Unread 03-20-2010, 10:00 PM   #1 (permalink)
G12H30 Solder only terminals...Help!
Hey guys,
I am swapping out 2 of the V30's in my cab for some Heritage G12H30's I just got. Thing is though the + and - terminals on these are solder only, so I was looking to get some advice from you guys. I have a Marshal 1960BV with a impedance switch so I am going to have to solder 2 separate wires to the + and - terminals. How should I attach 2 separate wires? (one wire from + to + of the other G12H and the other wire to the Independence switch, like wise for the - terminal). Is it ok if the 2 wire ends that are being soldered to the terminal are touching each other? This is the first time I have changed my speakers so any help would be greatly appreciated. I attached a picture of the solder only terminal.
Marko1986 is offline   Reply With Quote
Unread 03-21-2010, 03:01 PM   #2 (permalink)
Re: G12H30 Solder only terminals...Help!
Just thought of something, instead of soldering two separate wires to one terminal, would I be able to just run 1 wire, strip the section that needs to be in contact with the terminal, solder it and run the same wire to the + or - terminal on the switch? I drew a sketch real quick to explain what im thinking and attached it. That would be just one continuous wire and I know I'd have to do the same thing with the negative terminal I just didn't draw it. But would this be fine, I cant see there being a difference between this or soldering 2 wires that are gonna be on the same terminal. Again, any help would be greatly appreciated guys!
Unread 03-21-2010, 11:42 PM   #3 (permalink)
Echevarria's Avatar
That should be fine. Both speakers is then wired parallel so if you have 8 ohm speakers then the total load will be 4 ohms.
http://www.youtube.com/user/jechevarriadotcom#g/u
Echevarria is offline   Reply With Quote
