Like Tree14Likes
  • 3 Post By Batman
  • 1 Post By V2
  • 1 Post By River
  • 3 Post By TOMMYTHUNDERS
  • 1 Post By Syrus
  • 2 Post By Cygnus X1
  • 1 Post By TOMMYTHUNDERS
  • 1 Post By Deed J
  • 1 Post By rickym
Unread 04-22-2012, 07:01 PM   #1 (permalink)
Rocknburn's Avatar
Is modding amps hard?
Question is simple.I dont have any experience on modding amps.If i find some
Info at web do you think can i do it?I have got a cheap lil night train amp can i mod it?
Rocknburn is online now   Reply With Quote
Unread 04-22-2012, 07:57 PM   #2 (permalink)
Kyle76's Avatar
Re: Is modding amps hard?
I'm sure it depends on the amp. I'm getting ready to do the Billm mods on my Blues Junior. I hope it won't be too difficult. I haven't soldered any electronics since making a Heathkit digital clock about 30 years ago, but if I didn't think I could handle it, I wouldn't try it. I did buy a nice thermostat-controlled soldering iron to hopefully not fry my amp.
Kyle76 is offline   Reply With Quote
Unread 04-22-2012, 09:17 PM   #3 (permalink)
Dark Knight
Batman's Avatar
If you can follow directions, amp modding is not very difficult. Soldering is actually quite easy with a little practice and a good iron.
The hard part is understanding the theory behind what you are doing and learning how to work safely with the potentially lethal voltages that are present in amplifiers.
Before you start, you need to know how to drain the filter caps and use a DMM.
River, eddy999 and IndySouthPaw like this.
Rock and Roll. . .Guitars, Bass, Drums and Voice at high volume
Batman is offline   Reply With Quote
Unread 04-23-2012, 10:00 AM   #4 (permalink)
V2
V2's Avatar
If you learn safety, then yes, you can mod amps. Working on PTP circuits is probably going to be easier than PCB stuff, although I understand that the BillM mods are pretty simple.
Having said that, it is much more fun when you know the basics of amplification. There are some good books on tube amp design out there (and some not-so-good ones).
River likes this.
1997 Schecter Traditional, ESP Ltd
Traynor Mark 3, Phaez Daisycutter 10, HG18 Denogginizer
Barber Launch Pad, Super Sport, Ltd v2 with mod board
V2 is offline   Reply With Quote
Unread 04-23-2012, 10:02 AM   #5 (permalink)
River's Avatar
Can you solder? Can you discharge caps? Can you follow directions, meticulously? Do you have steady hands and the patience of a stalking cat?
Rhust likes this.
Unread 04-23-2012, 12:41 PM   #6 (permalink)
TOMMYTHUNDERS's Avatar
ignore the above advice.
modding amps is super easy! just flip that sucker over and start poking around with a screwdriver! something awesome will happen!
alligatorbling, River and Batman like this.
Cat do a bath salts.
TOMMYTHUNDERS is offline   Reply With Quote
Unread 04-23-2012, 12:46 PM   #7 (permalink)
Syrus's Avatar
How about, building a Fender Champ clone?
They come in kits and its a good way to learn which component does what and the whole amp as machine sort of.
Kits do tend do come with clear instructions and while I know its not a mod, it is the perfect way to getting to know an amp. Which in turn makes future modding a piece of cake.
Cygnus X1 likes this.
Syrus is offline   Reply With Quote
Unread 04-23-2012, 07:29 PM   #8 (permalink)
Gryphon's Avatar
I did most of the Billm mods to my Blues Jr. It wasn't easy, as no matter how careful you are, the PCB traces are easily broken and then you are into trace repair, which will test your soldering skills. For those determined to do it anyway, tips are:
1) Soldering iron tip size has to be small - a 'screwdriver' sized tip (the stock ones) isnt going to work out
2) Practice removing and replacing components with an old receiver , or something that uses a PCB
3) Get some sharp, small clippers to cut components off the PCB so you only have to try and de-solder the component stubs - DONT try to extract the component in one piece or you will bust a PCB trace sooner or later
And of course, when working on the amp, unplug it (!) then let it stand for 10 minutes or so, before opening it up and testing for DC volts between the + side of the biggest capacitors in there, and ground. Dont forget to do this, as 450v stored in a set of caps can kill you. DC is much worse than AC in that regard. The stored charge needs to be gone before you start work.
