#32 (permalink) |
Rock Star
![]() Join Date: Sep 2007
Re: What do you think of Marshall's Today ???
I know im mental, but i try to stay on my meds
...........Cold Steal II Soundclick Songs ................. ColdSteal2's YouTube Videos.............MusicMight Secret Service . Still Rockin' at 56 . |
#33 (permalink) | |
![]() Join Date: Aug 2007
Harpo, You should check out a JCM000 Dual Reverb, OR a Vintage Modern, but forget that Power Soak, especially if its the Tom Sholtz one, one very bad attenuator, The Marshall isnt much better
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#34 (permalink) | |
![]() Join Date: Nov 2007
"Specs: The JCM 900 Dual Reverb was produced by Marshall during the 1990's. Marshall engineers voiced Channel A for sparkling clarity but added enough percussive punch to kick out every note. Channel B provided "potent gain and grinding aggression" for solos. Each channel has its own reverb control. Features of the Dual Reverb series * Separate preamp gain controls: Channel (A) 1-10, Channel (B) 0-20 * Tone network with Treble, Middle, Bass, and Presence controls * Individual master volume controls for each channel * Separate reverb controls for each channel * Manual or footswitch operation for channel selection * Effects loop with sensitivity control * Direct and recording compensated line ouputs * Impedance selection switching * Two speaker outputs * High/low power switching (pentode to triode) * Valve failure LEDs * Entirely wired and assembled by hand in England * 100 watt models (model numbers 4100, 4101, 4102) feature 4 x 5881 output valves, 3 x ECC 83 preamp valves" I just cannot have the volume associated with a 100 watt hafl stack though. As much as I love all out roar and tone, I will need to bring it down in DB and loose some tone/add spnginess, etc. Just what has to be, unfortunatly. Are there any attenuators that you would recommend? I used the Sholtz for years with my Ameg V4 head and a Sound City 4 x 12 cab. No ill effects that I'm aware of. Some folks highly revere it while others say it was badly designed and hurts the amps. ![]() I just need to bake some power tubes for the sounds I crave. Pushing just the preamp tubes is not getting me there with my Mesa and will likely not with any Marshall as well. Plus I need the volume at human levels, not rock god ones
"Ape Shall Not Kill Ape” Only 1,970 years until the Reign of Zaius! ![]() I Use WB Pickups http://www.wbpickups.com/ "Trizzle Trazzle Trozzle Trome, Time For This One To Go Home!" http://www.sargescomics.com/ |
#35 (permalink) |
![]() Join Date: Apr 2007
That's what I thought. Thanks for verifying that!
They say that the '59 Bassman is the "Holy Grail" of amps.
You have a nice guitar, but can you actually play it? |
#36 (permalink) |
Since Marshall can't make a decent channel switching amp I went with a newer Splawn Quickrod. Awesome Marshall crunch, nice clean and high quality parts and construction. Affordable too. The Bogner Shiva is a great alternative, though more pricey.
#37 (permalink) |
Harpo, IF you need the 100 watts, but I had 4500, and 4501 ( 1 12 Combo )
The 900 series uses a half power switch in the back which is already some attenuation right there The 4100 series does the same going from 100 down to 50 , There are several ways in which to attenuate an amp, either thru making the signal work down or thru DC resistance, The Power Soak uses a very crude form of resistance using wood blocks, but here is my all time recommendation for attenuation, I have seen it used and used it myself, I am shopping for one as well https://taweber.powweb.com/weber/mass.htm
#40 (permalink) | |
Guess it's time to sell the Power5 soak to the hoards on ebay and put some 4 towards a weber. The biggest problem I have with heads is so many of them do not have reverb, and I'm a reverb guy. My V4 did, it was a late '70's model. I even used the reverb to record some vocals through in a pinch back in my four track reel to reel days. I went to the local Orange dealer today. All they had left were some Crush practice amps and other solid state thingies. ![]() I have several solid state thingies now and one real tube Mesa. I'm thinking a British tube sound is what I'm really after, so I'd love to try a Rockerverb 50 Combo or head. Might still need to bring down the DB with a Weber. Dunno yet.... I saw some Marshall combos today, the Vintage Modern. Looked like it has a good voice, I just want it to channel switching too... I guess I want it all, eh
#41 (permalink) | |
Attenuating some amps , like a Bassman59 type or a Plexi will give you tones so sweet you wont even miss your reverb at all, Trust me I love verb too, but I've done this, and you wind up reaching tones you could never find , because they were hiding in the verb Slide a EQ into the loop of a VIntage Modern, Attenuator Use the High and low gain and your volume knobs and tones and you wont need a second channel, you will have more than enough tones, plus the wanted or needed verb on call
#42 (permalink) | |
I'll agree that reverb can hid tone, but it also adds an ambiance that is all its own that no room can emulate. Sometimes you get a room that works real well for you and the reverb never gets turned on. It's just nice to have it available.
#43 (permalink) |
MVP Clown
What do you need channel switching for ? I use my one channel JCM800 and boost it with a Klon for more chunk !!
" Over the Pond Guy " PAF Pickups & M69 Rings ... @ OverthePondGuy@aol.com |
#44 (permalink) |
I like channel switching because sometimes I want a true clean sound. Rolling down the volume doesn't get clean enough for me and I believe an amp should have the proper amount of gain built in. The Quickrod smokes any channel switcher Marshall has made in tone, features and build quality. I'm not really into effects... I like just having the amp footswitch, tuner and wah.
