MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > The Squawk Box
Like Tree7Likes
  • 5 Post By randelli
  • 2 Post By randelli
Unread 09-27-2011, 07:28 AM   #1 (permalink)
GrouchyDog's Avatar
Blackface "Death Cap"?
Can someone tell me what the "death cap" is on Fender blackface amps? Seen a few recent references to it, but I don't know what it is...
<img src=http://www.mylespaul.com/forums/members/grouchydog-albums-profile-sig-pics-picture41749-drz-circle.html border=0 alt= />
GrouchyDog is offline   Reply With Quote
Advertisement
Unread 09-27-2011, 07:34 AM   #2 (permalink)
randelli's Avatar
Re: Blackface "Death Cap"?
There is a capacitor on the AC power that connects the white wire to ground. Just snip it out
I was surprised to find one in my 80's three prong vibro champ - not just limited to old 2 prong designs I guess!
randelli is offline   Reply With Quote
Unread 09-27-2011, 08:35 AM   #3 (permalink)
GrouchyDog's Avatar
Thanks!
What was its intended purpose? My understanding is less than rudimentary, but why would you connect the wall power to ground? Wouldn't that make the whole chassis live?
Unread 09-27-2011, 08:53 AM   #4 (permalink)
randelli's Avatar
Here is a good explanation: David Lamkins - Guitarist - Ground switches and "death caps"
"Ground switches and "death caps"Ground switches and "death caps"
This is probably more than you ever wanted to know about ground switches and "death caps"...
In the US, conventional power outlets have one side of the line at ground potential and the other side connected to the "hot" lead. The ground switch works by creating a high-impedance connection, through the grounding or "death" capacitor, between the chassis and one side of the AC line. The "correct" connection attaches the capacitor to the grounded side of the AC line, thus putting the chassis at ground potential for AC frequencies.
The cap really was necessary; without it, leakage currents (mostly from the power transformer) would put some small amount of AC voltage on the chassis. With the entire circuit floating up and down on the AC voltage, a certain amount of imbalanced voltage would get injected into the circuit and cause hum. The cap simply shunted the chassis voltage to ground, greatly reducing the magnitude of the voltage and reducing hum.
The ground switch itself was a convenience. Most products of the era had the cap without the switch; you'd have to reverse the AC plug in the outlet to get the proper connection.
All this came about because grounded outlets, although available, were not required by the electrical code until sometime in the `70s, I think. Grounded outlets were preceded by polarized outlets which had one prong wider than the other. A matching polarized plug could only be inserted one way. For backward compatibility, a non-polarized plug could be inserted either way. Before that, of course, both plugs and outlets were non-polarized (and ungrounded). Now that we have grounded outlets almost everywhere, the function of the ground cap has been replaced by a direct connection from the chassis to the safety ground through the round pin of a 3-wire plug.
The "death cap" appellation is fairly recent. My cynical side says that the name was probably invented to drum up business for amp techs... The name is appropriate, even if it does overstate its case. What can happen is that the capacitor can fail shorted which allows it to pass DC. That's like wiring the chassis directly to the AC line, which is a lot like sticking a finger into one side of the AC outlet; you have a 50/50 chance of getting zapped.
The cap may fail shorted due to manufacturing defect (rare) or dielectric punch-through. A capacitor is made of two strips of metal separated by an insulator, or dielectric. The dielectric is rated to withstand a certain amount of voltage. Higher voltages may breach the dielectric. The grounding cap is subjected to line voltage when not properly connected (switch or plug in the wrong position). Line voltage is nominally 120 volts AC (now; it has crept up by a few percent over the decades) and a properly-manufactured and rated cap will tolerate that for many, many decades. However, AC line voltage is not "clean"; it's host to much higher spike voltages that happen when motors get switched off or when there's a nearby lightning strike. A high-voltage spike can punch through a weak spot in the dielectric material, burning a tiny permanent hole and - via carbonization or welding of the electrodes - create a DC path through the capacitor.
Now, getting zapped with the full 120 volts is unpleasant (I can vouch for that) but not universally fatal (ditto). It happened a lot in the days when vacuum tubes could be purchased at the corner store, and very few people died from the experience. Guitarists, though, are at greater risk than the general public because they have a firm grip on a piece of metal connnected to the chassis. If that grounding cap fails shorted and the grounding switch (or plug) is set wrong, the unlucky guitarist is going to be connected to the AC line. Assuming that the guitarist is wearing non-conductive shoes and not touching anything else, he'll notice a buzzing sensation which may range from noticeable to somewhat unpleasant. At that point, touching any grounded piece of metal - say a microphone - completes the path. If the path of the electricity through the guitarist's body happens to involve the heart, we end up with a "late, as in departed" (gratuitous Douglas Adams quote), guitarist.
