Go Back   My Les Paul Forums > Music Gear > The Squawk Box
Old 06-30-2008, 08:19 PM   #1 (permalink)
nakleh's Avatar
Send a message via AIM to nakleh
OHMS.. can someone help me really quickly?
Silly question, I know.
If I'm using a Marshll JCM800 50W head, and a Mesa 4x12 cabinet, with the following as the jack plate in the back- if I plug one cable from the output of the 800 to the bottom left jack, does that mean I set the amp to 4ohms? The amp has 4, 8 or 16.. the "split for stereo or bi amp" part confuses me..
nakleh
WebsiteMySpaceBand MySpace
2006 Gibson Custom Shop Les Paul Custom
1978 Marshall JMP 2204 • 1993 Marshall JCM900 4100 • Marshall JCM800 4x12 Cab
Egnater Rebel 20 Head • Avatar 1x12 Closed Back Cabinet
Mac Pro Tower • Pod XT • Guitar Rig 3
nakleh is offline   Reply With Quote
Old 06-30-2008, 08:34 PM   #2 (permalink)
monroe's Avatar
Re: OHMS.. can someone help me really quickly?
Looks to me like it's an 8-ohm cab, and that if you use the stereo inputs, each half of the cab becomes 4-ohms so each 4-ohm input would be connected to only two speakers. If you're only using one amp, use the 8-ohm input and set the amp accordingly.
Green: the new Red
monroe is offline   Reply With Quote
Old 06-30-2008, 09:00 PM   #3 (permalink)
drewbertca's Avatar
yep...+1
BFG Defender....The normal ones...Not the over priced "First 52 of Each" ones.
THIS THREAD IS DEAD!
drewbertca is offline   Reply With Quote
Old 06-30-2008, 10:20 PM   #4 (permalink)
Robster's Avatar
Set your amp to 8 ohms and use the jack on the lower right (8 ohm input). Just ignore the others, unless you plan to use this as a stereo cab (or plug 2 different amps into it, in which case you'd set each amp {or the stereo amp} to 4 ohms.) Does this make sense?
Rob
Just between us,
I think it's time for us to recognize
The differences we sometimes fear to show.
Just between us,
I think it's time for us to realize
The spaces in between
Leave room for you and I to grow
{Neil Peart}
Robster is offline   Reply With Quote
Old 06-30-2008, 10:33 PM   #5 (permalink)
stryker59's Avatar
yep on the descriptions above.......unless you would rather use just two of the speakers then do it the way you described!
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Old 07-01-2008, 12:04 AM   #6 (permalink)
nakleh's Avatar
Here's why I'm asking..
It's a studio we go to once in a while, and this is the amp and cab setup. The right side of the inputs are taped off, not to be used. So I can't plug into the 8ohm side, only the left side. And the "split" part was confusing me..
I guess they don't want people using the 8ohm side for some reason?
Tonight at practice I set the amp to 4ohms and plugged into to the bottom left input. Sounded ok..
nakleh
Old 07-01-2008, 12:11 AM   #7 (permalink)
Disciple-of-RobotOverlord
xsouldriverx's Avatar
maybe get a y connector so that the one head plugs into both 4 ohm inputs. or maybe they only want 2 speakers to be used so its not as loud.
by the way i have an amp and cab that can do 4/8/16 ohms, whats the sound difference between them. and if there is no sound difference what is the best value to use.
2005 Ibanez H.R. Giger Iceman
VHT Deliverance 60
xsouldriverx is offline   Reply With Quote
Old 07-02-2008, 06:40 PM   #8 (permalink)
monroe's Avatar
Most Y connectors are parallel, and that will result in a 2-Ohm total load. If you choose to try a Y connector, make sure it's a series connector (may have to fab one) and then your amp will see 8-Ohms using both 4-Ohm inputs. Actually, all of the suggested schemes seem like overkill for a recording session....? My $.02
Green: the new Red
Do all epi's get fret wear this quickly? :/ Tippsy- Epiphone Les Pauls 6 05-11-2008 08:43 PM
Is a guitar amp load 2.2 Meg ohms or 47K ohms? Mitch Malloy Tonefreaks 0 03-29-2008 05:57 PM
question about speaker ohms!?!?!?!? tarddoggy The Squawk Box 9 03-06-2008 01:43 AM
Another infamous ohms questions Blues Power The Squawk Box 1 02-25-2008 07:50 PM
p90 dogear ohms ? frrrrrrunkis Pickups 1 10-08-2007 08:05 PM