#45 (permalink) |
Rock Star
marshalls arent suposed to be clean
#47 (permalink) |
Rock Star
You can get them at really decent prices on eBay also
#48 (permalink) |
My amp has the best of both worlds. That's cool if you don't need or want a clean sound. Since we don't live in the late 60's anymore I expect amp companies to offer amps that deliver both nice cleans and raunchy crunch. Some people like lugging around multiple amps for cleans and crunch, but I like having it all in one box.
#49 (permalink) |
Rock Star
I guess so.
Back in the old days you just used a Plexi, for clean you turned it half way, and for lead you cranked it but nobody can handle those DB's anymore, so that makes sense
#50 (permalink) | |
Maybe the new Vintage Modern channel switcher will be good. If I didn't need or want a clean channel I'd have totally bought the original single channel version. It's a sweet sounding amp for crunchy Marshall tones. |
#51 (permalink) | |
I still like the Vintage Modern Marshall too the only thing in the Marshall Catalogue that interests me and is near affordable
#52 (permalink) |
![]() Join Date: Jun 2007
Other than the handwired ones and some of the reissues, the rest are flimsy overpriced junk. Why did Marshall get away from building solid, roadworthy amps? Even as far back as the Jubilee with the big PCB dangling from the front pots and jacks, cracking solder joints all the time. Who ever thought that was a good idea?
#53 (permalink) |
MVP Clown
#54 (permalink) |
I like certain models that are out there, mostly from more than 10 years ago but there are definitely some good amps.
As much as I loved the JCM800s I do like having more gain, so the newer ones sound great to me.
LP_Junkie ![]() my personal MySpace _____________________________________________ Disclaimer- The opinions expressed on this site may cause incontinence, wadded panties, indigestion, insecurity and other serious maladies. Use as directed, not intended for the overly sensitive and humor impaired. |
#55 (permalink) |
I don't like new marshalls at all besides there cabinets I find they lack the great crunch or "brown" sound of the older moldels. I went to Orange and found that amazing tone I was looking for and an amazing clean channel with a Marshall you sacrifice your great cleans for good distortions and now a days you don't even get a good distortion...
#56 (permalink) |
Rock Star
Vintage Modern has the old brown sound
speaking of vintage amps, Marshall has a new 1987XPW combo (Paul Weller....i know Oasis....) Chanel one is a Super Lead chanel, Chanel 2 is a Super Bass chanel has two G12C greenbacks, EL34 power tubes Is white but im not crazy about the grill if you can get past the dorky grill cloth looks like a great amp http://www.marshallamps.com/product....ctCode=1987XPW ![]() ![]() ![]()
...........Cold Steal II Soundclick Songs ................. ColdSteal2's YouTube Videos.............MusicMight Secret Service . Still Rockin' at 56 . Last edited by coldsteal2; 03-01-2009 at 03:35 AM. |
#57 (permalink) |
![]() Join Date: May 2008
I dunno. I haven't been blown away by the sound of any Marshall since the JCM 800. A guy I used to gig with (he was in the support band) back in the early 90s had a 900, and it just didn't sound as good as the 800s. There was something kind of fizzy about it. Marshall seems to have gone more and more in that direction ever since, with the notable exception of the VM.
But to be honest, there are better heads out there. My ancient Laney AOR slaughters Marshalls. Monstrous bass that no Marshall ever matched, with the tight mid range of a cranked JMP, but with the gain structure of the 800 series. I switched from my Laney to a Marshall JMP in the early 90s (92, I think) because the Marshall must be better (right?). Lots of people commented on exactly the opposite. It was really rather odd. I had people telling me the Laney sounded better (which I really didn't want to hear, having just bought my dream amp), whereas before I'd had people coming up to me after gigs and asking me how I got 'that' tone when I was playing the Laney. I am slow, but I got the message eventually... So while I have nothing against Marshall, it's a long time since I was impressed by one. And I definitely like their old stuff better than the new. Unfortunately, the 'new' seems to date from about 1993.
...A tasty world...a very tasty world... |
#58 (permalink) | |
), so I can't think of an indoor venue that would take a cranked Marshall half stack in this town anymore.This is one of the reasons I play 40 Watt combos these days.
#59 (permalink) | |
#60 (permalink) |
![]() Join Date: Jun 2008
I've got a Vintage Modern and think it is pretty damn cool that the designer posts on the vintage modern forum. I almost couldn't believe it. Usually the people behind these things are hidden from the customers, by choice I suppose. But he takes time to answer all sorts of questions about the amp, with patience and without dissing other amps. Makes me appreciate the VM a lot more.
| Went to the store today..... | buck7617 | Gibson Les Pauls | 18 | 04-16-2008 11:16 AM |
| look what i got today! | 1959burst | Vintage Les Pauls | 7 | 04-10-2008 07:52 AM |
| SF Bay Area Today.... | WildeStarr | The Backstage | 13 | 04-02-2008 08:51 PM |
| My amp came today!!!!! | needlespauls | The Squawk Box | 11 | 02-20-2008 05:35 PM |
| came today.... | dogbone94 | Gibson Les Pauls | 17 | 01-31-2008 07:20 PM |
