Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 07-22-2009, 09:07 PM   #241 (permalink)
Madguitarist78's Avatar
Re: Show your amp!
It gets it done!! I need a 100 watt head though.
2007 Gibson Les Paul Standard (Gingerburst)
2006 Gibson Les Paul Custom (Ebony)
2008 Gibson Hummingbird True Vintage
2007 Takamine EAN40C
*^2004 Marshall JCM 800 2203 100 WATT^*
2006 Marshall JCM 2000 DSL 401
The story of life is quicker than the blink of an eye, the story of love is hello, goodbye.
-Jimi Hendrix
Madguitarist78 is offline   Reply With Quote
Old 07-22-2009, 09:23 PM   #242 (permalink)
Re: Show your amp!
guehwyvar is offline   Reply With Quote
Old 07-22-2009, 10:31 PM   #243 (permalink)
Re: Show your amp!
76 Super Lead, 73 DR112 and 60's EL84 6 watt Scala .
marantz1300 is offline   Reply With Quote
Old 07-22-2009, 10:50 PM   #244 (permalink)
zplapplap's Avatar
Re: Show your amp!
2008 Gibson Les Paul Classic Antique
2000 Fender American Series Telecaster
2006 Breedlove AD20/SR Plus
2008 Fender Super Reverb RI
2009 Vox AC4TV8
2002 Fender Mini Twin
zplapplap is online now   Reply With Quote
Old 07-25-2009, 03:02 AM   #245 (permalink)
BMS
BMS's Avatar
Re: Show your amp!
Marantz, notice my Marshall PA100 underneath the Orange cab?
BMS is online now   Reply With Quote
Old 07-25-2009, 03:38 AM   #246 (permalink)
jodymauk's Avatar
Re: Show your amp!
My Randall G-2 200 watt 1/2 stack,Was to be a Dime sig,Until he got the "WARHEAD"
Not to many in this Color..
I also have a 2/12 combo of the same amp in black,I dont have a pic here of it....
jodymauk is offline   Reply With Quote
Old 07-25-2009, 04:07 AM   #247 (permalink)
Re: Show your amp!
[QUOTE=BMS;975605]Marantz, notice my Marshall PA100 underneath the Orange cab?
Yes,do you have a closer pic? How dose it sound? My DR112 sounds as good as my DR103 did. I got it three days after trading the Custom 100.
Old 07-25-2009, 11:32 PM   #248 (permalink)
DSH
DSH's Avatar
Re: Show your amp!
Since my gig was cancelled, I now have time to post my amps. Just a few quick pics...
Me Marshalls. Modded G10MkII and a 5210 with a Jensen MOD speaker on the left, slightly modded DSL on the right. I swapped a cap so the EQ would sound the same for both channels. Cab is a Carvin but with 2 Eminence Cannabis Rex speakers.
Next up, Fenders...
42, 33, variety, LP Deluxe, LP Custom, R8, ES-135, EDS-1275, Melody Maker RI, Strat, Tele, Ramirez classical, Peerless acoustic, Epi 12 string acoustic, Sho-Bud pedal steel, Jazz Bass, Marshall DSL100, '52 Fender 600, '62 Fender Pro, '65 Fender Tremolux, '77 Fender Pro Reverb, '82 Fender Champ II, assorted stompboxes, ability to build/mod the above, and hopefully the right to bitch.
DSH is offline   Reply With Quote
Old 07-25-2009, 11:47 PM   #249 (permalink)
DSH
DSH's Avatar
Re: Show your amp!
'52 "600." It was once thought this version didn't appear 'till '53, but the handwritten SN puts it in late '52. Completely stock, even the power cord.
This one has the Cleveland speaker. It probably ain't the best. You can also see the RCA blackplate 6V6 peeking through.
'62 Pro. Stock except for the power cord (I saved the orig. 2 prong). Oxford speaker.
'65 Tremolux & late '77 Pro Reverb. I run the T-lux thru the same 2X12 as the DSL pictured above.
Lastly, my '82 Champ II. Great sound & power for its size; it murders Fender's recent similar sized amps (Blues Jr., etc).
(edit) I forgot that the upper back panel on the '62 Pro was recovered; it was pretty much bare wood when I got it.
Old 07-28-2009, 10:42 PM   #250 (permalink)
Re: Show your amp!
a couple more
Old 07-28-2009, 11:12 PM   #251 (permalink)
Toogy's Avatar
Re: Show your amp!
not a great pic, but here's my Traynor YCS50
2008 Gibson Les Paul Standard Faded
2007 Gibson Les Paul Studio
1992 Fender Stratocaster MIM
Traynor YSC50 Tube Amp & DG30D SS Amp
http://www.anotherround.ca
Toogy is offline   Reply With Quote
Old 07-28-2009, 11:36 PM   #252 (permalink)
Wolff's Avatar
Send a message via MSN to Wolff
Re: Show your amp!
