Unread 10-21-2010, 11:11 AM   #1 (permalink)
Just Got a Blackstar HT-40
Glad I gave this amp another shot really starting to dig this amp, I bought it this past Sunday and got to use it with my band and no problem at all cutting through a band mix. When I initially got it the speaker was a bit stiff sounding and a tad harsh with my Les Paul but after cranking it for 3 days the Celestion 70/80 is starting to come to life the low end is starting to get much bolder and the top end is not so harsh I just back off a bit on the tone knob of my LP and get a very musical tone happening.
I'm going to play this amp stock for a while and right now I like it stock I know the 70/80 speaker is probably not every ones choice for a speaker but it actually does sound good to my ears, I like the voicing switch out on the OD channel it still has plenty of gain if needed and its very dynamic I think the amp cleans up incredibly well.
Well all I can say is the amp rocks I have a gig this Friday and Saturday night so it will be a good test for it i will get to try out the emulated output as well and see how it sounds through the P.A. i also like the digital reverb sounds convining to my ears!
Will report back later!
J.LaGrassa is offline   Reply With Quote
Unread 10-21-2010, 12:32 PM   #2 (permalink)
JakeM's Avatar
Re: Just Got a Blackstar HT-40
glad to see another ht 40 user!!! i love mine. i'm thinking of swapping tubes soon and upgrading my speaker but i'm not sure what to.
jake
Aut Vincere Aut Mori
Epiphone Les Paul Standard Red Flake
Blackstar HT 40
TC Electronic Polytune
EHX Big Muff Pi
MXR Carbon Copy
Proud Member of Teen Axe Dudes
JakeM is offline   Reply With Quote
Unread 10-21-2010, 01:06 PM   #3 (permalink)
Right now I am actually liking the amp stock, I usually replace tubes and speaker with my amps but so far I dont see a need just yet!
Unread 10-22-2010, 11:09 AM   #4 (permalink)
moodus2006's Avatar
Welcome the Blackstar! I have a ht-60 and love it! I was a/b ing the Blackstar to my Super Reverb yesterday with petals and clean. I love the Super but the HT just does it all well. (also 4x10 compared to 2x12 ...I like the fullnes/bottom end of the 12's). Let me know what y'all swap for tubes or speakers. I am willing to experiment/ curious to know what others are trying.
moodus2006 is offline   Reply With Quote
Unread 10-23-2010, 07:32 AM   #5 (permalink)
Well I had my first gig with the amp last night and I felt very comfortable using it we had to keep our volume under control so I could not really push the amp but that did not effect the tone or dynamics of the amp I love the master volume on this amp.
The amp had no problem cutting through a band mix both channels sound great, for cleans I used the Blackstar Boutique mode it was set around 12:00 for a little bit of dirt and on the OD channel I use it with the voice switch out and the gain set to around 2:00 I got a real nice crunch tone and was still enough for a good solo tone as well. The only pedals I use now is a Boss DD-3 delay and a Barber Launch Pad for a solo boost I place these in the fx loop which worked nicely.
I will get to use it again tonight hopefully I can push the amp a little more plus I will get to try out the Emulated line out into the PA so far I think this amp is great for doing gigs the 40 watts are perfect for my needs.
Unread 10-25-2010, 08:29 AM   #6 (permalink)
2nd gig went great as well the amp performed flawlessly, a big plus for me is the emulated line out sounds great into the P.A. it is just as good as the Palmer PDI-09 I have used.
Unread 12-01-2010, 12:20 PM   #7 (permalink)
Well I put my HT-40 to a good test the other night I played in a 300+ room and the amp sounded so good on stage only had the master about 10-11:00 and it was plenty loud on stage, I used the line out to the board to help fill the room.
My amp is still totally stock I like every thing about the amp the TAD EL34 power tubes the Sovtek 12AX7WA and the Celestion 70/80 they all work great in this amp. It feels so good not to be going nuts changing every little thing, I have even stopped using drive pedals i plug straight in and just use delay and a clean boost in the fx loop.
This is an amazing amp for the money I'm glad I bought it!
Unread 12-01-2010, 12:29 PM   #8 (permalink)
just curious, what clean boost are you using in the loop?
does the fx loop work well with pedals?
erikm5150 is offline   Reply With Quote
Unread 12-01-2010, 01:35 PM   #9 (permalink)
I am using the Boss GE-7 EQ as a clean boost I run it flat and just use the volume slider to adjust the amount of boost, the only other pedal I am using is a Boss DD-3 delay these both work great in the loop.
You have a push button option on the amp to use +4db for rack fx and -10db for pedals, the fx loop is very nice no volume loss or tone issues. I wanted the Boss pedals for there silent switching rather than going with True bypass pedals to avoid any popping issues they can cause.
