Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 09-27-2007, 07:57 PM   #1 (permalink)
Possible Problem with Roland Cube 30X
Good day. My amp has developed a hum when a guitar cord is attached. It disappears when I touch the metal part of the cord. Its also there when there is a guitar attached and disappears when I touch any metal part of the guitar. I have replaced the cord and the hum is still there. I tried my guitar with my friend's amps and no hum, so it's not the guitar and not the cord. Maybe it's operator error? What's the ideal volume, gain, etc., setting for practicing at home. Thank you so much.
NewtoyLPVM is offline   Reply With Quote
Old 09-29-2007, 11:36 PM   #2 (permalink)
MIDNIGHT's Avatar
Re: Possible Problem with Roland Cube 30X
hmm.. good question newtoy
sorry i don't know the answer though.. .. happened to me with my amp back in the Philippines.. it's broken now.. .. i was just careless.. knew nothing about amp settings, etc.. basically, when i wanted it loud then i'd just turn up without restraint.. not a bright idea
Actually...
... I'd play for free ...
MIDNIGHT is offline   Reply With Quote
Old 09-30-2007, 12:21 AM   #3 (permalink)
lp59aholicDon's Avatar
sounds like a possible ground problem somewhere in your amplifier, does it have a working three prong plug? increase in gain settings may make it even louder yet
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk
lp59aholicDon is offline   Reply With Quote
Old 09-30-2007, 06:02 PM   #4 (permalink)
You're probably right. It came with a two-prong plug and the hum increases as you turn the volume up.
Old 10-01-2007, 12:31 AM   #5 (permalink)
Rock Star
coldsteal2's Avatar
just turn the power plug around and it will reverse the polarity
...........Cold Steal II Soundclick Songs ................. ColdSteal2's YouTube Videos.............MusicMight Secret Service
Still Rockin' at 56
coldsteal2 is online now   Reply With Quote
Old 10-02-2007, 04:23 AM   #6 (permalink)
Possible also in handling or moving an internal ground wire has come loose or broke
another thing that can give you alot of hum in high gain amps is if you are playing under flourescent lighting
Old 10-04-2007, 01:21 PM   #7 (permalink)
LoKi's Avatar
Send a message via MSN to LoKi
Have you ever bent or moved the cord violently while it was plugged into the amp? An input jack is made out of cheap, cheap metal and if its not getting a solid connection, could cause a buzz or hum.
Most often the source of hum in an amp is electronics around or on the same circuit as the amp, lighting, or the guitar itself. But input jacks are CHEAP if thats all it is, and can be replaced in about 5 minutes with a soldering iron and a screwdriver and a pair of pliers.
LoKi is offline   Reply With Quote
Roland Micro-CUBE FLICKOFLASH The Squawk Box 40 07-02-2008 04:53 PM
VOX AD30VT vs. Roland Cube 30X jetsfan420 The Squawk Box 9 05-03-2008 03:40 PM
Just got my Roland Micro Cube Doctor Dread The Squawk Box 8 03-31-2008 03:52 PM
Vox Valvetronix vs. Roland Cube series amps needlespauls The Squawk Box 3 01-25-2008 04:16 PM
My next new amp, Roland Street Cube Harpozep The Squawk Box 6 12-08-2007 01:30 PM