BH5 and KranK Rev. Jr. Pro
Wolff is offline   Reply With Quote
Old 07-28-2009, 11:47 PM   #253 (permalink)
Jason's Avatar
Send a message via Yahoo to Jason
Re: Show your amp!
Jason is offline   Reply With Quote
Old 07-29-2009, 04:42 AM   #254 (permalink)
BUDOKAI's Avatar
Re: Show your amp!
Originally Posted by Bowhunterwt View Post
Here another amp in my stable~!!!
looks like my amp except 3x bigger!
Sigs are for losers
BUDOKAI is offline   Reply With Quote
Old 08-30-2009, 11:59 PM   #255 (permalink)
zplapplap's Avatar
Re: Show your amp!
I moved from a townhouse in a college town to a small apartment in the city. I bought a Vox AC4TV8 to play at low volume. Nice little amp. In spite of this, I am considering buying a hotplate for the Super Reverb.
Old 08-31-2009, 01:18 AM   #256 (permalink)
Udonitron's Avatar
Re: Show your amp!
My now discontinued limited run Palomino V32H 30W Class A Head & Palomino V212 Cabinet. These were hardly around long enough to get a ton of written reviews but all the reviews ranted and raved on this 10/10 combo...it really does scream. It's like taking a Twin Reverb & cross pollinating it with a JCM 800...amazing. Even kicks back 45* like the old sweet cabs used to do.
HEAD:
* Output Power Rating: 30 Watts RMS@6 % THD,8 ohm load, 120 VAC
* Signal to Noise Ratio: 71dBTypical
* Gain: Clean 56dB, Overdrive 101dB
* Treble: 12dB range @ 6kHz
* Boost: +10dB @ 900Hz
* Mid: 10dB range @ 1kHz
* Bass: 8dB range @ 150Hz
* Presence: +8dB @ 10kHz
* Preamp Tubes: (3) 12AX7A
* Power Amp Tubes: (4) EL84
* Power Requirements: 120 VAC, 60 Hz, 35VA
* 100/115 VAC, 50/60 Hz, 35VA
* 230 VAC, 50/60 Hz, 35VA
* Size and Weight: 12.2" W x 12.6"H x 25.2" D, 25.5 lbs.
CAB:
Features 2 - 12" Celestion 70 speakers
“The greatness of a nation and its moral progress can be judged by the way its animals are treated”. ~ Mahatma Gandhi
Udonitron is offline   Reply With Quote
Old 08-31-2009, 04:07 PM   #257 (permalink)
citrixmeta's Avatar
Re: Show your amp!
picked up a danelectro nifty seventy on the weekend, for living room playing.
nice little amp.
Dan Electro 56-U2
Godin SDXT
Epiphone SG limited edition (Ebony & Gold)
Orange Crush 30R
Danelectro 15w Nifty Seventy
citrixmeta is offline   Reply With Quote
Old 08-31-2009, 05:24 PM   #258 (permalink)
kelv_w's Avatar
Re: Show your amp!
Just picked up 2 marshall amps this month
Gibson LesPaul Standard '08
Gibson LesPaul VintageMahogany '08
Gibson LesPaul GM BFG '09
Epiphone ES335 Dot VS
Travellers Guitar EG-1
1999 MIK Squire Stratocaster
Orange TinyTerror|PPC112
kelv_w is offline   Reply With Quote
Old 08-31-2009, 06:24 PM   #259 (permalink)
hipofutura's Avatar
Re: Show your amp!
14 watt Phaez Daisycutter with 2x12 British Series Webers.
Don
Unencumbered by Knowledge
Trapped inside this old man's body, is the mind of an old man
08 Classic Antique Wine Red
Traynor YRM-1 (1x12 JBL)
Phaez Daisycutter (2x12 Webers)
www.dcsysinc.com
www.seatrakinc.com
hipofutura is offline   Reply With Quote
Old 09-01-2009, 12:08 AM   #260 (permalink)
brettk7's Avatar
Re: Show your amp!
Just cause I'm all giddy...
You can visit me @
Hit me up with any and all gear questions. I'd be happy to help!
You can reach me on here or at brett@eddiesguitars.com
Rig!: 72' Fender Tele Deluxe RI/ 93' Epi LP Custom/Xotic Ep-Booster/Boss TU2.RV3.DD6/Orange Rocker 30/Orange 4x12
brettk7 is offline   Reply With Quote
Old 09-01-2009, 04:29 AM   #261 (permalink)
Splattle101's Avatar
Re: Show your amp!
