#32 (permalink) |
Re: YAMAHA THR-10 review!
with the 5, can you adjust the bass/Mids/treble using the software? or is the tone knob all you get there too?
'98 LP standard Charvel CX290 '06 SG g400 vintage AMPs: Blackstar HT5 too many pedals.
#34 (permalink) | |
so, I doubt it. Perhaps someone with a 5 will post a reply. |
#35 (permalink) |
All three tone knobs are available in Editor for the 5.
Regards, Jim More gear than talent (and that ain't saying much) |
#38 (permalink) |
No one has heard anything yet, that I have seen. I guess the 9/10 date listed on the now-removed YouTube video was wrong.
#40 (permalink) |
So, I actually ordered the THR10 over Labor Day, and received it on Monday.
I must say I really like the concept - a small lightweight portable bedside amp that also doubles as a really good iPod speakers. But I really do not like how it sounds with my guitars. I find the sound to be overly digital, very artificial. Although it processes the high frequencies very well - cleans are crisp and clear, while distorted high notes are nice and crunchy - the low frequencies come across as very weak and muddy and if you try to play a full chord, it just sounds 'off' because of this imbalance in frequency response (yes I did try all combinations of tone, pickup position, treble/mid/bass etc). I think it will work well as an acoustic amp or just for bright clean sounds, especially if you like your sound with a lot of modulation. For me I think the effects kick in a little too strong - just turn the Chorus knob up one tiny millimeter and you get drowned out in the chorus. There is no gradual in-between. TL;DR high end too bright, low end too muddy and too digital. I can get much better tones out of my Pod XT Live. Yeah I'm putting it back in the box to return it. I still think it is a great idea, and I might consider a future model if they are able to improve on it. |
#41 (permalink) |
I have the Thr10 and love it ... Ive played alot amps in 40 years but this one is a keeper my marshals and peavys, line 6 mostly sit unused . You guys think this little amp box sounds good. Well i moded mine..... install external speaker jacks now running through my costume 40 watt 16ohm 10inch skumbacks in stereo . the sound is incredible at 5 watts a channel this little amps sound like 50 ,friends can't believe how good it sounds. I can get sustain and feed back better than my marshal and at lower volume. Im not recommending anyone do this as it negates the 5 year warranty and Im a electronics tech but it was worth it. and a simple mod if your careful. People complain about no bottom end well with 6 ohm 2inch speaker what do you expect. add acouple of real speakers and well ....... with the exjack just unplug and your back to the stock sound. most worth while mod iv'e done. O yah plugin a set of studio monitors and you mp3 player and man what a sound. FYI Ok here are pics ![]() ![]() ![]() __________________________________________________ ______ If people want details on this mod I guess I could advise not sure this is the place to post that info. I will say that the key to this mod is finding a connector that matches the pc board speaker output connector . diden't want to cut or damage any internel parts. That said I was able to find a connector that worked in my pc parts supply. It.s a fairly standard 4pin connector. Also exjack locations are not the same on both ends as you have to account for the pc boards inside, it's a tight fit. need to be vary carefull take your time double check all your measurement before you drill any holes. If you do mod your THR unit be careful and make sure your external speaker are 6 ohms or more, remember ohms law about resistance/current. As I said I'm using 16 ohm/ 40 watt speakers and sound great. I recommend the THR10 it.s a little more money but the extra features are well worth it. The next mod is going to be a external foot-jack to access the user memory. I'll let you guys know. One last thing. The usb interface has a drie / wet out but most DAWs only let you select one to use. But with Harrision Mixbus Daw you can record wet and drie at the same time and that is real cool. opens up alot of possabilities .
#42 (permalink) | |
To each his own. Sorry it didn't work out for you. |
#43 (permalink) | |
#44 (permalink) |
I tried a THR10 earlier this month, and mannnn what an AMP!!! My favorite sound is the crunch channel with master cranked and gain adjusted to liking. It sounded very Marshall to me.
