Unread 12-06-2008, 06:08 AM   #1 (permalink)
noelsoasis's Avatar
Amp Help.
Hi everyone, been a long time reader of these boards and i thought i might as well sign up and get in on the action
im going for a new amp set up, i really like the fender blues junior but i wanted to know if that could be hooked up to a couple of marshall 1960ax cabs? basicly im just using the fender as a head. would this work? any help is apreciated. cheers
noelsoasis is offline   Reply With Quote
Unread 12-06-2008, 11:24 AM   #2 (permalink)
stryker59's Avatar
Re: Amp Help.
the jr. is eight ohms so you theoretically run an 8 ohm cab from the amp like a head. the problem is that there are no speaker outs....
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Unread 12-06-2008, 08:17 PM   #3 (permalink)
noelsoasis's Avatar
Re: Amp Help.
can i use a a y adapter to connect from teh speaker output of the fender?
