Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 10-31-2009, 04:35 PM   #1 (permalink)
leftyguitarman's Avatar
Ohm question
My buddy has one of these: Marshall AVT50 Guitar Combo Amplifier (50 watt, 1x12 inch) from zZounds.com
He blew the speaker a while back and can't find a 4 ohm replacement speaker. Could he use an 8 ohm speaker or a 16 ohm speaker, or does it have to be a 4 ohm speaker?
leftyguitarman is offline   Reply With Quote
Old 10-31-2009, 04:46 PM   #2 (permalink)
Paragon's Avatar
Re: Ohm question
https://taweber.powweb.com/weber/
Memphis "The Paul" • Mightymites
Partscaster • Lace Sensor Gold
Vox AD60VTX • VC12
Vox VT30 • Crybaby Classic
Danelectro Nifty Fifty 4Sale?
Paragon is online now   Reply With Quote
Old 10-31-2009, 04:48 PM   #3 (permalink)
Boshizzle's Avatar
Re: Ohm question
The answer to your question depends on who you ask. Personally, I don't ever use a speaker unless it matches the output requirements of my amp. That being said, some people claim that SS amps aren't as picky about speaker impedance as tube amps.
Does it have an ohm selector switch on the back? If not, you could get an impedance matcher. But, it might cost less just to get a 4 ohm speaker.
2008 1959 Reissue Les Paul / 2008 1960 Les Paul Historic VOS FOR SALE / 1974 Gibson Les Paul Special '55 Reissue / 1964 Gibson Country Western Acoustic / 2008 Fender Custom Shop '56 Strat / 2005 Epiphone '57 LP Goldtop - Skynyrd 30th / Agile PS-1000 / 1977 Ovation Legend / 1975 Fender Acoustic / Stelling Red Fox Banjo / Peavey Heritage VTX / Blackstar HT-5 Mini Stack / Epiphone Valve Sr. /
Fender '65 Reissue Deluxe Reverb FOR SALE
Boshizzle is online now   Reply With Quote
Old 10-31-2009, 05:02 PM   #4 (permalink)
rickym's Avatar
Re: Ohm question
12" Bugera 4 ohm 50 watter.
Bugera 12" 4ohm 50watt Replacement Speaker - eBay (item 370278964229 end time Nov-21-09 15:40:20 PST)
Eminence Texas Heat.
http://cgi.ebay.com/Eminence-Texas-H...item5188e8eb6e
ShamRockers-1Up/Press Play On Tape-The Eric Clapton Social Group-The VOX club
rickym is offline   Reply With Quote
Old 10-31-2009, 05:04 PM   #5 (permalink)
Atomic's Avatar
Re: Ohm question
with impedance you can always go up but never down. SS amps are not as picky with output impedance matching as tube amps are, but it is best to match when possible. putting an 8 ohm load on a 4 ohm output will most likely not be an issue.
Atomic is offline   Reply With Quote
Old 10-31-2009, 06:58 PM   #6 (permalink)
axepilot's Avatar
Re: Ohm question
That is true for SS amps. Go below the minimum rated impedance of a SS amp and you will blow the final amps.
With a tube amp, the output transformer is the critical component. While it's always best to match the speaker load, most modern tube amps can live with a 2:1 mismatch either way...................I wouldn't push it any farther or you'll be tickling the dragon.
1996 Les Paul Studio Gem, 2001 Les Paul Studio Plus, 2002 SG Supreme, 2006 Les Paul Standard LE, 2008 SG Classic, Fender Double Fat Strat, Bluesville "Super" Strat copy, Fender Tele, Ovation 1897 Adamas, Taylor 355CE
Germino Club 40, Johnson JM150 Millennium, Johnson JM250 Millennium, Axe FX Standard rack rig, Mesa 4x12 cab (V30's), Highly modded Gibson Titan Medalist
axepilot is offline   Reply With Quote
Old 11-01-2009, 11:32 PM   #7 (permalink)
jrnic's Avatar
Re: Ohm question
I am currently using an 8 ohm Speaker in my Marshall combo that originally had a 4 ohm speaker. No problems whatever. Like it was said above, you can go up in ohms but not down.
jrnic is offline   Reply With Quote
Old 11-02-2009, 12:34 PM   #8 (permalink)
...with a big mouth
Big John's Avatar
Re: Ohm question
5 seconds with Google and I found the manual...
i. Combo Version (AVT50)
This socket allows you to connect your AVT50 into an external loudspeaker system, provided it has an impedance of 8 or 16 ohms. By using any one of our comprehensive range of extension cabinets, you will be able to unleash the massive amount of tonal options that extra loudspeakers will provide.
...blah, blah, blah...
WARNING:
Always provide the AVT50H with a load equal to, or greater than, 4 Ohms. Using the two loudspeaker outputs, with cabinets rated at 8 Ohms each, the full 50W of the specially designed AVT power amplifier will be unleashed.
In other words, the factory speaker in the 1x12 combo is an 8 ohm speaker, and always has been. If it was a 4 ohm speaker and you got a wild hair one day to plug in an extension cab, the total load would be below 4 ohms which, according to the warning in the manual, is not good.
Big John is offline   Reply With Quote
Old 11-03-2009, 08:00 PM   #9 (permalink)
axepilot's Avatar
Re: Ohm question
It all depends on whether the amp is tube or SS:
Tube - Matching impedance is best, but mismatching a lower speaker load is the safer bet. Mismatching with too high a speaker load risks flyback in the OT - and it will kill the OT. Most modern tube amps can safely handle a 2:1 mismatch either way, but matching is the safe bet. With older tube amps, match the impedance - time is not on their side and some of them have delicate OT's.
SS - can be operated into a straight open because they have no OT. Running a speaker load lower than minimum rated impedance will fry the final amps.
SG Question - Need vintage expert. Polaris White question brockburst Gibson Les Pauls 4 04-22-2009 08:55 PM
Quick and easy question about SD wiring diagram (and a soldering question) bluestandard Tonefreaks 2 12-21-2008 07:25 PM
Acronyms Question and Chassis Question Jupa The Squawk Box 4 11-03-2008 03:44 PM
A question of taste.... (Goldtop question) screamingdaisy Historics & Reissues 15 07-21-2008 07:55 AM
time to think...question about pickupz...take a look not a typical question st.bede The Custom Shop 7 03-16-2008 09:45 PM
