Unread 12-18-2010, 04:29 PM   #1 (permalink)
help me understand
hey all. first post here. nice place!
ok, this is a noob question. i'm leaning toward a marshall haze 15, and i'm not sure if i should get the full stack or half stack. i am trying to understand the difference. if a half stack, 15 watts would go to one speaker, right? so, if i got the full stack, are 15 watts going to each of two speakers, making it twice as loud? or is it dividing it between the two, so each get 7.5 watts, but somehow sounds better because it's coming out of two speakers? if the full stack sounds better, then i would get it. this is just for home use, but i'd really like to understand the difference between the half and full stack arrangement.
thanks,
pat.
pat 58 is offline   Reply With Quote
The Following User Says Thank You to pat 58 For This Useful Post:
Unread 12-18-2010, 04:48 PM   #2 (permalink)
chrisuk's Avatar
Re: help me understand
The second of your suggestions - the 15 watts is shared. You will get a slightly fuller sound running two cabs but at low volumes it could still sound better out of one since there is a minimum power you want to put through a speaker. Full up two cabs will be very slightly louder and fill more space.
chrisuk is offline   Reply With Quote
Unread 12-18-2010, 07:25 PM   #3 (permalink)
Cygnus X1's Avatar
If you are going to buy a cheap head like the Haze then spend a bit more and get a good cab.
Two junk cabs are no better than a single combo.
Then you can upgrade the head and speakers as money allows.
I'd take a V30 Birch Ply 2x12 over any MDF 4x12.
Check Sourmash for a cab.
Or keep an eye out on CL for used 1960A's or older Peavey cabs.
Cygnus X1 is online now   Reply With Quote
Unread 12-18-2010, 07:51 PM   #4 (permalink)
acstorfer's Avatar
I was always curious about that!
Welcome to the squawk box.
Give a man a fish, he'll eat for a day.
Teach a man to fish and you just cost him a six pack a day!
acstorfer is online now   Reply With Quote
Unread 12-18-2010, 08:21 PM   #5 (permalink)
thanks for the quick reply, guys. it sounds like it would be better to get the two cabs. hopefully, i can find some locally and try them out first.
Unread 12-19-2010, 10:23 AM   #6 (permalink)
4nd3h's Avatar
My question, sorry for the hijack: 2 speakers = twice as loud as one? 4 speakers = twice as loud as two, four times as loud as one?
-Andy
4nd3h is offline   Reply With Quote
Unread 12-19-2010, 11:20 AM   #7 (permalink)
Cygnus X1's Avatar
No, just more range and projection.
The amp still pushes the same wattage no matter what.
Speaker efficiency has a much more pronounced effect than anything else.
Another factor to consider is closed back vs. open back enclosures.
Unread 12-19-2010, 11:27 AM   #8 (permalink)
Thumpalumpacus's Avatar
No. But you will get more depth of tone thanks to the dispersion multiple speakers will provide.
Unread 12-19-2010, 12:21 PM   #9 (permalink)
thanks, thump, good stuff to know.
have any haze 15 owners experienced any issues with their units so far? satisfied with it?
Unread 12-19-2010, 01:19 PM   #10 (permalink)
JakeM's Avatar
The watts will not be divided, extra speakers push more air and thus increase perceived volume. You will still have 15watts just pushing more air
jake
Aut Vincere Aut Mori
Epiphone Les Paul Standard Red Flake
Blackstar HT 40
TC Electronic Polytune
EHX Big Muff Pi
MXR Carbon Copy
Proud Member of Teen Axe Dudes
JakeM is offline   Reply With Quote
