Unread 08-18-2012, 02:40 PM   #1 (permalink)
Help for rookie: amp-cabinet match-up (Bugera V55)
Well I'm not on top when it comes to amp-cabinet match-ups. I've always used certain amps with their matched cabinets. Now I use a solid state Fender 100H with its 4 speaker cab.
However i have the chance to get a Bugera vintage 55W head but i cannot find a cabinet for it (live in Hungary). So my question is: Can i use the 55W head with the 100W fender cab? (my bet would be that any cab can be used which is equal or higher than 55W) The head has a resistance switch for 4-8-16 ohms the cab runs at 4 ohms, so i just switch to 4 ohms on the head and im ok?
Also how do these ohms work? What would happen if i played tru 8ohms and the cab would be only 4 ohms?
Thank you!
"Years from now, after I'm gone, someone will listen to what I've done and know I was here. They may not know or care who I was, but they'll hear my guitars speaking for me." Chet Atkins
2006 Epiphone LP Standard
2010 Epiphone LP Tribute (1960) Sold!
2011 Gibson LP Studio Faded
adamsvok is offline   Reply With Quote
Unread 08-18-2012, 08:24 PM   #2 (permalink)
Syrus's Avatar
Re: Help for rookie: amp-cabinet match-up (Bugera V55)
Thank you!
You can run the amp with a matching ohms or higher ohms.
On a tube amp, some say you run it lower/higer.
This all comes down to the iron or just in in plain English the transformer.
Basically, just match the ohms.
If you can't, I always go to a higher resistance. Never a lower.
For solid state it's true, going from 4 ohm to 8 ohm will mean half power cut.
This doesn't equally mean half volume, but you should just read up on that subject.
JUST MATCH THE OHMS.
I've run a 4 ohm champ with a 16 ohm load for years and haven't destroyed anything.
Also
2x the amp power is what you want in the cab.
As in max. speaker RMS power.
Syrus is offline   Reply With Quote
Unread 08-18-2012, 10:51 PM   #3 (permalink)
Thanks for your input!
