Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 11-06-2009, 01:13 AM   #1 (permalink)
Amp Started Smoking
So the other night me and my friend were jamming and i had my '81 Fender Deluxe Reverb on full volume and the volume started fading in and out when i was playing and then lots of smoke started coming out the back. Im not sure where the smoke come from. Anyone have any ideas of what could have happened and if it would be expensive to fix? thank you.
cjdincus is offline   Reply With Quote
Old 11-06-2009, 01:43 AM   #2 (permalink)
Atomic's Avatar
Re: Amp Started Smoking
one of the elves inside opened the door and let the magic smoke out.
once the smoke is gone, so is the magic that makes the amp work.
but seriously, it could be any number of components really.. any attempt to say what it is without opening the amp and testing in person is pure speculation. take it to a qualified amp tech.
Atomic is offline   Reply With Quote
Old 11-06-2009, 01:54 AM   #3 (permalink)
KSG_Standard's Avatar
I've only seen one amp smoke, it was caused by a short...If you are not an electronics guy, take it to an amp tech. The deluxe reverbs have been around forever and there are plenty of techs that can figure out what's up with it. Maybe you'll be lucky and the fix will be cheap. Good luck!
"Get your facts first, then you can distort them as you please."
Mark Twain
KSG_Standard is online now   Reply With Quote
Old 11-06-2009, 02:29 AM   #4 (permalink)
TeleDog's Avatar
Tube amps require periodic service. Have you ever serviced the amp? Replacing the tubes, checking the caps...
If not, it's probably the amp showing its age and lack of TLC...
... just blues it up a little!
TeleDog is offline   Reply With Quote
Old 11-06-2009, 03:02 AM   #5 (permalink)
thanks for the info. yeah i had the tubes changed back in july but the amp itself has been serviced since 89 i think so its been a while. im gona take it to the shop soon. Once again thanks for helpin
Old 11-06-2009, 03:22 AM   #6 (permalink)
Splattle101's Avatar
You bastard.
Filter caps, rectifier...the list is endless.
...A tasty world...a very tasty world...
Splattle101 is offline   Reply With Quote
Old 11-06-2009, 03:37 AM   #7 (permalink)
Atomic's Avatar
Originally Posted by Splattle101 View Post
You bastard.
hey every bench jockey worth his salt has said that to at least one customer.. and done so with a straight face.
Old 11-06-2009, 07:23 AM   #8 (permalink)
hipofutura's Avatar
I'm guessing transformer.
Don
Unencumbered by Knowledge
Trapped inside this old man's body, is the mind of an old man
08 Classic Antique Wine Red
Traynor YRM-1 (1x12 JBL)
Phaez Daisycutter (2x12 Webers)
www.dcsysinc.com
www.seatrakinc.com
hipofutura is offline   Reply With Quote
Old 11-06-2009, 07:26 AM   #9 (permalink)
paulygates's Avatar
It should be easy to identify. The bit that looks burned is probably it. I would still take it to a tech though. There maybe another faulty component that caused it to overheat.
04 LP Std HCSB (Grace)
94 Epi LP Classic Birdseye Maple top (The Captain)
Flextone III XL
http://www.thesilverhorses.com/#
paulygates is offline   Reply With Quote
Old 11-06-2009, 07:46 AM   #10 (permalink)
MLP Trucker
dennistruckdriver's Avatar
Originally Posted by cjdincus View Post
Amp Started Smoking....
Your amp is hanging out with a bad element. Next thing you know, it'll be drinking, taking downers and amphetamines and stealing.
Originally Posted by diceman View Post
Sound it out, Dennis. Play-Bill-Titty
Who is Bill? And, why does he have Titties??
"I've never used one, but I hear good things about them."
dennistruckdriver is online now   Reply With Quote
Old 11-06-2009, 08:01 AM   #11 (permalink)
paulygates's Avatar
I wondered who would go down that road.
Flextone III XL
Old 11-06-2009, 09:18 AM   #12 (permalink)
BillB1960's Avatar
All electronic devices are powered by smoke. Irrefutable evidence of this is available by simple observation: when an electronic device starts showing visible smoke it stops working, e.g. the smoke has leaked out. This is because electronic devices run on a "closed loop" system, as opposed to automobiles which run on an "open loop" system.
Now the trick is finding which of the components has begun leaking and let the smoke out. Since some individual components actually generate their own smoke it is sometimes possible to simply replace the component and it will create the necessary smoke to power the device. However in most cases it's best to take it to a professional who will replace the faulty component and refill the device with smoke.
For many years there has been a significant shortage of smoke available on the open market. The manufacturers seem to be able to get it but most smaller repair facilities can't which is why they tell a lot of people that it's better to buy a new device than repair the old one. There's also been a concerted effort to get consumers to recycle their old electronic equipment so that the smoke can be reclaimed but so far success has been limited.
