Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 08-05-2008, 10:00 AM   #1 (permalink)
Bordeaux's Avatar
Peavey Delta Blues 210 feedback issue.
Hello all,
Last night I fired up the ole Peavey amp and noticed a dull hum, the longer the amp stayed on, the louder the hum grew. So, I unplugged and tried a different outlet. Same issue, so I tried switching to the dirty channel, same thing. So I did a little investigating and I figured out what was causing all the noise. My reverb was cut up to 10 and as I slowly dailed it back the hum died down. Now, of course I never have my reverb that high (not sure how it got there to begin with). I normally keep it at 3 or 4 wich pretty much eliminates MOST of the hum.
I have never noticed this hum before last night and I havn't done any modifications to the amp. I was just wondering if anyone may be able to tell me why this may be happening. I used the amp on Sunday at practice and all was well. Could a tube be causing this? I was gonna switch out all the tubes when I get home today just to test.
The reverb is definately causing the amp to hum, just not sure why. Any input would be appriciated.
PS- I did not have any pedal effects running when this happened, I was running from my guitar straight into the amp. I did however try and hook up my noisegate to see if it would cut out the noise but nothing doing. I actually completely disconnect my guitar from the amp and still had the hum.....very odd.
My GEAR:
Gibson Les Paul Studio Worn Cherry 2008
Epiphone LP Standard Plus Vintage Sunburst
American Fender Stratocaster '89 "Blackie Edition"
Orane Tiny Terror head (7/15 WATTS)
Crate Palomino V32X212 (30WATTS)
Epi Valve Jr. head (5WATTS)
Epiphone Valve Junior 1X12 Extension Cab (70WATTS)
Digitech Jamman
Ibanez Compressor Sound Tank
EHX Metal Muff (w/Top Boost)
EHX Small Clone
Boss Metalzone MT2
Zoom 505II Effects
ISP Decimator Noise Gate
MXR Carbon Copy
MXR 10 Band EQ
Vox Wah
Bordeaux is offline   Reply With Quote
Old 08-05-2008, 11:44 AM   #2 (permalink)
...with a big mouth
Big John's Avatar
Re: Peavey Delta Blues 210 feedback issue.
Originally Posted by Bordeaux View Post
...Could a tube be causing this?...
First thing to check.
Big John is offline   Reply With Quote
Old 08-05-2008, 02:55 PM   #3 (permalink)
Bordeaux's Avatar
I will check that once I get home. I was just wondering if maybe someone had run across this issue and could save me some time. Thanks
My GEAR:
Digitech Jamman
EHX Small Clone
Boss Metalzone MT2
Zoom 505II Effects
MXR Carbon Copy
MXR 10 Band EQ
Vox Wah
Old 08-07-2008, 09:25 AM   #4 (permalink)
Bordeaux's Avatar
Just in case anyone ever runs across this issue maybe I can be of some help. The tubes were not the issue. The issue was with my reverb tank. All I did was pull out the reverb tank and pull the 2 cable leads away from the reverb tank springs. Looks like they were too close and may have been causing the feedback. Amp is working fine now.
My GEAR:
Digitech Jamman
EHX Small Clone
Boss Metalzone MT2
Zoom 505II Effects
MXR Carbon Copy
MXR 10 Band EQ
Vox Wah
Old 08-08-2008, 10:56 AM   #5 (permalink)
Oaklanda's Avatar
Good to know for future reference. I would've thought it was a tube for sure based on what you described.
That's what she said
Oaklanda is offline   Reply With Quote
Old 08-09-2008, 11:41 AM   #6 (permalink)
Bordeaux's Avatar
Nope, tubes are fine. Reverb tank was the culprit. Still not exactly sure what was causing the hum but I pretty sure it had something to do with the leads being too close to the tank. So far everything is working fine.
My GEAR:
Digitech Jamman
EHX Small Clone
Boss Metalzone MT2
Zoom 505II Effects
MXR Carbon Copy
MXR 10 Band EQ
Vox Wah
1988 Issue '58 Goldtop Re-issue jansboy98 Historics & Reissues 1 07-19-2008 02:14 PM
feedback 98supra The Squawk Box 8 06-19-2008 08:05 PM
Help! Feedback Issues Mercutio Gibson Les Pauls 5 05-10-2008 09:57 PM
Peavey Classic/Delta Blues question. WhippingPost The Squawk Box 2 04-19-2008 11:31 AM
Feedback? caseyizzle Tonefreaks 6 04-06-2008 12:53 PM
