Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 04-16-2007, 07:56 PM   #1 (permalink)
GLOBAL STOOGE MOD
FLICKOFLASH's Avatar
Roland Micro-CUBE
I had a chance to play with one of these at the Greensboro Les Paul Jam & let me tell you i was quite impressed , Much so that I desire to purchase one, It not only had a vast spectrum of modeled guitar amp sounds but had some good effects as well. This amp sounded rocking even at low volume
Roland Micro-CUBE Guitar Amplifier :: Overview
FLICKOFLASH is online now   Reply With Quote
Old 04-17-2007, 12:16 AM   #2 (permalink)
CAFeathers's Avatar
Send a message via ICQ to CAFeathers Send a message via AIM to CAFeathers Send a message via MSN to CAFeathers Send a message via Yahoo to CAFeathers
Re: Roland Micro-CUBE
Must have been Wagner's, he and Dillon love those things.
Authorized TonePros Dealer
Authorized WD Music Products Dealer
2006 Gibson CS-336
2001 Gibson LP Standard
2006 Fender Highway 1
1986 Fender MIJ '72 RI
CAFeathers is offline   Reply With Quote
Old 04-25-2007, 09:31 PM   #3 (permalink)
GLOBAL STOOGE MOD
YouTube - Pink Floyd Wish You Were Here Roland Micro Cube test
YouTube - Johnny DeMarco for Boss/Roland
YouTube - Roland micro-cube
Old 04-26-2007, 05:28 AM   #4 (permalink)
GuitarGal's Avatar
Plan to buy one Flick?
GuitarGal is offline   Reply With Quote
Old 04-26-2007, 03:07 PM   #5 (permalink)
GLOBAL STOOGE MOD
Yeap !!!
Old 04-28-2007, 06:59 PM   #6 (permalink)
GuitarGal's Avatar
Originally Posted by FLICKOFLASH View Post
Yeap !!!
Let us know once you get it~
Old 04-29-2007, 07:22 AM   #7 (permalink)
Yeah Chet,it was Jims.
Thank you for playing guitar.
Gavin Morse is offline   Reply With Quote
Old 05-03-2007, 07:02 PM   #8 (permalink)
GLOBAL STOOGE MOD
YouTube - LP Classic Test 1
Old 05-05-2007, 06:03 PM   #9 (permalink)
GLOBAL STOOGE MOD
Roland Micro Cube Red and Vox DA5
By Barry Cleveland | August 2006
Small guitar amplifiers are hardly new, and battery-powered models have been available since the early ’70s, but the advent of digital-modeling technology has made it possible for even the most diminutive amp to deliver multiple tones, and even relatively sophisticated digital effects. The Roland Micro Cube Red and Vox DA5 are prime examples of this new order. For street prices of less than $150, these little wonders offer a variety of tones reminiscent of classic amps, a selection of high-quality digital effects, the ability to monitor with headphones or send a line-level signal directly to a recorder or P.A., and the option of being powered using either an AC adapter or batteries.
The Roland Micro Cube Red is a limited red edition of Roland’s popular Micro Cube digital-modeling amplifier. Like the standard black version, it sports six COSM amp models (including an acoustic guitar simulator), six DSP effects (with two independent processors), and a three-tone digital Tuning Fork (A, Ab, or Abb). In addition to the standard guitar input, you get 14" and r" Aux inputs, and a 1" recording/headphone direct output. You can also plug a high-impedance microphone into the guitar input, and set the Amp Type switch to Mic if you need a mini P.A.
Given its two-watt power section, the Micro Cube is not particularly loud. For example, with the “JC Clean” amp model selected and the Gain control fully counterclockwise, there’s enough ultra-clean volume for practicing. Cranking up the Gain adds considerably more level with only minimal distortion—but there’s still not enough volume for, say, a band rehearsal.
Besides the JC Clean model (which actually does capture a bit of the flavor of a Roland Jazz Chorus amp when you dial in some chorus), you get Black Panel (Fender Twin Reverb), Brit Combo (Vox AC30TB), Classic Stack (Marshall JMP1987), and R-Fier Stack (Mesa/Boogie). Although some of these sounds are reminiscent of the amps modeled, the others are a stretch, and that stretch lengthens as you increase the gain, which can cause the Micro Cube to break up in unpleasant ways—particularly at higher volumes. With a little tweaking, you can get distortion sounds that are fine at practice levels, but much past that, the limitations of the 5" speaker quickly become apparent. My favorite models were the JC Clean, the screaming R-Fier, and the remarkably realistic Acoustic (which induced a minor identity crisis in my Les Paul Custom).
