX mix to your rythem level. Pretty much because it is a wet/dry mix you will only just decrease the level of your dry because there is no wet to increase. So with the FX loop on you have your rythem level and the button to turn it off for leads. I think that is the coolest thing about the TSL although you cant put any effects in the loop, but IMO effects dont belong in a loop.
Old 06-08-2008, 04:37 PM   #9 (permalink)
Mercutio's Avatar
thanks guys, i appreciate the help
Old 06-09-2008, 09:41 AM   #10 (permalink)
hbucker's Avatar
FWIW I've never had any luck boosting solos with a Tubescreamer in front of my amp. As was said earlier, it just creates more overdrive, not volume. And overdrive in the loop usually sounds bad, period.
Are you saying that the T.S. and the E.Q. are all in the same pedal? If so, then I'd say that's your problem. I use a Boss GE-7 eq in my loop to boost solos with PERFECT results. I don't even boost the volume much. I slightly cue up a couple of the middle frequencies and raise the volume slightly and BAM! My solos pop out to the front and everyone hears me loud and clear.
Honestly, I can't think of a more efficient and accurate way to boost solos. There are others but this is the one that I hang my hat on because it's so easy to control and sounds great.
hbucker is offline   Reply With Quote
How do You Run Your Signal Chain ??? BOBBO Pedals 13 03-04-2009 07:04 PM
Noise in the pedal chain Volusia Pedals 17 05-19-2008 11:32 PM
Loop or Not. ozone Pedals 1 04-28-2008 01:54 PM
Loop Station antei Gibson Les Pauls 6 04-28-2008 01:18 PM
Effects loop attenuator ZoomZilla The Squawk Box 0 03-24-2008 01:39 PM
