Like Tree41Likes
Unread 04-09-2012, 09:20 PM   #1 (permalink)
Falconbill's Avatar
Tube replacement on Phaez JTM18
To kill time while waiting for my new Phaez (Jackel supposed to be delivered Wednesday), I figure I'd ask a dumb question or two. I've been going through the Phaez threads and noticed some of you guys have been playing around with replacing the preamp and power tubes, saying it makes a big improvement. Two questions:
1. Are the tubes that come with the Phaez amps something gimped in some way? With the obvious care that's taken in building these amps, it's hard to imagine that shitty tubes would be used to save a few dollars.
2. Is this amp a plug and play amp, or do you have to rebias it if you change the tubes. I know you have to stick with the same tube model numbers and that power tubes should be a matched pair. Other than that, is it plug and play with respect to different manufacturers?
Thanks in advance. Oh the wait . . it's the worst part.
Falconbill is offline   Reply With Quote
Unread 04-09-2012, 09:33 PM   #2 (permalink)
bufbills's Avatar
Re: Tube replacement on Phaez JTM18
Matched pair and pop em in. EL84s right?
The stock tube are Russian and chinese new production. Amp builders are selling amps, not tubes, so yes, using cheap tubes help keep the initial cost down. Look at it this way, the stock tubes will be fine. They will hold you over until you can research and find some better replacements.
Wednesday huh. Getting close! Youll have a great weekend with your new amp.
Enjoy.
Rhust and Falconbill like this.
God rides a Harley, and Plays a Les Paul
bufbills is online now   Reply With Quote
Unread 04-09-2012, 09:35 PM   #3 (permalink)
bufbills's Avatar
We were talking tubes in the "big" thread tonight. Last page.
Unread 04-09-2012, 09:51 PM   #4 (permalink)
WHEN IT COMES TO TUBES IN PHAEZ AMPS they are of good quality and the amp was voiced using these tubes ....there are more choices of tubes people lake to try to change the tone but the cost of some of these tubes would double the price of the amp,in some cases some players have a large collection of tubes to try .....THE AMP is ready just plug and play and enjoy.....JIM
kingedb, Chop'emDown and middy like this.
ANEAS is offline   Reply With Quote
Unread 04-09-2012, 10:30 PM   #5 (permalink)
Can you spec whatever tubes you want with Randy? It doesn't make sense that you buy a custom amp and then have to change out the tubes.
jw3571 is offline   Reply With Quote
Unread 04-09-2012, 10:49 PM   #6 (permalink)
MLP Vendor
alexb17's Avatar
IDK of Randy does that. He's in the amp building business not the tube business. Plenty of multi thousand dollar amps come with chinese tubes. changing tubes is just a part of life. Kinda like changing guitar strings. I'm always swapping tubes in and out. They can have a big impact on tone and everybody had their preferences. The ones that come stock sound great though. I wouldn't worry. My sibly came with JJs. I think they are a great production tube.
Royer R101 + Shure SM57 =
alexb17 is offline   Reply With Quote
Unread 04-09-2012, 11:05 PM   #7 (permalink)
Chop'emDown's Avatar
My Jackal sounded great with the stock glass. I just like the sound of some older glass better.
I happen to have a bunch of tubes and I like swapping them from time to time.
"This light is not my own..."
Phaez JTM18/Jackal
Phaez 10w Daisycutter
'78 Fender Vibro Champ
'11 Les Paul Traditional
'93 Les Paul Studio
Chop'emDown is offline   Reply With Quote
Unread 04-09-2012, 11:10 PM   #8 (permalink)
redking's Avatar
both of my Phaezs sounded great with the stock tubes, but an upgrade made them that much better.
bufbills and middy like this.
redking is offline   Reply With Quote
Unread 04-09-2012, 11:26 PM   #9 (permalink)
GP_Hawk's Avatar
My DC 14W woody still has the same tubes that came with it. Love the sound of that amp. Although now after so many years I'm thinking a pair of 6BQ5/EL84 Early Amperex Bugleboys
GP_Hawk is offline   Reply With Quote
Unread 04-10-2012, 02:25 AM   #10 (permalink)
onioner's Avatar
Doesn't it? Seems like that's the case with nearly every amp builder. As mentioned, they're not in the tube selling business. That's a whole 'nother ballgame, and one that takes time, and a pretty hefty investment. Stock tubes are fine. They're tubes, and they'll work, and the amp will sound great. Want it to sound even better? Start rollin' tubes.
