Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 10-30-2009, 10:24 AM   #1 (permalink)
Grand Pappy in Chandler's Avatar
Speaker Advise Needed FAST!!!!
I have a chance to pick up a slightly used Eminence Texas Heat 12" 8 ohm speaker CHEAP! It's a 150 watt speak. I want to use it in a 1x12" cab as an extension speaker for a Mesa 5:25 Express. Is this too much speaker for a 25-30 watt amp? Should I get something w/ lower wattage?
Please advise poor pappy, oh wise amplifer guru's of MPLF!!!
Thanks in advance
Baby Jake Approves!!!
Grand Pappy in Chandler is offline   Reply With Quote
Old 10-30-2009, 12:16 PM   #2 (permalink)
Boshizzle's Avatar
Re: Speaker Advise Needed FAST!!!!
I run a 5 watt amp through a 200 watt 4x12 so, I don't see why the wattage would be an issue. Speaker watts capacity is something you don't want to exceed. Under the rating is OK.
Make sure the speaker impedance matches your amp's output and make sure that the speaker wattage rating is greater than your amp's output. So, a 30 watt amp running through a 150 watt speaker isn't a problem as long as the speaker impedance (in this case 8 ohms) matches the requirement of the amp.
2008 1959 Reissue Les Paul / 2008 1960 Les Paul Historic VOS FOR SALE / 1974 Gibson Les Paul Special '55 Reissue / 1964 Gibson Country Western Acoustic / 2008 Fender Custom Shop '56 Strat / 2005 Epiphone '57 LP Goldtop - Skynyrd 30th / Agile PS-1000 / 1977 Ovation Legend / 1975 Fender Acoustic / Stelling Red Fox Banjo / Peavey Heritage VTX / Blackstar HT-5 Mini Stack / Epiphone Valve Sr. /
Fender '65 Reissue Deluxe Reverb FOR SALE
Boshizzle is offline   Reply With Quote
Old 10-30-2009, 01:47 PM   #3 (permalink)
G Man's Avatar
I'm running a 50 watt Cannabis Rex in my 15 watt Blues Jr and it sounds great. I'd say go for it.
G Man is offline   Reply With Quote
Old 10-30-2009, 01:49 PM   #4 (permalink)
Disciple-of-RobotOverlord
xsouldriverx's Avatar
i run one in my 30 watt amp and it gets the exact sound that i wanted. no issues at all.
DOOOOO ITTTTTTT!
2005 Ibanez H.R. Giger Iceman
VHT Deliverance 60
xsouldriverx is offline   Reply With Quote
Old 11-03-2009, 02:30 PM   #5 (permalink)
Well.... I got the Emi Texas Heat this weekend and installed it in a Epi Valve Jr 1 x 12"extension cab.
I tried it through my Boogie 5:25 8 ohm jack, by it's self and was pleased.
No farting out on the lows. crisp mids and highs
Played with both the internal 10" and the 1X12" extension plugged in to the 4 ohm jacks and again was pleased w/ the sound. Great cleans good sparkle on the blues setting.
I used my Firebird V all afternoon and was impressed with the over all performance using the TH as a stand alone and in unison w/ the internal 10".
I got the TH for $30, still in the box, so I'm happy w/ the $$ and the speaker!
Thanks to all for their advise
Old 11-03-2009, 05:28 PM   #6 (permalink)
im happy you went with it!
VHT Deliverance 60
Help.. advise needed on tuner installation. billy The Custom Shop 10 10-22-2009 03:50 AM
New speaker needed? Wyleway The Backstage 1 04-12-2009 01:53 PM
Pleeeezzzzzz - urgent advise needed! ajaxajax2000 Gibson Les Pauls 33 12-07-2008 06:34 AM
Just finished my speaker cab last sunday! Need speaker advice. siore The Squawk Box 8 10-18-2008 03:43 AM
boss advise needed!!! terence_tez Pedals 9 04-17-2008 01:34 PM
