Unread 02-06-2011, 01:51 AM   #1 (permalink)
johnt's Avatar
Fender Hot Rod Deluxe with Les Paul
Hi,
I was gigging last night with the HRD and my Epi Les Paul with DiMarzios (PAF 36th Anni neck, Super Distortion bridge).
I've owned the HRD with stock Eminence speaker for a few years now and never had any problems, however I have always gigged it with my Strats and Teles - great sound!
I have a fairly extensive pedal board with analogue effects (timed effects go through the effects loop).
Last night however with the Les Paul (I didn't take the Fenders) , no matter what I did my clean sound was distorted, not in a pleasant way, rather in a raspy sound through the speaker, using the clean channel. The usual lovely pure cleans that I have come to expect just weren't there. Volume was around 3 (quite a big gig) and my amp was mic'd to the large PA system. The raspy sound was coming from the speaker, nothing to do with the PA. I was very disappointed and wondering why this was so different to the otherwise great sound I have with my Strats and Tele. I am thinking that maybe I need to get a Marshall to use the Les Paul with
It occurred to me this morning that I was using the DiMArzio loaded LP through input one of the amp and the manual says that input 2 is designed for high output or pre-amplified (active) instruments.
I'm now thinking should I have used input 2? Would this have solved the problem?
It's difficult to emulate this at home because as we all know HRDs are VERY LOUD even at low volume settings
Thanks for your thoughts.
JohnT
2011 Gibson Les Paul 60's Tribute - Cherryburst (SD Pearly Gates neck and bridge)
1996 Epiphone Les Paul Goldtop MIK (DiMarzio 36th Anni. PAFs)
1998 Epiphone Les Paul Custom MIK (Gibson 490s)
1996 Fender Stratocaster '62 Reissue MIJ
2009 Squier Classic Vibe '50s Strat
2011 Squier Classic Vibe '50s Tele
1984 Yamaha SG-300 MIJ
1993 Fender Stratocaster (Partscaster)
Marshall DSL 401
Marshall TSL 212c
johnt is offline   Reply With Quote
Unread 02-06-2011, 01:54 AM   #2 (permalink)
slapshot's Avatar
Location: Fishing.it's like yoga but I get to kill something
Send a message via ICQ to slapshot
Re: Fender Hot Rod Deluxe with Les Paul
i always used input 2
just plug it in and strum a chord and see?
slapshot is offline   Reply With Quote
Unread 02-06-2011, 05:44 AM   #3 (permalink)
johnt's Avatar
Would an Epi Les Paul with DiMarzios' (13.4k Super Distortion) be classed as a 'high output instrument?'
JohnT
Marshall DSL 401
Marshall TSL 212c
Unread 02-06-2011, 06:45 AM   #4 (permalink)
I only recently became aware of this myself, my stock double cutaway is apparently a high output instrument, the cleans do exactly as you describe.
You can run an A/B box to swap you over Hi/Lo if you like the BIte on HI for driven sound....
dubcut is offline   Reply With Quote
Unread 02-06-2011, 08:18 AM   #5 (permalink)
johnt's Avatar
Well this is reassuring since I thought: -
a) my speaker is damaged or
b) My HRD can't handle a Les Paul for cleans at gig volume;
'The bite on HI' is really not kind on the ear as it was sounding like a wasp in a bean can.
My band has a rehearsal in the week. I'll crank it a little to try emulating the racket I was hearing last night and then switch to input 2. So what exactly is the 'LO' input doing and would this be okay at any volume level?
Thanks for the help.
JohnT
Marshall DSL 401
Marshall TSL 212c
Unread 02-12-2011, 03:31 PM   #6 (permalink)
johnt's Avatar
Well I tried both inputs at rehearsal the other night. Not happy...
Now considering part-exchanging the Fender Hot Rod Deluxe for a Blackstar Stage 60. This seems to work well with both single coil guitars as well as those with humbuckers.
What do you think?
JohnT
Marshall DSL 401
Marshall TSL 212c
Unread 02-12-2011, 03:58 PM   #7 (permalink)
Scooter2112's Avatar
JohnT
Is this an honest question?? Seriously?
Absofrigginlutely!
______________________________________________
Scooter2112 is offline   Reply With Quote
Unread 02-12-2011, 07:18 PM   #8 (permalink)
Sukkoi19's Avatar
Super D always seems hotter than the numbers would indicate. I have never played one is a Paul only Strats and Super Strats but they always seem like they have a lot punch.
2010 Gibson Les Paul Standard Plus Cherry Burst
2010 Gibson Les Paul Traditional Pro Cherry Burst
2006 Jackson Soloist SL2H in Metallic Black
1997 Jackson Soloist SL1 in DCR
1992 Fender Stratocaster
Marshall JVM 410H
Marshall Vintage Modern
Mesa Boogie Mark IVA
Peavey 6505 Modded Yes Please
Peavey Classic 30
Sukkoi19 is offline   Reply With Quote
Unread 02-12-2011, 08:05 PM   #9 (permalink)
Splattle101's Avatar
Yes, your guitar with Super Distortions is a high output instrument.
The sleep of reason brings forth monsters.
Splattle101 is offline   Reply With Quote
Unread 02-13-2011, 02:30 PM   #10 (permalink)
johnt's Avatar
Thanks , yes I was serious as I didn't know if this meant purely active guitars.
Thanks anyhow.
Marshall DSL 401
Marshall TSL 212c
Unread 02-13-2011, 03:37 PM   #11 (permalink)
Thunder Dump's Avatar
Did you have the volume pots dimed on the LP? Dial back to the 5-8 range and it should clean up a hot pickup very nicely.
-Matt
'12 Gibson LP Standard Trans Amber/'12 Gibson LP Traditional Mahogany Worn Brown
'11 Gibson LP Custom Shop R0 VOS Southern Sunset Burst
/'11 Gibson LP Classic Custom Antique Natural
'11 Gibson LP Studio '60s Tribute Darkback Vintage Sunburst
/'10 Gibson LP Traditional Pro Goldtop Darkback
'10 Gibson LP Custom Shop 50th Anniversary R0 VOS Cognac Burst
/'08 Gibson LP Custom Shop G0 VOS Dark Burst
'07 Gibson LP Classic Custom Ebony
/'07 Gibson LP Classic Antique Honeyburst
Thunder Dump is offline   Reply With Quote