Originally Posted by zplapplap View Post
Is the Strat and the Super Reverb a match made in heaven, or what!??!!
...A tasty world...a very tasty world...
Splattle101 is offline   Reply With Quote
Old 09-01-2009, 04:15 PM   #262 (permalink)
caltx01's Avatar
Re: Show your amp!
I just picked up this Blackheart BH5H amp and cabinet yesterday as a practice amp. Great sound and LOUD - very LOUD. This is not a bedroom amp, even at 3 watts. It is LOUD, and dripping with tone. I am very pleased with it.
Modifications? Bitmo 10-uator and Bitmo Triple Bypass tonight. Added a NOS 12AX7. Stock EL84 seems fine.
2005 Gibson Les Paul Standard
2009 Gibson Custom Johnny A. Signature
1997 Fender Stratocaster Plus
Vox P15-SMR408
1959 Fender Tweed Champ
Blackheart(Bitmo) BH5 Ministack
caltx01 is offline   Reply With Quote
Old 09-02-2009, 12:11 AM   #263 (permalink)
zplapplap's Avatar
Re: Show your amp!
It is a great combination. One clearly voiced for the other. I couldn't be happier with the amp. It is probably the best musical instrument purchase I've made. Of course, I let a $1400 USD Vibro-King get away from me. But I try not to think of that one.
Old 09-07-2009, 04:08 AM   #264 (permalink)
BMS
BMS's Avatar
Re: Show your amp!
[quote=marantz1300;975752]
Hey Marantz! Finally took some pics of the P.A.100. It's in rough shape cosmetically. Someone butchered the front for who knows what reason? I found it at a garage sale for 20 bucks! I had it rewired so that it has channel one before the preamp tubes and channel six after(without cutting!). i get some really insane tonal variations. It is very unique.
Old 09-07-2009, 11:08 AM   #265 (permalink)
Re: Show your amp!
BMS. Its a shame Freddy Kruger was the last owner ,but what a fantastic amp .I'd Love to have it and such a bargain. I use to have a similar Sound City PA,which I picked up for £25. I gave it away,full of Mullards .Doh!. I do a similar thing to your amp wiring mod,using a lead I knocked up.
Old 09-07-2009, 11:23 AM   #266 (permalink)
Boshizzle's Avatar
Re: Show your amp!
2008 1959 Reissue Les Paul / 2008 1960 Les Paul Historic VOS FOR SALE / 1974 Gibson Les Paul Special '55 Reissue / 1964 Gibson Country Western Acoustic / 2008 Fender Custom Shop '56 Strat / 2005 Epiphone '57 LP Goldtop - Skynyrd 30th / Agile PS-1000 / 1977 Ovation Legend / 1975 Fender Acoustic / Stelling Red Fox Banjo / Peavey Heritage VTX / Blackstar HT-5 Mini Stack / Epiphone Valve Sr. /
Fender '65 Reissue Deluxe Reverb FOR SALE
Boshizzle is online now   Reply With Quote
Old 09-07-2009, 08:29 PM   #267 (permalink)
BMS
BMS's Avatar
Re: Show your amp!
Very interesting? So, do you utilize each channel? Does it make it louder? It must wail for sure!
Love your Les Paul BTW! I dig those inlays. It's got some real style!
Old 09-07-2009, 08:44 PM   #268 (permalink)
Re: Show your amp!
Dsl 50
Fender Super Reverb
pete is offline   Reply With Quote
Old 09-08-2009, 03:15 AM   #269 (permalink)
Re: Show your amp!
It makes it sound thicker and way louder(not that it needs it). I'm going to experiment with pedals,feeding each into a different input,so I can adjust individual tones and levels. The inlays look more a bit greener usually. The flash makes them like they are in the pic.
Old 09-08-2009, 07:16 AM   #270 (permalink)
SatelliteAmps's Avatar
Send a message via AIM to SatelliteAmps
Re: Show your amp!
Nice Hiwatt PA. Looks familiar.
SatelliteAmps is offline   Reply With Quote
Show yourself. Sean French The Backstage 251 04-09-2009 05:57 PM
I Will Show You Mine ....if you show me yours... FLICKOFLASH The Backstage 59 08-02-2008 10:43 AM
show off your SG Paul My Other Guitars 59 07-03-2008 01:18 PM
L.A. Amp Show SAt. Oct. 6th !!! WCR The Backstage 9 10-04-2007 10:05 PM
LA AMP Show...anyone from here going? Southbay Ampworks The Backstage 1 09-26-2007 10:01 PM