I've yet to see smoke "commoditized" but it wouldn't surprise me to someday soon see "smoke futures" traded on the open market. When that happens watch out...there could ba a serious run up in the cost of electronics.
None of this helps you figure out what went wrong with yor amp. Just take it to a pro and let him figure it out.
Classic Antique Fireburst GOTW #2
Classic Antique Tom Morgan GOTW #5
Deluxe Antique Gold Top GOTW #8
ES-339 Caramel Burst
Fender Limited Edition Strat
Ibanez AR-250
Epiphone DR500M Masterbilt
Crate Vintage Club 20
Mesa/Boogie F30
Fender Prosonic
Zvex Nano
Al Gore didn't invent the Internet but he did make up Global Warming
BillB1960 is offline   Reply With Quote
Old 11-06-2009, 10:24 AM   #13 (permalink)
Belzeebub's Avatar
looks like you've fried the transformer.
2008 Gibson Les Paul Classic Heritage Cherry with Guitarforce Vintage '57s
Belzeebub is offline   Reply With Quote
Old 11-06-2009, 10:25 AM   #14 (permalink)
paulygates's Avatar
Thanks for clearing that up, Bill
Flextone III XL
Old 11-07-2009, 12:31 PM   #15 (permalink)
lp_junkie's Avatar
my Fender amp caught on fire during a sound check once, prompting my return to Marshalls in 1997.
Smoke means heat, which is the enemy of all things electronic, it can get very expensive repairing amps depending on what caused the smoke.
LP_Junkie
my personal MySpace
Disclaimer- The opinions expressed on this site may cause incontinence, wadded panties, indigestion, insecurity and other serious maladies. Use as directed, not intended for the overly sensitive and humor impaired.
lp_junkie is offline   Reply With Quote
Old 11-07-2009, 08:03 PM   #16 (permalink)
Those of you suggesting particular components, forget it. There are any number of things that could have gone, and in combination.
You can do a lot of initital trouble shooting with your nose. Where does the smokey smell come from? With your eyes: which bits look burnt? And so on. But you can do sweet fuck all along those lines sitting behind a computer monitor.
It must go to an amp tech.
Old 11-07-2009, 08:06 PM   #17 (permalink)
axepilot's Avatar
Thank you! Too many web experts here.........................with devining rods seeking the cause.
1996 Les Paul Studio Gem, 2001 Les Paul Studio Plus, 2002 SG Supreme, 2006 Les Paul Standard LE, 2008 SG Classic, Fender Double Fat Strat, Bluesville "Super" Strat copy, Fender Tele, Ovation 1897 Adamas, Taylor 355CE
Germino Club 40, Johnson JM150 Millennium, Johnson JM250 Millennium, Axe FX Standard rack rig, Mesa 4x12 cab (V30's), Highly modded Gibson Titan Medalist
axepilot is offline   Reply With Quote
Old 11-07-2009, 08:22 PM   #18 (permalink)
hipofutura's Avatar
Ah, come on guys. We're just having fun with intellectual masturbation. Of course we don't know what components smoked this amp, and of course it will have to go to a tech for repair.
Remember, the OP asked what could have happened. I believe he received most if not all possibilities from the collective MLP armchair amp techs.
Don
www.dcsysinc.com
www.seatrakinc.com
Old 11-07-2009, 09:29 PM   #19 (permalink)
weirdotis's Avatar
It could need a cap job but if you replaced the fuses and it works fine, I'd leave well enough alone.
Matt
- Matt
One lonely Les Paul, some pedals, and a nice amp.
weirdotis is offline   Reply With Quote
Old 11-08-2009, 04:52 AM   #20 (permalink)
vortexx's Avatar
I've seen a picture of Ritchie Blackmore with his cab on fire
62 Epiphone Coronet
Epiphone Korina V 58 re-issue
Fretlight strat style
Fender Baja Telecaster
Orville By Gibson 59 re-issue
Raven West Guitars LP style Lizardburst
Fender J5 3 Telecaster
Gibson V2
Epiphone Mo Baby
WCR fillmore pickups
PRS #10 pickups
Gibson long magnet PAF
vortexx is offline   Reply With Quote
One Way To Quit Smoking.... Led Zep Fan The Backstage 0 06-30-2009 08:43 AM
Smoking in Hotels EEF13 The Backstage 49 02-15-2009 10:32 PM
What Are They Smoking In Philly? Led Zep Fan The Backstage 1 02-12-2009 01:52 PM
quitting smoking Pwozzie The Backstage 41 12-30-2007 05:01 PM
