MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > The Squawk Box
Like Tree5Likes
  • 1 Post By dlmorley
  • 2 Post By hipofutura
  • 1 Post By psc3
  • 1 Post By HRC
Unread 03-07-2012, 02:46 PM   #1 (permalink)
Pedal Addict
Batman's Avatar
Ampeg VT-22
Does anyone have any experience with the Ampeg VT-22 Combo?
I just picked up one (with assistance. . .it's a heavy b*$tard!) that needs some work; non-working reverb, no speakers and a loud hum when plugged into an external cab. It was only $140 so worst case I can gut it and use the working parts to start a 18-watt TMB project that I've been considering.
It's good to have certain restrictions sometimes, but it's definitely more fun to play really loud, with distortion - J Mascis
MacNab Number 1 and -1
Batman is offline   Reply With Quote
Advertisement
Unread 03-07-2012, 04:15 PM   #2 (permalink)
dlmorley's Avatar
Re: Ampeg VT-22
I had a VT40 (same amp but 4 x 10)
Great amp. MASSIVELY loud! The reverb is wonderful.
Guitars: Sid Poole LP, Sid Poole Telecaster, '81 Gibson LP, '91 CS Fender Strat, Jaydee Flying V, '81 Ibanez Lee Ritenour, '80 Ibanez PF-350, '86 Ibanez AH20, 1970's Hofner 477
Amps: Laney TT20, Laney Supergroup 50w, Kingsley Deluxe 30, Selmer Zodiac 30, Hughes Kettner Tube 20
FX: Kingsley Jester, Big Lloyde Tone Clamp, TC Alter Ego X4, Sonuus Wahoo
Facebook David Morley
dlmorley is offline   Reply With Quote
Unread 03-07-2012, 04:42 PM   #3 (permalink)
hipofutura's Avatar
Re: Ampeg VT-22
That's a very cool amp. I'd build a Fender BF style head cab and dump the combo. The slant face on the chassis screams for it. Then tweek it for more O/D. I wouldn't gut it as there's too much good stuff there.
Don
Unencumbered by Knowledge
Trapped inside this old man's body, is the mind of an old man
www.dcsysinc.com
www.seatrakinc.com
hipofutura is offline   Reply With Quote
Unread 03-07-2012, 04:49 PM   #4 (permalink)
Pedal Addict
Batman's Avatar
Re: Ampeg VT-22
Don - That's probably what I'll end up doing. I'd like to end up with an amp that gives me nice distortion without deafening me. The only thing that worries me with my relative lack of experience is diagnosing and fixing the hum issue; I can mod and tweak quite well but I'm no amp technician.
Unread 03-07-2012, 04:56 PM   #5 (permalink)
hipofutura's Avatar
Re: Ampeg VT-22
Tracking down hum can be a problem, but not always. The hum is the result of aging, so that eliminates a design/layout problem. The obvious sources are tubes and filter caps.
This amp, like some old Fenders, has a hum balance pot. It could be as simple as adjusting it. They did this because the PT didn't have a 6.3V CT. I'd strip the HB circuit and run a 100 ohm resistor to ground for both sides of the heater tap.
Don
www.dcsysinc.com
www.seatrakinc.com
Unread 03-07-2012, 08:05 PM   #6 (permalink)
Cygnus X1's Avatar
Re: Ampeg VT-22
Backing up Hip, probably due for filter caps and filament CT lift.
Death cap/modernizing the power section might be in order.
I can work on these but have no experience modding for more gain.
They take pedals so well I'd be wary of doing much in that area anyway.
Cygnus X1 is offline   Reply With Quote
Unread 03-08-2012, 03:05 AM   #7 (permalink)
Xavier_32's Avatar
Re: Ampeg VT-22
The guitarist in one of my bands plays through a VT-22. I've used it a bunch, too. I find that while the amp gets great natural distortion without going too loud, the problem is that it doesn't get loud enough for a medium sized venue without being mic'd. You keep turning the volume up, but instead of getting louder, the the volume stays the same and the distortion just gets gnarlier.
All that put aside, it DOES get some awesome distortion and take pedals quite well if you need more.
Bassist for Cab 20 and Future Shock
Originally Posted by blakem (in regards to Norlins) View Post
Mines done got sausage too! Maple, Pancakes and sausage!
From now on, mini humbuckers shall be known as sausages.
Xavier_32 is offline   Reply With Quote
Unread 03-08-2012, 04:19 AM   #8 (permalink)
EvLectric's Avatar
Re: Ampeg VT-22
Up until a few months ago I had a factory master volume for one, but lost it when I let a storage shed go. It was in a little reverb on/off looking box & plugged into the back of the amp. I would think you could probably find a schematic for it online somewhere & one of these guys could build it for you.
As far as it not being loud enough, that's a first for me. That thing was one of the loudest amps I ever heard in my life. It's probably the speakers maxing out rather than the amp. New high wattage speakers or a 4-12 cab should take care of that.
EvLectric is offline   Reply With Quote
Unread 03-08-2012, 05:34 AM   #9 (permalink)
Xavier_32's Avatar
Re: Ampeg VT-22
That's definitely a possibility. It still has the original speakers that came with the amp from back in the '70s, and as far as I know, it's never had any work done other than a tube replacement (with the default NOS tubes.)
Unread 03-08-2012, 05:47 AM   #10 (permalink)
dlmorley's Avatar
Re: Ampeg VT-22
A VT22 not being loud enough is new to me too! Massive volume. I'd say it needs a service!
TeaForTwo likes this.
