MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > The Squawk Box
Like Tree16Likes
  • 1 Post By lespaul01
  • 3 Post By tazzboy
  • 1 Post By kam4ff
  • 1 Post By nauc
  • 1 Post By nauc
  • 4 Post By Splattle101
  • 2 Post By rocknhorse1
  • 1 Post By Splattle101
  • 2 Post By Cygnus X1
Unread 01-23-2012, 07:25 PM   #1 (permalink)
nauc's Avatar
JJs vs Groove Tubes
so i need to change out my preamp tubes (12ax7) and this is my first tube amp and first tube change. i was thinking stock JJs or some Groove Tubes (mainly because theyre pretty cheap)
how do the 2 compare to 1 another. anything i need to know
thanks
Gibson Les Paul Studio (R.I.P.)
Peavey Classic 30 (R.I.P.)
nauc is offline   Reply With Quote
Advertisement
Unread 01-23-2012, 07:29 PM   #2 (permalink)
nicolasrivera's Avatar
Re: JJs vs Groove Tubes
thanks
In my experience JJ are a bit more bright and the overdrive is more defined.
I have about 6 tubes of each brand and i alway keep liking the JJ better over the GT's
nicolasrivera is offline   Reply With Quote
Unread 01-23-2012, 07:31 PM   #3 (permalink)
It will depend on the amp.. But, imo overall you are going to have more luck, tone wise, with JJ. The groove tubes are usually just relabeled sovteks or chinese..Some are actually JJ's too..
Lowdown likes this.
lespaul01 is offline   Reply With Quote
Unread 01-23-2012, 08:07 PM   #4 (permalink)
tazzboy's Avatar
Grove tubes are nothing more the re brand of current manufacture tubes that are made over seas and they are marked up in price.
Wraptail, Lowdown and lespaul01 like this.
tazzboy
tazzboy is offline   Reply With Quote
Unread 01-23-2012, 08:13 PM   #5 (permalink)
I use JJs in my Fender hotrod deville, Marshall silver jubilee and marshall JCM 800. Wouldnt trade them for GTs. Ive heard rumors of reliability issues but I have never experienced them. Also Eurotubes does a check on all the tubes to make sure theyre legit.
fairlanericky likes this.
kam4ff is offline   Reply With Quote
Unread 01-23-2012, 08:22 PM   #6 (permalink)
nauc's Avatar
sounds like im sticking with my JJs
thanks
tazzboy likes this.
Unread 01-23-2012, 08:23 PM   #7 (permalink)
nauc's Avatar
thanks
rocknhorse1 likes this.
Unread 01-23-2012, 10:30 PM   #8 (permalink)
Splattle101's Avatar
JJ is a manufacturer. They actually make the valves.
Groove Tube is a re-seller. They buy in bulk from manufacturers, test the product and, if they meet spec, label and sell them as Groove Tubes. GT is not the only re-seller out there. Ruby is another. TAD from Germany is another. There's another well known mob in the UK, Harma, and there's Watford, etc, etc.
Some of the tests the re-sellers do can include: peformance, lifetime, burn-in for reliability, microphonics, noise, etc, etc. Not all re-sellers test for the same things. Some also sell valves that are made exclusively for them by particular manufacturers. These are not just rebranded valves, they're actually custom order valves that you can't buy from anybody else. Some examples include the 6L6WGC-STR from TAD or the 12AX7M from Groove Tube.
Some manufacturers do some testing before sale. None of the current manufacturers do pre-sale testing on the scale that used to be done in the olden days. They can't afford to because the market's not big enough to support that sort of approach. This means current manufacture valves have a high % of duds that would've been weeded out by the pre-sale testing in the olden days. This means that if you buy a new Sovtek or JJ or Shuguang or whatever, you have a higher probability of early failure due to defect than in the good old days.
Re-sellers get around this problem for you by pre-testing. They weed out (most of) the duds. Some re-sellers test better than others, but the mark up you are paying is for a testing service. Caveat emptor.
If you buy a Groove Tube ECC83 / 7025, what you are buying is a tested JJ ECC83. It IS a JJ, so if you can get a Groove Tube cheaper than a JJ, the GT is better value because it's tested.
The sleep of reason brings forth monsters.
Splattle101 is offline   Reply With Quote
Unread 01-24-2012, 05:28 AM   #9 (permalink)
Lest my post above be misunderstood, I should point out that not all Groove Tube 12AX7s are tested and re-labeled JJs. Only the Groove Tube ECC83s / 7025 is a JJ. Their other 12AX7 valves are Russian or Chinese, usually with either an 'R' or a 'C' suffix in their Groove Tube designation (i.e., 12AX7R = a Russian valve, probably a Sovtek).
Unread 01-24-2012, 07:22 AM   #10 (permalink)
rocknhorse1's Avatar
Good post Splat. If I could add a couple of things.
I think the 12AX7M has been discontinued??? But I have seen it being sold on other sites as a "rare" tube now for as much as $40.
Also, didn't GT actually manufacture the 6L6GE here in the US for a while? That tube was made on NOS materials not used when the original GE6L6 was being made. So it's essentially an old tube made in modern times. I believe they also used the old tooling as well. I think they have also been discontinued, but you can still get them from a couple of dealers.