And you can always do what I've done, and then get it without tubes. I just saw no point in having Randy put tubes in the Orion. I'll probably get tubes w/ the next one, but just 'cause I could use some more backups...
This post is the view of the author, and should be considered with all the usual acronyms implied, including, but not limited to, IMO, IMHO, IMESHO, FWIW, IIRC, and YMMV. In addition, whenever in doubt of the intent of the author, assume the presence of an appropriate smiley to imply that any questionable statement was not intended to offend. The author is not liable for anything stated in this or any other post. Thank you for your cooperation.
onioner is offline   Reply With Quote
Unread 04-10-2012, 05:36 AM   #11 (permalink)
Bartlett Retrospec Member
Deftone's Avatar
My new Phaez is coming w/o tubes. Randy Recommended JJ's. I've always liked them.
I use some vintage 12AT7 or 12AU7's in my DC and I think I still have the Chinese EL84's in my DC.
"If gun control is the path to public safety, then Chicago should be the safest city in the nation … right?"
-Led Zep Fan
Deftone is offline   Reply With Quote
Unread 04-10-2012, 06:01 AM   #12 (permalink)
bufbills's Avatar
I also order without tubes. Im a tube roller, and enjoy the process of finding the perfect combination for my ears.
Deftone and lespaul01 like this.
Unread 04-10-2012, 06:17 AM   #13 (permalink)
wrc73's Avatar
I changed the stock tubes out in my JTM 18 pretty quickly, and to be fair, I didn't give the stock tubes much of a chance. I have JJ's in it right now and it sounds great. I do plan to try some NOS tubes in the future. That being said, I am sure that the stock tubes are good quality, I'm just not a big fan of the 12AX7B preamp tubes, they are just a little to sharp on the top end for me. I like a little warmer preamp tube, but that is just my personal preference, YMMV.
Guitars:
2009 Gibson LP Traditional (Light Burst)
2000 Fender Strat (Black)
1933 Gibson L-00
Couple other cheap acoustics
Amps:
Phaez JTM 18
Phaez AFD 18 (Currently under construction)
Blackheart BH5H (Twang Modified)
Fender HRDLx (Omega Modified)
“I love scotch. Scotchy scotch scotch. Here it goes down, down into my belly.” — Ron Burgundy
wrc73 is offline   Reply With Quote
Unread 04-10-2012, 07:50 AM   #14 (permalink)
kingedb's Avatar
I held off swapping tubes for a long time because my Phaez's were great as is. Then I contacted John and he hooked me up with a batch.
I've yet to roll many, but the difference in just a couple I installed was nice. It's all personal preference. And it's all a balancing act. In my case the 6L6 and a couple preamp tubes I tried smoothened/fatten out the top end bite. Not necessary, but pleasing to my ears.
Since I've had a lot of time with this setup I was thinking of tossing the stock tubes back in and see what I think about the difference going back. Just to hear if my initial impressions were correct. The problem is I LOVE the tone. I'm in no rush to mess with anything.
EDIT: Sorry man I didn't realize your question was specific to a JTM. My MLP/35 (JTM) is stock right now. I swapped a few in my DC only, so far.
lespaul01 likes this.
kingedb is offline   Reply With Quote
Unread 04-10-2012, 08:35 AM   #15 (permalink)
coldengray's Avatar
Location: Connecticut Yankee in Queen Charlotte's Court
Swapping tubes is like swapping speakers - not necessary but fun to dial in different sounds.
