#1 (permalink) |
Does this amp exist?
Help me out here, but I haven't found it yet:
2 channels, footswitchable. 2 separate EQ, one per channel. 2 separate reverb controls, one per channel. 2 volumes, 1 master volume. Clean channel: absolutely clean, Blackface voice. OD channel: medium gain, like a cranked '57 Champ. Tweed voice, in any case. Preferably in 1x12" combo version, or a just head. No big combos. Power: not more than 15-20W. Does anyone know anything in this configuration? The closest I've found is the ToneKing Metropolitan. Thanks! |
#2 (permalink) |
MLP Vendor
![]() Join Date: Jul 2008
Re: Does this amp exist?
My RUDE MOOD has:
2 separate amps (sides), blend-able. 2 separate EQ, one per side. 1 reverb on the MOOD side. 2 volumes, ones per side. Clean channel (MOOD): absolutely clean blackface voice with tremolo and reverb. OD channel (RUDE): slight clean to plexi/hiwatt and beyond with master volume. 2x10" combo version, head version (needs stereo cabinet), 4x10 combo version. Power: dual 20W amps. Weight: 45 lbs. Check out my link below for more info.
I never look at the drummer; it only encourages him ~randelli ![]() Website:www.RudeMoodAmp.com Questions:randy@rudemoodamp.com YouTube:www.youtube.com/user/RudeMoodAmp Facebook:www.facebook.com/RudeMoodAmp Twitter:www.twitter.com/@RudeMoodAmp |
#3 (permalink) | |
#4 (permalink) |
Mesa Boogie Express 5:25 1 X 12. The only thing it doesn't have is a master volume, but each channel has its own. Every other spec you listed it meets.
-Matt '12 Gibson LP Standard Trans Amber/'12 Gibson LP Traditional Mahogany Worn Brown '11 Gibson LP Custom Shop R0 VOS Southern Sunset Burst/'11 Gibson LP Classic Custom Antique Natural '11 Gibson LP Studio '60s Tribute Darkback Vintage Sunburst/'10 Gibson LP Traditional Pro Goldtop Darkback '10 Gibson LP Custom Shop 50th Anniversary R0 VOS Cognac Burst/'08 Gibson LP Custom Shop G0 VOS Dark Burst '07 Gibson LP Classic Custom Ebony/'07 Gibson LP Classic Antique Honeyburst |
#5 (permalink) |
Ah yes, I've looked at the the 5:25. However, MV is one of the essential features on my list.
Thanks for taking the time to reply, TD! |
#6 (permalink) |
Mesa Heartbreaker
Has gain and master on each channel + global Master, seperate EQ, footswitchable, individual reverb controls. Also has two different modes on each channel, half power option, can run on EL34, 6L6, or 6V6 tubes, and has solid state and tube rectifiers.
My Band -- The Crazy Ivans -- http://www.thecrazyivans.com -- http://www.myspace.com/yecrazyivans -- http://www.facebook.com/pages/The-Cr...ns/64003346609 |
#7 (permalink) |
How bout an Egnater Renegade?
65-Watt All-Tube Amp Two Independent Channels Each With: * Volume, Gain, 3-Band EQ * Tight and Bright Voicing * Switches * 18w / 65w Wattage * * Selector Switch • Tube Mix Blends 6L6 and * EL34 Power Tubes Master Controls: * Presence & Density * Individual Reverb on Each * Channel with “Spillover” * Main and Secondary * Master Volumes * Simple Master Bias Adjust * with External Test Points Buffered Effects Loop Four-Button Footswitch with Channel Select Plus: * Assign the REVERB, * * EFFECTS LOOP and MAIN * 2 Volume to Just Channel * 1, Just Channel 2 or Both * - Right From the Pedal Balanced XLR Cabinet Voiced Line / Recording Output 100V / 115V / 230V Voltage Selector
****************************** 2011 Gibson Les Paul Studio 1987 Gibson Les Paul Custom Lite 1979 Fender Stratocaster 2011Rickenbacker 620 Lots of Vintage Kramers Egnater Rebel 20 Egnater Renegade ****************************** |
#8 (permalink) |
The (discontinued) Pro Tube Reverb meets all of the requirements except for a single master volume and separate reverbs. It's not big - just heavy.
#9 (permalink) |
I just noticed that, by compromising on a couple of non-essential features, I'm left with a Fender SuperSonic 22.
(edit: SuperSonic, not ProSonic) Last edited by LouieTM; 08-08-2011 at 12:40 AM. |
#10 (permalink) | |
![]() I'm told mine's overweight due to the transformers.
#11 (permalink) |
Why are you limiting your choices to the 15-20W range? The Genz Benz El Diablo 60 meets all your qualifications except that it has a max of 60W. BUT it has a triode switch that takes it down to 30W, and that's where I always leave mine.
Plus, these things in heads and 1X12 combos have been going very cheap NEW from music stores. Like $500 -$600 on ebay. They used to have street prices of $1150 to $1300, and I have no idea why the deals are there on ebay (if you look for them for a while). But you can find one if you look for a while. To my experience, it's all worth it.
'62 Gibson LP SG Standard '09 Epi Goldtop LP P 90 Two Carvins Custom Strat Electra Strat type Hondo Longhorn Durango Guitar Works "Contender" (ask me about this one!) Sterling SUB AX3 (ask me about this one too) PRS SE "Orianthi" Genz Benz El Diablo 60 TS. Bugera V22 |
#12 (permalink) |
Good question.
Well, because I don't need copious amounts of headroom, and my '65 Deluxe Reverb reissue has more than enough already at 22W. I rarely play absolutely clean anyway. Even if I did the smallest of gigs, I'd still probably be micing the amp, so in all fairness even 12-15W would be enough. Another reason is the lack of a roadie, so "portability" is a big plus. Again, I've been spoiled by the lightweight '65 DRRI. Going back to the SuperSonic 22: it seems that it's been developed from the Deluxe Reverb platform, with an added higher gain channel. |
#13 (permalink) | |