Not surprisingly, the Micro Cube’s onboard effects sound a lot like Boss pedals—which is a good thing. It’s also a nice touch that you can choose between chorus, flanger, phaser, or tremolo in one independent section, and add delay or reverb in another. Other than being able to adjust the level of each effect (or the delay time in the case of the delay), the effects parameters are fixed, but the presets are just dandy for general use. The Reverb is particularly impressive, though it sounds more like a hall than the usual spring simulation.
The Aux inputs work well, as long as the level coming from the source isn’t too hot (there’s no input level control). The headphone/recording output sounds great. It bypasses much of the flabbiness of the small speaker on more distorted settings, and it highlights just how quiet the Micro Cube is overall. The tuner delivers a clean tone, and it’s a nice little “value added” afterthought, but a visual tuner would be more beneficial—as would a more sensible E tone. (And what’s up with that Abb tone?).
A great little practice amp with exceptionally quiet operation and a generous feature set, the Micro Cube offers excellent value for a minimal investment.
Vox DA5
Boasting some of the same digital modeling technology found in Vox’s larger amplifiers and effects devices, the DA5 provides lots of tonal options for an amp this size. You get 11 amp models that are labeled by sound type—rather than the specific amp they are based on—and 11 effects presets, as well as adjustable noise reduction. There are also individual Aux and Mic inputs, and the latter has a dedicated Volume control, making it possible to get the right blend of guitar and vocals when accompanying prerecorded sources such as CD and mp3 players. The output amplifier may be switched between 5, 1.5, or 0.5 watts, enabling you to scale the volume for your needs, and to extend battery life when operating on battery power.
The DA5 can get remarkably loud considering its size, and its 6.5" speaker is just large enough to keep from breaking up (in the wrong ways) on all but the most extreme settings. The two Clean models are quite good, with one having slightly more Vox-y midrange edge, and turning up the Gain gives them both a bit of hair. Similarly, each of the three Blues, three Higain, and two Crunch models are voiced differently, providing distinct tonal variations—not just varying levels of gain. All of the more overdriven and distorted models sound better at lower volumes, but are perfectly acceptable even with the amp cranked up.
The effects section is quite ingenious, allowing you to access and adjust up to three parameters for each preset using a single knob. The primary parameter is the default or Edit 1, and you access Edit 2 and Edit 3 by pushing and holding either the Tap or Bypass buttons respectively as you turn the knob. Effect choices include single effects (auto wah, compressor, delay, and reverb), as well as combinations (compressor plus chorus or phaser; chorus plus delay or reverb; and flanger, tremolo, or rotary speaker plus reverb), and tempos for the modulation and delay effects may be set using the Tap button.
All of the effects are generally quite good, though some are a little noisy unless you engage the noise reduction circuitry. Of particular note are the flanger, which can get really wild; the very effective rotary-speaker simulator, which ramps up and down semi-realistically when you change speeds; and the delay, which can be used to create short, “infinite” loops when the regeneration is maxed. The Aux and Mic inputs worked well, and the sound through the headphones and the line out was even better, and quieter, than the sound produced by the speaker.
The DA5 is a truly remarkable little amplifier, delivering a taste of classic Vox tone at low volumes, and featuring enough effects and other goodies to keep things interesting. And while it may not cut it alone at a full band rehearsal, it pumps out more than enough volume to annoy—or even awaken—your neighbors should you so desire.
Specs
Old 05-06-2007, 05:19 AM   #10 (permalink)
GuitarGal's Avatar
Old 05-07-2007, 03:21 AM   #11 (permalink)
LoKi's Avatar
Send a message via MSN to LoKi
I've always enjoyed the Cube Series.
Nice sounding practice amp... I'd love to have one in the office.
I had a blues cube once upon a time as well, and it was stellar.
LoKi is offline   Reply With Quote
Old 05-08-2007, 12:14 PM   #12 (permalink)
GuitarGal's Avatar
Hope you will get one and have it in the office someday~
Old 06-04-2007, 05:05 PM   #13 (permalink)
I just picked one up for teaching, lots of fun. My 2 student's are at the same time, and I generally don't do acoustic.