Deftone, bufbills, ANEAS and 2 others like this.
Phaez JTM 18+
Scumback H75
coldengray is offline   Reply With Quote
Unread 04-10-2012, 09:20 AM   #16 (permalink)
Falconbill's Avatar
Good info. Thanks for the responses, guys.
Unread 04-10-2012, 11:34 AM   #17 (permalink)
There have been some who got their amp with no tubes because they have tubes they prefer to use ..I would get the stock tubes in ready to play and if you want later on up grade but this can be costly ....your choice ...JIM
Unread 04-10-2012, 01:26 PM   #18 (permalink)
Deftone's Avatar
Good gawd....do you know what this means? I get some NOS EL84's and my DC could sound even better?
-Led Zep Fan
Unread 04-10-2012, 01:30 PM   #19 (permalink)
onioner's Avatar
FWIW, my favorite preamp tubes for the DC have been the JJs. I haven't tried that many though, no more than ten. But, of the ones I've tried, I did prefer the JJs. *Shrug* Only time I've preferred a new production tube.
Unread 04-10-2012, 03:36 PM   #20 (permalink)
Deftone's Avatar
I like JJ's and Randy reccomends them. How about the EL-84's? JJ's as well?
-Led Zep Fan
Unread 04-10-2012, 03:59 PM   #21 (permalink)
onioner's Avatar
I haven't tried anything else yet. I'd like to, and I will. Just got to earmark the funds...
Unread 04-10-2012, 04:48 PM   #22 (permalink)
dennq's Avatar
I am lucky as I have the luxury of picking my amps up at Randy's place so when I drop off the deposit I have my tubes with me at this time.
This way my tubes are in the amp when I pick it up.
I guess you could ask if your amp be delivered without tubes as long as the power tubes are cathode biased like my Daisycutter.
My Dragonfly has a fixed bias but I have a Bias King so that made things easy there.
Don't matter on the preamp tubes just plug and play.
"If it floats, flys, fornicates or drives, it's cheaper to rent it"
http://www.phaezamp.com/ampshop/en/
dennq is offline   Reply With Quote
Unread 04-10-2012, 08:25 PM   #23 (permalink)
singlecut's Avatar
well i just tonight swapped out the vintage mullards on the lightning side of my new amp for sovtek's
sovteks win
who da thunk it.
hands down
they have been in a drawer for 5 years
Deftone and bufbills like this.
[SIGPIC]
singlecut is offline   Reply With Quote
Unread 04-10-2012, 08:33 PM   #24 (permalink)
sovteks win
who da thunk it.
hands down
I have a couple of Sovtek 7025/12AX7WA tubes that sound incredible. I had to pick through about 10 to get the two I've got but they are GREAT sounding preamp tubes.
Phaez JTM18/Jackal
'93 Les Paul Studio
Unread 04-11-2012, 12:07 AM   #25 (permalink)
GP_Hawk's Avatar
sovteks win
who da thunk it.
hands down
But still, the mullards might win another night, looking for a sound ya know
kingedb likes this.
Unread 04-11-2012, 05:06 AM   #26 (permalink)
bufbills's Avatar
Yep. I go back and forth between tubes a lot.
Unread 04-11-2012, 04:33 PM   #27 (permalink)
Falconbill's Avatar
Jim, I PM'ed you with a question.
Unread 04-11-2012, 04:50 PM   #28 (permalink)
JUST checked it >>>JIM
Unread 04-12-2012, 06:54 AM   #29 (permalink)
Grand Pappy's Avatar
I put all new JJ's (power and preamp)in my DC since I got it. IMHO JJ's are reliable, reasonably priced tubes and I like their tone
Grand Pappy is offline   Reply With Quote
Unread 04-25-2012, 06:16 AM   #30 (permalink)
bufbills's Avatar
I always end up back at Amperex for my power tubes
