#1 (permalink) |
adding reverb to an old amp
I have an old Electar Tube 10 amp I picked up at a local pawn shop for $100. It's a nice little amp but I find it lacking in features. I want to add a reverb unit to it.
There are a couple of sites that sell kits reverb pedals and I thought I could add one inside the box with just the mix knob showing up on the faceplate. It has room for just one more knob. I'd use a pot/switch (the same sort for splitting a humbucker) for the control. Has anyone attemped to do this before? I know there will be the ones who say I shouldn't mod the amp - it's 'vintage' etc - but to me it is a 13 year old amp that didn't make greatness and deserves to be improved. I have found and printed out some mods for this amp and wanted some feed-back before I got started. Thanks for reading. Dan
Old guy collecting and playing guitars and amps. |
#2 (permalink) |
Re: adding reverb to an old amp
Most of the mods out there effectively just stick a reverb pedal into the amp itself. I just don't get that appeal. It's the same as using a pedal, except you've hacked open the amp, and jammed it inside the chassis. Too much time and money, too little reward. Just IMO and all, but I don't see the allure.
This post is the view of the author, and should be considered with all the usual acronyms implied, including, but not limited to, IMO, IMHO, IMESHO, FWIW, IIRC, and YMMV. In addition, whenever in doubt of the intent of the author, assume the presence of an appropriate smiley to imply that any questionable statement was not intended to offend. The author is not liable for anything stated in this or any other post. Thank you for your cooperation. |
#3 (permalink) |
![]() Join Date: Feb 2009
I say, go for it. It will be fun. As you say, it's not a museum piece. If you're up to it, you can add tube reverb with a tank.
Don Unencumbered by Knowledge Trapped inside this old man's body, is the mind of an old man www.dcsysinc.com www.seatrakinc.com |
#4 (permalink) |
Pedal Peddler
![]() Join Date: Apr 2010
Naw, do it right... get a spring tank and build a driver unit for it, something tube driven for more open sound and better overall effect!
#5 (permalink) |
Now if that's the direction you want to go, I can understand it a bit more. I just don't see any reason to stick a pedal in your amp, but if you want to add tube reverb, then you need a power source, and you're amp's already got that, so it does make more sense. A heck ton more complicated though.
#6 (permalink) | |
If you decide to do it and you promise to document it here, Ill donate a spring tank. just pay the shipping. Let me know.
God rides a Harley, and Plays a Les Paul ![]()
#7 (permalink) |
get a fender reverb standalone unit
![]() or just get the boss fender reverb pedal (not the deluxe reverb!)
'98 LP standard Charvel CX290 '06 SG g400 vintage AMPs: Blackstar HT5 too many pedals.
