Unread 12-24-2008, 10:22 AM   #1 (permalink)
transtube amps???
Hi anyone know if the transtube amps are pretty good? The all tube amps cost a arm and left nut .... Try to get close to the ac/dc sound without going bank rupt... Anyways i got a angus young pickup on the way going to try it with my Roland 40 cube to see if i like the sound .. May end up getting a mashall solidstate...Thinking bout a Peavey Rage 158 15-Watt Transtube Amp also looking at a MARSHALL MG15CDR AMP any info. Thanks and merry xmas to all . and to all Rock On!
stealthdkm is offline   Reply With Quote
Unread 12-24-2008, 11:21 AM   #2 (permalink)
Belzeebub's Avatar
Re: transtube amps???
Im not sure if we are on the same page here, but AFAIK, transtube is an emulation circuit found in solid state amps from Peavey. I have a Peavey Audition 110 with transtube technology. This circuit is one of many out there that emulates the sound of a tube amplifier. Marshall on their SS amps have the FDD circuit. What FDD is supposed to do is to not only try and shoot for that tube sound but also the response of a tube amp to a musician's playing dynamics as well. Don't ask me how accurate these circuits are to the real thing as i have no personal experience with tube amps. Opinions on how accurate vary from person to person and as with all opinions, take each and everyone (including my own) with a grain of salt. The best i can recommend to you is to try it out for yourself in a store and see if you like it and suits you.
2008 Gibson Les Paul Classic Heritage Cherry with Guitarforce Vintage '57s
2010 Fender American Standard Stratocaster Maple Olympic White
2006 Epiphone Dot Cherry
2009 Taylor 214CE
Marshall JCM 2000 TSL602 60W 2x12
Epiphone Valve Junior combo
Acoustic AG15
Digitech RP1000
Belzeebub is offline   Reply With Quote
Unread 12-24-2008, 11:26 AM   #3 (permalink)
Belzeebub's Avatar
my personal opinion about how good it is is this: it gives pretty reasonable crunch for what it is. But do not expect Marshall Plexi or Mesa type overdrive. You will need pedals and then some to get close to those sounds. I can tweak the pre and post gain to achieve different levels and kinds of distortion as well as with the amp's EQ.
2009 Taylor 214CE
Acoustic AG15
Digitech RP1000
Unread 12-24-2008, 12:56 PM   #4 (permalink)
dont know alot about Tube Amp Modeler pedels . what do they do? i asume they plug between the amp and guitar. Recken this would help my couse any?
Unread 12-24-2008, 05:12 PM   #5 (permalink)
diceman's Avatar
I have a behringer vintage tube monster pedal - it sounds great, but I've only played it through tube amps. It is not quite as good as the onboard overdrive on my amps, but it helps.
I've been saying this a lot, but I paid less than $375 for both my Peavey Classic 30 and 50 - which is not prohibitively expensive, and is a much better amp than a similarly priced new SS amp. There just is no substitute IMO.
Unread 12-24-2008, 08:06 PM   #6 (permalink)
my advice would be to save your money,sell the roland, combine those funds and get a decent tube amp. the angus young pickup is only part of the equation. you wont go wrong with a classic 30. steer clear of the marshall mg ss stuff. what kind of guitar are you playing?
" why can't I own a plexi?"
randygt is offline   Reply With Quote
Unread 12-24-2008, 08:44 PM   #7 (permalink)
dwagar's Avatar
where are you playing? where do you expect to be playing over, say, the next year or two?
Don
Primary Tone: what the body and neck does not have cannot come out as tone - Iwanade, BOTB
Originally Posted by reswot
A 50's Special is, IMO, the coolest guitar ever made.
dwagar is offline   Reply With Quote
Unread 12-24-2008, 10:00 PM   #8 (permalink)
To the original question, yes Transtube amps are indeed "pretty good". However, your Roland is also "pretty good". I don't think any of the amps you mentioned are an improvement on what you have now. I'd suggest play what you have, keep your ears open, try to play with others and learn your guitar. Play different amps that your friends have and whats available at the music stores, and learn more. Try to learn details about different amps and why they sound different from each other. Work hard and save some money. After some time, when you have some money together if you've identified an amp that YOU'VE PLAYED that sounds the way you want then maybe take the plunge. Once you've done that, don't be surprised if a year later you've found things about that amp you're not as sold on and want a different one. You'll also find out there are other aspects - the guitar, the cord, the pickup, etc. that you want to change. Finally, you find out the most important part is YOU and HOW WELL YOU PLAY, no matter what you play through. Go back to square one, rinse and repeat. Welcome to the fun!
Monster is offline   Reply With Quote
Unread 12-25-2008, 04:59 AM   #9 (permalink)
Im playing a GB made in china . cheap guitar BUT>>>> it has a maple neck reinforced 3 single coil 5 way switch 2 tone 1 vol. looks like a strat. sounds ok for 40 bucks the body is bass wood or ply. OK will any tube amp work ?? how many watts like 10 or 15 watt be ok for living room??? I seen a Epiphone Valve Junior 5w all tube Amp Amplifier i dont know alot about them id haff to get a speaker for this one right??? is says it will handel 4 ohm 6 ohm 8 ohm . i guess a 5 watt speaker would be the best. theses amp speakers are high .. recken a car sterio speaker would work????
Unread 12-25-2008, 09:44 AM   #10 (permalink)
specflec's Avatar
As was previously stated, you will be best served to try many amplifiers with the guitar you play. You final choice will depend on how you play, what music you play, where you play and what makes sense to your ears. You will find worlds of difference in different tube amps so, no, not any tube amp will "do." The Valve Jr. might be a good place to start as it is quite inexpensive and has a pretty fair sound for what it is. But that is me speaking and has little to do with what you like and need.
Speakers are another factor and you will need to match your amp to an appropriate speaker cabinet. Or - and this might be your best bet - try out combo amps - speaker and amp in the same cabinet. Lots of great choices and they are easy to haul around - significant only if you are not a body builder.
Good luck and welcome to the forum! Listen to all these folks as they are experienced and will offer great advice. And, just a suggestion - make things easier for those of us reading your posts and use a spell checker. Thanks.
Alice says:
I'd play you some rippin' licks, but I don't have thumbs...
specflec is offline   Reply With Quote
Unread 12-26-2008, 09:45 AM   #11 (permalink)
Epiphone Valve Junior 5w all tube Amp Amplifier anyone know anything on this one????