Big Mike is offline   Reply With Quote
Old 06-11-2007, 11:18 PM   #14 (permalink)
Iceman0124's Avatar
VOX DA10 Digital Amplifier
Iceman0124 is offline   Reply With Quote
Old 07-01-2007, 06:21 AM   #15 (permalink)
lexluthier's Avatar
I've had a Micro cube since they came out, it's agreat little travel/practice amp. Toss some batteries in it, and you can sit on the beach (or wherever) and jam. Sometimes I wish the speaker was a little bigger, though. Doesn't sound too great pushing a lot of air.
lexluthier is offline   Reply With Quote
Old 07-01-2007, 06:37 PM   #16 (permalink)
I hook my DA5 to one (or both) of my MicroCubes for a really neat tone.
Alan is offline   Reply With Quote
Old 07-11-2007, 03:36 PM   #17 (permalink)
singlecut's Avatar
play mine out on the deck every night watching the sun go down.
very cool for the $
singlecut is offline   Reply With Quote
Old 08-01-2007, 10:17 AM   #18 (permalink)
lp junior freak's Avatar
that vox looks interesting
nahum 1:7 the lord is good a stronghold in the day of trouble
lp junior freak is offline   Reply With Quote
Old 08-01-2007, 10:25 AM   #19 (permalink)
Check out the new Roland Cube Street:
Roland U.S. - CUBE Street: Battery Powered Stereo Amplifier
and
Sonic State - News SNAMM07: Buskers Dream Amp, Roland’s new Cube Street amp offers big sound in a small portable package
and
Roland CUBE Street Battery Powered Stereo Amplifier :: Overview
Old 08-08-2007, 09:52 PM   #20 (permalink)
GLOBAL STOOGE MOD
YouTube - jammin rude mood/pride and joy out side on my micro cube
YouTube - MICRO CUBE CLEAN 1
Old 08-09-2007, 09:07 PM   #21 (permalink)
GLOBAL STOOGE MOD
YouTube - Canon Rock attempt
Old 09-04-2007, 01:15 PM   #22 (permalink)
lp59aholicDon's Avatar
ACCCCCKKKKKKKKK , No tubes?? you weren't induldging in any ah substances first, were ya Flick? LOL
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk
lp59aholicDon is offline   Reply With Quote
Old 10-04-2007, 05:26 PM   #23 (permalink)
GLOBAL STOOGE MOD
YouTube - Green day cover - Holiday
Old 10-05-2007, 01:46 AM   #24 (permalink)
coldsteal2's Avatar
Soundclick Songs ........ ColdSteal2's YouTubage Videos ........I left Myspace......
coldsteal2 is offline   Reply With Quote
Old 10-05-2007, 02:35 AM   #25 (permalink)
Hmm How many of those would ya have to stack to match the volume of a Marshall Mode Four ?
Old 10-05-2007, 06:58 AM   #26 (permalink)
coldsteal2's Avatar
I think that pile would just cover one 1960A cab hahah
Old 03-05-2008, 09:20 PM   #27 (permalink)
GLOBAL STOOGE MOD
YouTube - Roland Micro Cube Electric Guitar Amplifier
Old 03-05-2008, 10:04 PM   #28 (permalink)
Harpozep's Avatar
Still my favorite little am[p even with the Carr Merc in the house
It is what started me on the latest Gas round. Now I gotz a Micro, a Cube Street , Cube 30, and more. Silly amps, one cannot have enough of them
Another new stereo Cube was announced at NAMM, so I imagine it will be well worth trying.
Roland Micro Cube RX Battery-Powered Guitar Amplifier from zZounds.com!
"Ape Shall Not Kill Ape” Only 1,970 years until the Reign of Zaius!
I Use WB Pickups
"Trizzle Trazzle Trozzle Trome, Time For This One To Go Home!" http://www.sargescomics.com/
Harpozep is offline   Reply With Quote
Old 03-06-2008, 08:18 PM   #29 (permalink)
GLOBAL STOOGE MOD
YouTube - Johnny DeMarco shows the Roland Micro Cube RX
Old 03-12-2008, 09:43 PM   #30 (permalink)
GLOBAL STOOGE MOD
YouTube - Extreme Guitaring
VOX AD30VT vs. Roland Cube 30X jetsfan420 The Squawk Box 9 05-03-2008 02:40 PM
Just got my Roland Micro Cube Doctor Dread The Squawk Box 8 03-31-2008 02:52 PM
Vox Valvetronix vs. Roland Cube series amps needlespauls The Squawk Box 3 01-25-2008 03:16 PM
My next new amp, Roland Street Cube Harpozep The Squawk Box 6 12-08-2007 12:30 PM
Possible Problem with Roland Cube 30X NewtoyLPVM The Squawk Box 6 10-04-2007 12:21 PM
One of the largest message boards on the web !