Splattle101 and Lowdown like this.
"Distortion, bless it's fuzzy woolen socks" Dave Hunter
"Yesterdays anger, is the sadness of today" Warren Haynes
rocknhorse1 is offline   Reply With Quote
Unread 01-24-2012, 07:28 AM   #11 (permalink)
JW123's Avatar
I recently got a set of JJs for my Triple Rectifier.
I actually got the whole set, but I was experimenting and found a couple of GTs I had gotten a couple of years ago. I put the GT into the V1 slot and think it sounds better to my ears than the JJs, now as explained above it may in fact be a JJ.
But the JJ set I got from Eurotubes sounds really good, I dont think you can go wrong with them. Good prices, and they did follow up when I had a couple of questions on tubes.
Good Luck
JW123 is offline   Reply With Quote
Unread 01-24-2012, 08:06 AM   #12 (permalink)
GitFiddle's Avatar
thanks
Nauc, I bought my Classic 30 a little more than a year ago and it came stock with JJs. They do a wonderful job and I've found no reason to change them out.
I rotate this amp along with a 64 BF DR and a 68 Drip Edge SR, depending on the venue, and have no complaints at all from the Classic 30. Its a little "hoss" with those tubes and an extern 1x12 cab hanging off it.
GitFiddle is offline   Reply With Quote
Unread 01-24-2012, 05:33 PM   #13 (permalink)
Originally Posted by rocknhorse1 View Post
...Also, didn't GT actually manufacture the 6L6GE here in the US for a while? That tube was made on NOS materials not used when the original GE6L6 was being made. So it's essentially an old tube made in modern times. I believe they also used the old tooling as well. I think they have also been discontinued, but you can still get them from a couple of dealers.
They did indeed. I have a pair of these and they're good.
I understand that they moved some of the manufacture of that valve to China. So it's still made on the old General Electric machines and using their old stocks, but done in China. I don't know how much of the process went to China, and how much stayed in the US. GT themselves still claim this valve has a high US-made content.
I didn't know about the Groove Tube 6L6GE being discontinued, though.
Unread 01-24-2012, 05:40 PM   #14 (permalink)
SWeAT hOg
northernguitarguy's Avatar
FWIW, my TCW, for the most part I've never used any other tube than Electro-Harmonix and have had nothing but great tones and reliability out of them
2012 Gibson Les Paul Junior Special * 1980 Kasuga 'Northern' LG-770V Custom
2008 Yamaha RBX374 * 1993 Yamaha FG 411 VS * 1989 Yamaha 'TexMex' Pacifica
Amplifier: VOX Night Train 15H / Orange Tiny Terror w/ Radial Headbone VT
Free your mind, and your ass will follow.-George Clinton
northernguitarguy is online now   Reply With Quote
Unread 01-24-2012, 05:48 PM   #15 (permalink)
I've had some issues with eh in terms of sounding too bright in my amps specifically the JCM 800. I had them in my hot rod but I me they have no hold on jjs.
Unread 01-24-2012, 06:03 PM   #16 (permalink)
AngryHatter's Avatar
Talking Re: JJs vs Groove Tubes
ALL tubes are rebranded russian or chinese stuff. No US made tubes since the early 70s.
AngryHatter is offline   Reply With Quote
Unread 01-24-2012, 06:38 PM   #17 (permalink)
Koop's Avatar
Well, yes. But they're not all rebranded. Some actually have the manufacturer name (i.e. Shuguang).
Koop is offline   Reply With Quote
Unread 01-24-2012, 07:08 PM   #18 (permalink)
Cygnus X1's Avatar
USA
Richardson Electronics, LaFox, IL
Makes a 300B, 845 and 50 sold under the Cetron brand for high-end audio, as well as a KT88 sold under the National brand. Richardson has large quantities of tooling obtained from old American tube factories when they shut down. Also makes some larger transmitting and high-voltage types. Richardson markets many tubes, obtained from other factories worldwide, under their own brandnames; such as Cetron, National and Amperex.
Westrex Corporation, Kansas City, MO
Makes the reissued Western Electric 300B for high-end audio. Claims to be developing a KT88, WE308, WE274A and other old WE types for future manufacture. Corporate and sales offices are located in Atlanta and Chattanooga. Also has sales office in UK. Tube manufacturing facility was relocated from Kansas City to Huntsville, AL. This firm is independent of AT&T Corporation and has licensed the brandnames from AT&T.
MU, Oceanside, CA
Small contract factory, makes occasional runs of unusual glass and metal-ceramic tubes for military use. Still makes some of the old "Bendix Red Bank" tubes, such as the 6094 and 6384, in occasional lots.
Triton Services ETD, Gaithersburg, MD
Makes some Eimac and Litton glass power types, using equipment from the original manufacturers. Recently discontinued some glass types, such as 4-65A, 4-125A, 250TH, 304TH/TL, etc. (these types are now only available from China).
rocknhorse1 and JCarno like this.
Cygnus X1 is offline   Reply With Quote
