Unread 04-20-2012, 07:10 AM   #1 (permalink)
Fender Mustang I amp problems
I figured I would start a new thread even though i brought this up in my "what amp to buy" thread and wasnt getting responses.
Anyway I bought a Mustang I about a week ago and have been playing with my headphones on. With headphones on there are no problems, with headphones off here are the problems:
When I strum E and A separate on any fret the notes ring out perfectly fine. When strummed together there is almost a vibrationish muffled echo, the sound is hard to explain but sounds awful. I get this on any preset and if i raised the guitar volume or amp volume it was more apparent.
It happens on clean presets with no effects on or anything, so its not a delay or something. And the problem doesnt seem to happen on E B G, just D A E. And it happens on BOTH of my guitars, ibanez artcore and epiphone les paul
here is an audio clip:
mustang amp strings E & A by whitekeys26 on SoundCloud - Create, record and share your sounds for free
at first i hit E then i hit A, then i strum both together and you can hear the vibrationish bad noise i am talking about, the recording isnt the best but its all i have to record it on. Also at the end i just keep strumming a bit and you can hear it clear. this same noise happens on any and all presets
"I taught myself how to play the guitar, I taught myself how to play the drums, and I kind of fake doing both of them."-Dave Grohl
theWhiteKeys is offline   Reply With Quote
Unread 04-20-2012, 08:49 AM   #2 (permalink)
eddy999's Avatar
Re: Fender Mustang I amp problems
The fact that you don't get it over headphones pretty much rules out an electrical/circuit issue, leaving it likely to be mechanical.
It sounds like something is vibrating in the cab, or a speaker issue of some sort. You could either open it up and see if you can work out what's causing the vibration, or really as it's just brand new you can save yourself the trouble and just get it swapped for another.
Paul Edwards. See my site for info on all of my amp builds including my supplier list and useful learning resources etc.
eddy999 is offline   Reply With Quote
Unread 04-20-2012, 10:35 AM   #3 (permalink)
Syrus's Avatar
So what you are going to need is:
Step 1
1 Zippo
1 Gallon of Gas
Step 2
Pour gas over amp, make sure to adminster proper and even across surface of amp. Furthermore, get some of that fuel straight into the jack. The mustang loves it.
Step 3
Light Zippo
Step 4
Burn the motherfvcker
Step 5
Step 6
PROFIT!
Syrus is offline   Reply With Quote
Unread 04-20-2012, 10:37 AM   #4 (permalink)
Syrus's Avatar
Oh, and that just sounds like a bad speaker coil.
Had that problem too. Other amp, but same issue.
Unread 04-20-2012, 11:15 AM   #5 (permalink)
so this isnt common with other fender mustang amps? thats what my main question was.
I am just not sure if I got a bad amp, or if they just arent great to begin with and to either exchange it for another or return it and buy a completely diff amp
so any other mustang users have this problem?
Unread 04-20-2012, 07:55 PM   #6 (permalink)
rjwilson37's Avatar
If you strum a couple of bar chords even at a lower volume and it sounds all flabby, then you may just have a bad speaker. Take it back to the store and compare to the one of the floor, or if you purchased it online, just have them exchange it. It sounds like the speaker has a tear, even just plucking the strings alone does not sound too good.
Guitars
2011 Gibson Les Paul Studio Ebony Faded
2012 PRS SE 245 Black
2013 Chapman ML-1 Natural Finish
2013 Fender Telecaster Transparent Charcol
Amps
Blackheart Handsome Devil Combo w/Eminence Governor
Blackheart 1x12 Cabinet w/Eminence Wizard
Blackstar HT-5RH
Pedals
Boss SD-1
Boss ME-70
rjwilson37 is offline   Reply With Quote
Unread 04-21-2012, 12:44 PM   #7 (permalink)
i stumbled upon this forum/thread and seems to be a consistent problem with the mustang amps. this is very upsetting as i was just beginning to like my mustang amp! oh well
FenderŪ Forums • View topic - Obnoxius tail end distortion
Unread 04-21-2012, 07:03 PM   #8 (permalink)
rjwilson37's Avatar
The only time mine get's fizzy is when the fuzz pedal is engaged in the effects, so I just make sure it is never used. I only use the compressor for my effects on the stomp box side of things, I let the amp models handle the gain.
Couple of my clips with the Mustang III.
http://www.rj-zero.com/misc/guitars/...l_20120211.mp3
http://www.rj-zero.com/misc/guitars/...e_20111005.mp3
No fizz here.
http://www.rj-zero.com/misc/guitars/...l_20111001.mp3
Guitars
Amps
Blackstar HT-5RH
Pedals
Boss SD-1
Boss ME-70
Unread 04-22-2012, 08:51 AM   #9 (permalink)
cgm
cgm's Avatar
i read some of those threads from the fender forum... it looks like some people had some electrical interference, while others had issues with the hardware. even if it is just electrical interference, if the amp doesn;t work in the part of your house where you want it to, then it is not worth the hastle. did you bring it back to wherever you got it?
i just picked up a mustang 1 yesterday, so far i really like it. when i have time later on today, i will see if i have the same issue you have. i was playing mostly with the headphones last night, and i didn;t notice any fuzz. i will tell you, there sure are a lot of wires involved with this thing. it was a nice night, so i went on the back deck and was tangled in chords. i had a power chord for the amp, a power chord for the laptop, the guitar cable, the usb cable and headphones. i was shocked that i didn;t knock over my beer when moving everything around. now i think i will need one more cable... i wonder if i can conect the speaker out of my laptop to the aux in on the amp so i can listen to both the amp and lessons on justinguitar.com through the head phones.
i hope you figure everything out... this really seems like a great amp for us beginners who want a cheap way to play with all of the effects.
cgm is offline   Reply With Quote
Unread 04-22-2012, 09:48 AM   #10 (permalink)
so i took it back to GC and while they were processing the exchange I messed around with the mustang i on display and in no way shape or form could i duplicate the noise. the guy asked me what was wrong with mine i tried to explain it to him, so he took it out of the box and tested it out and knew something was wrong right away.
they were great swapped it with a brand new one and let me test it at the store to make sure everything was good. when i got home i wanted to do more testing so i noticed i almost got a similar reaction when turned to the amber, red, and green 59 bassman settings. i hooked it up to fuse and noticed it was the gain set at 9 which was causing it, i lowered it down to 6 and it goes away completely. This is not the issue i had with my first amp, but it was causing a slightly similar irritating noise (to me)
but this mustang is amazing
Unread 04-22-2012, 11:00 AM   #11 (permalink)
rjwilson37's Avatar
The presets that already come setup with the amp, most are not so good. I would hook it up to your computer and use the fuse software to download some or make your own presets. The Fuzz stomp box is just awful and makes this fizzy sound where you might think the amp has gone bad, but you take that Fuzz box out of the equation and it sounds just fine.
Guitars
Amps
Blackstar HT-5RH
Pedals
Boss SD-1
Boss ME-70
Unread 04-22-2012, 12:35 PM   #12 (permalink)
the fuzz seems to sound okay on the mustang i, i am a fuzz fan, you just have to tweak the settings in fuse and you can hit a sweet spot with it