06 Classic Player 60s Strat
91 Les Paul Std (Ebony)
86 Yamaha SG1200S
91 Marshall JCM900 MkIII
Gryphon is offline   Reply With Quote
Unread 04-23-2012, 07:48 PM   #9 (permalink)
Cygnus X1's Avatar
Sure, funny, but not all know how to take this.
Some will actually do it!
I'll stay out of it, other than to say...READ, and read the safety warnings first and take them seriously.
We are flooded with idiotic warnings all the time ("Do Not Use this Device as a Hammer"...which is an actual tag I have from a brand new hammer...)
But the advice for safety with tube amps is REAL.
And deadly if done wrong.
5F6-A and eddy999 like this.
Cygnus X1 is offline   Reply With Quote
Unread 04-24-2012, 04:33 AM   #10 (permalink)
If you want to check out whether it is something for you or not, why not get a kit from Ceriatone (or another kit builder) and build one yourself? Granted, I may be full of it, as I tend to stay away from anything solderiron like so I never did it. But simple logic says you'd get a feel of what it means.
Loads of guitars! Signature limit doesn't allow me to list them all...
Line6 Pod 2.0
Randall RM-4 (DLX, Top Boost, Plexi, 1086)
Ceriatone Overtone HRM by Vernet Amps
Area51 Wah, Digitech Whammy, Keeley modded Ibanez TS-808, George Dennis Volume, TC Electronic Nova System, Dunlop Heil Talkbox
Nigel T. is offline   Reply With Quote
Unread 04-24-2012, 04:41 AM   #11 (permalink)
Syrus's Avatar
Sure.
It is impossible to go wrong with amps.
Going wrong in the sense to understand what you did wrong.
Can't happen. You'll be dead.
Muwhahahha
Boohoo
If you don't know what you are doing and you are a bit unsure. Well, you shouldn't touch em.
Unread 04-24-2012, 05:43 AM   #12 (permalink)
whoa.... mind = blown.
if you are not alive to see that you were incorrect about something, then you cannot truly perceive that you are incorrect, rendering the fact that you were incorrect totally irrelevant. As far as you are aware you were 100% right, and our perception is all that matters because it's all that we personally experience.
whoa.
River likes this.
Unread 04-24-2012, 12:49 PM   #13 (permalink)
Deed J's Avatar
You can start by reading some books about amps to understand how they work for instance. After that the sun is rising
River likes this.
"Just a shadow in a rock'n'roll sky"
Deed J is offline   Reply With Quote
Unread 04-24-2012, 02:01 PM   #14 (permalink)
rickym's Avatar
Only if you don't know what you're doing. Or what you want to get out of it.
Deed J likes this.
ShamRockers-1Up/Press Play On Tape-The Eric Clapton Social Group-The VOX club
rickym is offline   Reply With Quote
Unread 04-24-2012, 02:13 PM   #15 (permalink)
jfwund's Avatar
Blah blah blah safety don't shock yourself be careful, etc.
The important question is,
Cygnus X1, what were you supposed to use the hammer for?
One day you pick up the guitar & you feel like a great master, & the next day you feel like a fool. It’s because we’re different every day, but the guitar is always the same…beautiful. -Tommy Emmanuel
jfwund is offline   Reply With Quote
Unread 04-24-2012, 03:16 PM   #16 (permalink)
Cygnus X1's Avatar
I need to scan a picture of that hang-tag.
It's true!
