#1 (permalink) |
Wax potting
Situation: You have a pickup with no cover and is not wax potted.
You want to install a cover. Question: Do you have to wax pot the pickup before you place a cover on.? I only ask, because, I read somewhere that you should, to cut down on feed back.???? Which makes me think, because Duncan Antiquities come with covers and are not wax potted at least that's what the add said.???? So I'm kinda cornfused.????
And so Castles made of sand, slip into the sea eventually.
#2 (permalink) |
Re: Wax potting
It depends. If you play loud, you should wax pot it. I play loud sometimes, and I can't really use the non-potted pickup, becasue of the feedback.
People say the one without wax pot sounds better (more open and so on), but I don't have a choice. |
#3 (permalink) |
Re: Wax potting
Some Seymour Duncans have neither the coils nor the cover waxed.
But make no mistake, high quality winds are less microphonic without wax than junk pickups are with wax or epoxy. These SDs also have the cover on very tight. It is likely that if you casually put them on on your own you will get more feedback. To make that clear: there is extra waxing going on with the cover. It is not just a waxed pickup with a cover on. |
#4 (permalink) |
'MLP Mid-West'
![]() Join Date: Jan 2008
Re: Wax potting
You can also use a thick piece of double-sided tape to hold the cover tight against the pickup...prevents it from moving.
WB uses that technique on his non-potted pickups--works well on my guitars. BB
I use: WB Custom Pickups--6707 VTP/VTPH, 5707 Prototypes, Habaneros, Firewaters DeTemple 'Sweet Spot' Pickups (Strat) RS Guitarworks Electronics Jonesy's Caps |
#5 (permalink) | |
Re: Wax potting
But it depends how loud you play and with how much gain. |
#8 (permalink) |
Re: Wax potting
A further question on this topic,
If one wanted to change ones chrome covers to nickel, would any action other than the solder blobs be needed, ie, can you just literally take off one cover and push on another? Thanks. |
#9 (permalink) |
![]() Join Date: Apr 2007
Re: Wax potting
Providing the replacement cover is of the same pole spacing then yes you can.
http://www.shedpickups.com |
#12 (permalink) |
Re: Wax potting
It should solve the problem due to the fact that there will be no air pocket in between the coils and the cover ( no air to vibrate) though the pole shoe with poles and baseplate might cause feedback if not tightly built. but get it dunked in some wax if you are finding it a big problem.
#13 (permalink) |
Re: Wax potting
Do a 10 minute wax.
peace n tone ![]() Never underestimate the predictability of stupidity WBpickups-My tones as fat as a Samoan ballerina Yeah my gear is beet up, Thats cause I play it. Shut up and play. http://www.myspace.com/daisychamber whiners click here http://www.youtube.com/watch?v=XDwyG...eature=related |
#14 (permalink) |
Re: Wax potting
All of my Les Pauls have solid nickel covers and un-potted pickups.
No feedback unless I want them to. It's a question of how good you are at manipulating the Volume control, and how many overdrive boxes you have 'on' at the time... My opinion: un-potted, put your amp on '7', and use your Volume & Tone controls...limit your OverDrive boxes to 1 (one).
Democracy is 2 wolves and a lamb voting for what to eat for lunch. Liberty is a well-armed lamb disputing that vote.---Benjamin Franklin >>> RS GUITARWORKS <<< |
#15 (permalink) | |
Capacitor Ambassador
![]() Join Date: Mar 2008
Re: Wax potting
Gibson 490R is 1 15/16" pole spacing and 490T is 2 1/16" spacing. Just added a cover on the neck pu of "Alice" pressed it on tight, no wax and I am liking the sound that I get now, tamed the neck pu and made it sound a bit thicker with the cover on. Have not noticed any feed back or microphonic's with cover installed.
#17 (permalink) |
Re: Wax potting
Output has a lot to do with if it should be potted or not. If pickups are PAF sort of output then they most likely wont feed back where if they are say 43g wire wound hot then you more likely going to need them potted.
You can just stick 2 strips of black tap to the roof of the cover, that will be a preventative of feedback too and saves messy potting. |
| When did Gibson start wax potting? | Juan C. | Pickups | 0 | 02-06-2008 09:02 PM |
