Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 11-15-2008, 10:39 AM   #1 (permalink)
soloben347's Avatar
ohms help
Hey I dont know sqaut about ohms so basically im asking if this Peavey Classic 30 Head Tube Amp and more Guitar Amplifiers at GuitarCenter.com. can go into this Avatar Speakers the G212H DUAL VINTAGE 30 Closed Back one
thanks.
soloben347 is offline   Reply With Quote
Old 11-15-2008, 11:03 AM   #2 (permalink)
stryker59's Avatar
Re: ohms help
yes it will. the peavey is a 16 ohm head so make sure that cab is ordered in the 16 ohm version.
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Old 11-15-2008, 11:13 AM   #3 (permalink)
soloben347's Avatar
Re: ohms help
so I will have to get a custom version? cause the others are only 8 ohms
Old 11-15-2008, 02:06 PM   #4 (permalink)
Re: ohms help
Peavy website says 8 or 16. Most tube amps can run 8 or 16.
http://www.peavey.com/products/brows.../112-Tweed.cfm
996ttcab is offline   Reply With Quote
Old 11-15-2008, 02:12 PM   #5 (permalink)
soloben347's Avatar
Re: ohms help
yea but on the head version at guitar center it says into 16...theres no 8 Peavey Classic 30 Head Tube Amp and more Guitar Amplifiers at GuitarCenter.com.
Old 11-15-2008, 02:43 PM   #6 (permalink)
stryker59's Avatar
Re: ohms help
the owners manual states that the head is 16 ohms ONLY. as for whether you need a custom cab from avatar, just specify to them that the cab needs to be 16 ohms, there is no price difference as far as i know. it states on the avatar website that the cab is available in 4, 8, or 16 ohms. the best thing to do is to call avatar direct and find out what the options are.
Old 11-15-2008, 03:03 PM   #7 (permalink)
soloben347's Avatar
Re: ohms help
thanks
Old 11-15-2008, 03:04 PM   #8 (permalink)
stryker59's Avatar
Re: ohms help
Originally Posted by soloben347 View Post
thanks
Old 11-15-2008, 03:25 PM   #9 (permalink)
Re: ohms help
Wow, that sucks. You can probably just rewire the speakers, i.e., parallel and series to get the load correct if you cannot order to the specified load or you find a cabinet you want used.
Ohms.... Big_dawg The Squawk Box 16 08-22-2008 10:33 AM
OHMS.. can someone help me really quickly? nakleh The Squawk Box 7 07-02-2008 06:40 PM
Is a guitar amp load 2.2 Meg ohms or 47K ohms? Mitch Malloy Tonefreaks 0 03-29-2008 05:57 PM
question about speaker ohms!?!?!?!? tarddoggy The Squawk Box 9 03-06-2008 01:43 AM
p90 dogear ohms ? frrrrrrunkis Pickups 1 10-08-2007 08:05 PM