Unread 03-08-2012, 07:50 AM   #11 (permalink)
Pedal Addict
Batman's Avatar
Re: Ampeg VT-22
Filter cap replacement is pretty straight forward. For the heater filaments I want to make sure I am on the same page as you.
On this amp there is no 6.3V CT, therefore to lift the CT I have to create a voltage divider like this where Vout = Vin*R2/(R1+R2). From the reading I have done, I have read both the first and last filter cap are good places to tap into B+. The argument for first is that this yields the least hum from the heaters feeding back into the B+. Where do you suggest is the best place to tap into B+?
Again, from my reading, the Vout spread seems to be somewhere between 20 and 50 volts DC from the B+ (plate voltage). What Vout value should I be looking for?
If I use the first filter cap (337V from the schematic) then it looks like the following values would work;
R1=100K
R2=10K
Vout=30V
Unread 03-08-2012, 07:56 AM   #12 (permalink)
hipofutura's Avatar
Re: Ampeg VT-22
I wouldn't bother with the voltage divider. I've had great results with just running a 100 ohm resistor to ground from the two heater winding taps. I do it at the pilot light.
Cygnus X1 and Batman like this.
Don
www.dcsysinc.com
www.seatrakinc.com
Unread 03-08-2012, 08:05 AM   #13 (permalink)
Pedal Addict
Batman's Avatar
Re: Ampeg VT-22
Sounds good; Thanks Don!
I hope to tear into this later today. I will post pics of what I find and start a parts list. Do you have a preference on filter caps or is this somewhat irrelevant to the overall tone?
Barry
Unread 03-08-2012, 10:21 AM   #14 (permalink)
psc3's Avatar
Re: Ampeg VT-22
A VT22 is a V4 (in combo form). This should be loud as thunder! There is a hum balance knob on the back. Get some work done on her and she will blow down walls.
Stan M likes this.
psc3 is offline   Reply With Quote
Unread 03-08-2012, 05:59 PM   #15 (permalink)
Pedal Addict
Batman's Avatar
Re: Ampeg VT-22
WOW! Once I got inside, this thing is a bit of a Rat's nest! Someone has been in here before. . .
It looks good from the front. . .
and the back. ..
Doesn't look too bad from the top. . .
But not so good under the reverb tank. . .
Although the mods and trace repairs are pretty obvious from the photo, the pre-amp tube sockets are all loose on their CB's and most of the pins of the power tubes are loose. I think this is going to require a fair bit of surgery to get it back to playable condition. I'm not sure I want to spend that much time and effort on an amp that is well louder than I'll ever need.
I'm looking for opinions; should I fix this up and sell it or use it as a donor platform for another build?
Unread 09-24-2012, 08:54 PM   #16 (permalink)
LesPaulCat33511's Avatar
Re: Ampeg VT-22
needs caps for sure
Plenty of cold solder joints there I'll bet
Might be the impedance due to one speaker is off, therefore your bias is off
Careful with that hum balance - do you know how to bias?
Mine is 42 years old and louder than anything anyone's got
Best tone EVER
Anyone hear back from him lately
Hope he didnt fry himself
Very dangerous amp to work on
Tome to die for
LesPaulCat33511 is offline   Reply With Quote
Unread 09-25-2012, 06:35 AM   #17 (permalink)
Pedal Addict
Batman's Avatar
Re: Ampeg VT-22
Hey Dude - Welcome to MLP!
I haven't had time this summer to do anything with this amp so it's parked in a corner waiting for me to have some spare time.
Unread 10-08-2012, 09:37 PM   #18 (permalink)
Re: Ampeg VT-22
Thanks Batman
I joined just to reply to you and your amp !
Mine is a 1970
Had the speakers replaced
Retubed a bunch of times
Nothing sounds like this
Super Loud and Clean
I wouldn't mod it if I were you until you got it to work right as it was designed to, and hear what it can do
I think John at the Tubesstore can help you find tubes and stuff
Also Bob at Eurotubes helped me revive this thing when the majority wanted me to mod it
Real parts are available
You will be amazed
Unread 10-08-2012, 09:54 PM   #19 (permalink)
HRC
HRC's Avatar
Re: Ampeg VT-22
I've had 3 VT-22's and they are louder than any other combo I've ever had. Something isn't right if a VT-22 isn't loud enough IMHO.
If You Can't Play 'em, Relic 'em
Bluesville Junction
The more you drink the better I sound
Vape-R-Holics - e-Cig and Vaping Forum
HRC is offline   Reply With Quote
Unread 10-08-2012, 10:02 PM   #20 (permalink)
The Guitar Whisperer
TeaForTwo's Avatar
Re: Ampeg VT-22
I also owned three VT-22s...Very loud amps, with great tone....
They're tanks, and heavy...
"We all have a choice to live or die, to keep trying or give up, we have to use the wealth of knowledge and experience gained from the struggles of the past to make a better future."..HOT-BRIT
"Ask not what MLP can do for you, ask what you can do for MLP."
Originally Posted by mdubya View Post
I don't like anything pure. I prefer my tone to be molested. Dirty.
That said, I don't have some ridiculous pedal board either. Just a couple to ensure everyone knows my tone is a whore.
TeaForTwo is offline   Reply With Quote
Unread 10-09-2012, 07:36 AM   #21 (permalink)
Re: Ampeg VT-22
Correct this old geezer's memory if I am wrong.....but did the Stones do U.S.tours with these in the early 70s with Mick Taylor ?
ezra1 is offline   Reply With Quote
