Unread 02-11-2011, 07:33 PM   #1 (permalink)
Buggaluggs's Avatar
Multiple cabs. Multiple heads. What to do?
I occasionally use an A/B pedal to switch between two amps, and I also use a patchbay to route stuff around a mixing desk.
How do I attach multiple speakers to multiple heads? Can I use a patchbay? Would it change the impedance that the head sees?
I think eminence have a 'wall of sound' that allows users to try any speaker they want.
I realize that care would need be taken to avoid blasting out from a head into zero ohms no speaker and blown transformer, but there must be a convenient way to do this, eh?
Current Fleet: Gibson LP; FEnder '52 Tele (re-issue); Les Paul Copy (unmentionable brand); 2x MIJ Strats w/ Lollar pups; Gibson SG w/ P90s; Hartke Bass w/ SD pups; Seagull 12; Takamine 6; Ibenez Class.; DR-103; Laney H20; Laney L20T-410; Phaez BlackDaisy; Phaez Dogs Bollocks; Blackheart 5W; Valve Jnr 5W; Laney LA65D; VOX AVT50; Pignose 6xAA.
Wanted: Tiny Terror/Dual Terror; Takamine Class.; More speakers. More Phaez. More Cowbell.
Buggaluggs is offline   Reply With Quote
Unread 02-12-2011, 05:01 AM   #2 (permalink)
Colabrador's Avatar
Re: Multiple cabs. Multiple heads. What to do?
You may build a switched network that can take care of that. I would take care that only one cab can be selected at a time.
CoLabrador
Colabrador is offline   Reply With Quote
Unread 02-12-2011, 08:23 AM   #3 (permalink)
Tonebone makes an amp switcher
AudioWonderland is offline   Reply With Quote
Unread 02-12-2011, 05:51 PM   #4 (permalink)
rocknhorse1's Avatar
But he wants a speaker switcher, not an amp switcher.
"Distortion, bless it's fuzzy woolen socks" Dave Hunter
"Yesterdays anger, is the sadness of today" Warren Haynes
rocknhorse1 is offline   Reply With Quote
Unread 02-12-2011, 06:01 PM   #5 (permalink)
lp_junkie's Avatar
Good question, I remember seeing custom built speaker switching systems in the past.
I run up to 4 cabs and 2 heads, but I am running them as a stereo image so I don't do any switching.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
Unread 02-12-2011, 08:00 PM   #6 (permalink)
roodyrocker's Avatar
Radial Engineering also makes a pedal called the Cabbone. They make one version of it which is for tube heads. It basically lets you run two heads into one cab. I think it maintains a load on the head not in use as the other head is running through the cab. Then when you switch to the other head it places a load on the other head.
At NAMM 2010 they also released a rack mounted unit that I believe lets you run up to 6 amps. I don't recall whether it was simply an amp switcher or if it allowed you to mix and match heads and cabs. I'd contact Radial Engineering and see what they have to offer. I've used their Switchbone A/B/Y switcher to run two amps live before and its top notch stuff!
roodyrocker is offline   Reply With Quote
Unread 03-01-2011, 09:12 AM   #7 (permalink)
Buggaluggs's Avatar
Thanks. (Two weeks later, what a disgrace!!)
Unread 03-01-2011, 10:34 AM   #8 (permalink)
Size Matters
Big John's Avatar
Sound Sculpture Headtrip feeding an Egnater SC-4
This setup gives you a choice of 3 heads, 2 loops, 4 tip-ground jacks (like for changing amp channels), and choice of 4 speaker sends...all under MIDI control.
Big John is offline   Reply With Quote
Unread 03-01-2011, 12:25 PM   #9 (permalink)
Nah dude, don't be so hard on yourself. Even if it is true No, No, I am kidding with you.
Seriously,
If you had a stereo cab, you could run one amp to one side of the cab, and the other head to the other side of the cab. Usually a stereo cab is 8 ohms for each side in stereo. That is the most common anyway, there could be different set ups for sure. This way you use the 8 ohm out on each head. Then you just use an A/B/Y switcher, and you don't have to worry about a load on either of the amps, because they both have a load. Is this making sense to you? I don't know if I explained it very well.
So, you could run 4 heads with two 4 X 12 speaker cabs. Each head would get 2 X 12. You would need two A/B/Y switchers...and watch out for ground loops. Use the same wall outlet for everything. Try to find an outlet that is a 20 amp circuit. Rock out, with your "hangy down thing" out!!
Unread 03-01-2011, 07:16 PM   #10 (permalink)
Buggaluggs's Avatar
Seriously,
Most likely scenario is four heads and five cabs. I reckon I could use a patchbay and just make sure any amp that isn't in use is off or on standby.
The Headtrip mentioned above wound do the job, but I'm not too concerned with hot-swapping, as long as I have flexibility and front side convenience. Tepid-swapping, maybe.
Unread 03-01-2011, 09:15 PM   #11 (permalink)
Don't worry about it