I love the master volume on that thing, the more I turn it up the more crunchy and full the sound gets. It seems replicate the power amp crunch pretty well, better that other modelling amps I tried doesn't seem to capture. I was sold just on trying the clean, crunch, and lead. I didn't even bother with hi gain sounds and all the FXs . I am normally straight into a crank Marshall guy anyway. For those who said it sounded thin and process, I suggest you crank the master and adjust overall volume via the knob labeled "guitar" on the amp. The overdrive and distortion do sound pretty bad at low master volume. The bad news is the 1st shipment that shipped to my country was sold. So I have to wait for 2nd shipment which is supposed to arrive in a week or two. Can't wait to try it with my Les Pauls. One more thing, this amp is supposed to sound pretty good as a hifi computer speaker as well. That is one neat application
2006 Gibson Les Paul Custom 57 Vos Black Beauty 1993 Gibson Les Paul Classic Goldtop 200x Epiphone Les Paul Custom, White Last edited by Smashing_tv; 09-26-2012 at 03:54 PM. |
#45 (permalink) | |
jwesdwin - your photobucket.com jpg links are not working.
Is there any way you could re-upload them and post the new links here? Looking forward to seeing your THR10 mod. Could you make a YouTube showing the mod in action and demoing the actual sound of the THR going through bigger external speakers? Thanks for your interesting and intriquing post! dattaa Quote:
#46 (permalink) |
I will get some pics posted and a youtube vid sounds like a good idea but
no time right now. Some good news I have the THR10 working in AVlinux 5.3 with a kernel mod. Getting a solid 5.3ms in Mixbus and the editor works in wine 1.4 . and Yamaha is coming out with 3 more models THR10C, THR10X, and THR5A . I will post some pics at AV Linux - Install...Create... forum. avlinux > need help with kernel build to get yamaha thr10 working Wes |
#49 (permalink) |
The headphone output is heavily limited and only puts out a % of a watt. A full 10w through headphones would damage your ears.
#50 (permalink) |
Yes, that makes sense. So, you could do that if going to a PA or other amp, but the power would not be enough to drive a speaker cabinet, which is what the jack mod is meant to do. The other amp or PA might color the sound so in the end, it might not be the THR10's voice.
#51 (permalink) | |
The headphone jack cannot properly power a basic external cab, the ext. speaker/s have to be a self-powered unit.
'48 Rickenbacher Bakelite 8 str. steel '50 Magnatone - Varsity 8 str. steel '55 Carvin dbl. 6 str. steel '05 DynaLap 8 str. steel '60 Magnatone - Mark V black, slab body '05 Mex Custom Shop Strat - Shoreline Gold '09 PRS SE Santana - black '09 PRS SE Soapbar II - maple top '95 Washburn - J-10 sunburst Magnatone - MP5, Magnatone - M10C, Gibson - 88S, Guild - Thunder Bass, Crate - Vintage Club 30, Webster-Chicago 375, Electromuse, Marvel - 35, MicroCube - RX, Yamaha - THR10 |
#52 (permalink) |
Yes, the headphone output is so low, it would not drive an extension cab correctly but you could take the headphone out to a PA or amp and it would work....would it effect the tone? Depends on what you're plugging it into. A super clean source would be best, like going straight into a PA. If you output the headphone jack to another guitar amp, it will color the sound to some degree.
#53 (permalink) |
A couple things to consider when you build a combo amp the speaker used are important. Now the 3inch speaker in the Thr10 are real good sounding for sure but this little amp was begging more. I had to hear it with 12inch pre rola's incredible. Micing the 3 inch speakers is not the same and the head phone jack into a P.A.not even close. with the external speaker jacks you can decide what kind of speakers you want and the sound. It's that simple. My scumbacks sound great. As soon as the Thr10c comes out I'll mod it too. I play the amp every day and love how it sounds.
#54 (permalink) | |
#55 (permalink) |
McDitto!
#56 (permalink) | |
Here's the link to the youtube vid which also has email details links to some pics. https://www.youtube.com/watch?v=QP3Ug3_hIrI Cheers, Mick |
#57 (permalink) |
btw, the THR10 is on sale again today at hello music for 219
if I had my tax money back I'd get one for a computer-amp
#58 (permalink) |
I just tried one of these out the other day, quite impressive for what it is. Granted its not my 100 watt rig bit it is certainly a GREAT practice amp. I have tried a bunch of the practice sim amps and was entirely unimpressed but this little thing was great and I know with some tweaking it would be an excellent unit.
#59 (permalink) |
yea, if I was shitting money I would pick one up just for a recording interface to the computer...
#60 (permalink) |
Im looking at it as a way for me to get back playing without the neighbors shooting me. In my old place I could play my hiwatt cranked and no one cared. The new place welll ummm that would be an issue.
