#1 (permalink) |
![]() Join Date: Oct 2007
Another infamous ohms questions
I have a Fender pro reverb RI (2005 model). I want to connect my marshall
4x12 cab which is switchable from 4 or 16 ohms. my amps internal speaker is 8 ohms and the ext jack says 8 ohms. The amp automatically switches to 4 ohm load when both jacks are connected can this be safely done at the 16 ohm setting on my cab. ![]() thanks |
#2 (permalink) |
Re: Another infamous ohms questions
Yep you should be safe as long as amp output load is lower than the cab value... you can even drive the cab at the 4 Ohms setting as you stated when both internal and external jacks are loaded the amp load is reduced to 4 Ohms.
Did you see the Sun outside today? Burning the bridges I built yesterday!
Proud member of Ireland's ShamROCKers! |
| Is a guitar amp load 2.2 Meg ohms or 47K ohms? | Mitch Malloy | Tonefreaks | 0 | 03-29-2008 05:57 PM |
| Tubes, Ohms, Series, and Confusion?? | diceman | The Squawk Box | 8 | 03-28-2008 03:46 AM |
| question about speaker ohms!?!?!?!? | tarddoggy | The Squawk Box | 9 | 03-06-2008 01:43 AM |
| p90 dogear ohms ? | frrrrrrunkis | Pickups | 1 | 10-08-2007 08:05 PM |