I developed a set of habits which have protected me from getting zapped. I always wear non-conductive shoes, use one hand to turn on an amp (with the other hand not touching any metal), and run a knuckle across the faceplate to see whether there's any buzzing sensation. The knuckle test, for some reason, is more sensitive than just touching the amp and is safer because you don't have a grip on anything.
On a closing note, let me add that a three-wire cord provides no guarantee of electrical safety. It's possible to encounter a miswired outlet which can either leave the ground floating or - even worse - connect the safety ground to a voltage source. Get one of those three-light grounded-outlet testers and use it before you plug in your amp at an unfamiliar venue. And if you'll be touching any gear other than your own rig, give it a "preflight" check using the knuckle test."
Unread 09-27-2011, 10:31 AM   #5 (permalink)
GrouchyDog's Avatar
Thanks - much appreciated!
Unread 09-27-2011, 10:43 AM   #6 (permalink)
st.bede's Avatar
thank you randelli
"to criticize without vision is to be complicitious with dominance" Carolyn Casey
"There is no hierarchy of goodness" Des
"Two kinds of karma, instant and full perk. Both will keep you up."
kevinpaul
st.bede is offline   Reply With Quote
Unread 09-28-2011, 08:04 AM   #7 (permalink)
randelli's Avatar
Actually, Thank You GrouchyDog!
I have wondered the same thing but never took the time to find out for myself. GrouchyDog inspired me to find out; so I posted it here I learned something too...
Just a beggar telling another beggar where to find bread
Quill and nutsauce like this.
Unread 09-28-2011, 09:28 AM   #8 (permalink)
LeftyF2003's Avatar
I keep a ground tester and a simple plug in voltage meter in my gig bag and test the outlets in any new venue before I'll plug anything in. It saved my a@# at an outdoor show years ago where someone had converted a 220 line to standard 3 prong in the upper lighting rack and dropped a line to the stage. That would have been the end of both guitar amps if I'd not checked it! Surprisingly I've only found one outlet in a club with an open ground. I guess the electrical inspectors are doing their jobs!
LeftyF2003 is offline   Reply With Quote
Unread 09-28-2011, 09:46 AM   #9 (permalink)
GrouchyDog's Avatar
Originally Posted by LeftyF2003 View Post
... someone had converted a 220 line to standard 3 prong in the upper lighting rack and dropped a line to the stage. ...
I dunno a lot about electricity, but
Unread 09-29-2011, 12:03 AM   #10 (permalink)
Rather than use a knuckle, how about using a portable RCD protected outlet (you guys might call them something different). Probably an idea for guys gigging around the place.
Like this.
Portable RCD Power Board - Double Outlet 10amp | eBay
Triangle Going Sick is offline   Reply With Quote
Unread 09-29-2011, 02:30 AM   #11 (permalink)
gibsonguitar1988's Avatar
Thanks for the info Randelli.
I've been shocked by an old Gibson vintage tube amp... And yes, it hurt like a mother. It was a two prong no ground amp and I didn't know jack about amps at the time (it was right after I started playing and I bought this amp for cheap and it had lots of issues and ultimately sold it) and I touched both my guitar strings and my iPod plugged into another speaker set at the same time (finding a backing track) and BAM! I screamed bloody murder. I couldn't sell that POS fast enough.... I still have nightmares about that amplifier. It was a TRUE POS. Cut in and out, would have static electricity problems, you name it. I think the guitar I was playing at the time also had bad grounding issues so that could have been a part of my "shocking" experience.
Obviously now that I'm older, smarter, and that I own a NICE vintage amp ('68 Fender Super Reverb but with the Blackface AB763 circuit), I know to have that stuff taken care of so when I bought the amp (I got it for a steal at an auction out in the country where no one knew what it was after seeing it in a paper ad and I got it for $500 bucks) I had them remove the death cap and change the cord (not just the plug) to a brand new three prong cord (as well as retubing, cleaning, cap change, etc). Well worth it. Vintage amps are nice but if you don't get them modernized in the safety department you are asking for trouble IMO.
gibsonguitar1988 is offline   Reply With Quote
