Unread 10-16-2010, 08:23 AM   #1 (permalink)
cmcoram's Avatar
Nad!
Picked up a Epi Valve Special at the pawn shop yesterday. So far, I'm liking it. Using it as practice amp, since I use my Palomino V32 for gigs. Couple of questions, for anyone with experience with them:
1. With humbuckers, the tone sounds as if I rolled the guitar's tone down slightly. Thought this might be due to it being a closed back combo, so I removed the back panel. Not much of a change. Any ideas?
2. What should I change the tubes and speakers out with? And can I change the tubes myself, or does it need biasing?
Thanks for the help!
Chris
'07 Epi Elitist LPC w/EMG JH Pickups
'07 Mexi-Fender '72 Tele Deluxe RI
'06 Epi Les Paul Custom w/GFS Fat PATs
Digitech RP500
Boss SD-1
Digitech Bad Monkey
Marshall JCM 2000 DSL201
Marshall JCM 2000 TSL60
Peavey ValveKing 100
Marshall MG412SL w/G12T-75s and Wizards
Laney 412SL w/G12M-70s
3 chords, 3 minutes. God Bless Johnny Ramone.
Time spent on the MLP and Marshall Amp Forums is time NOT spent playing my Les Paul and Marshall amp.
cmcoram is offline   Reply With Quote
Unread 10-16-2010, 07:12 PM   #2 (permalink)
TWANG's Avatar
Re: Nad!
You should try a tung sol 12AX7 in the preamp..
they get rave reviews..
EH and JJ are also good choices.
I'd put a JJ in the power amp tube spot.
no changes needed to do that at all.
If it's too much gain for you, a 12AT7 will cut the overdrive a bit and still give you very good tone, it will just break up later on the volume dial.
You will want to change the tubes before changing anything else as far as the sound with humbucks go
but some do feel the amps are a little dark with humbucks.
I like to use a clean boost in front.. for one thing it lets me run long pedal cable runs and for another it gives me a bit better control over the highs.
*even though I'm using modded vjs*
Speaker.. well.. a 12" will certainly wake you up.
But Weber or a Jensen Mod.. not bad and not pricey!
TWANG is offline   Reply With Quote
Unread 10-17-2010, 05:54 AM   #3 (permalink)
Standard 64's Avatar
Re: Nad!
Make sure you pull the tubes straight up and out,no bending.A Danelectro fish n chips equalizer($39)does wonders with these amps.
2005 Gibson Les Paul Standard HCS
2011 Fender American Standard Stratocaster.
2012 Fender Jaguar with Lollar P90 pickups.
1965 Fender Tremolux amplifier(AB763)
2012 Orange Holy Terror(Mercury Magnetics).
Standard 64 is offline   Reply With Quote
Unread 10-17-2010, 03:41 PM   #4 (permalink)
cmcoram's Avatar
Re: Nad!
Thanks! Twang, I knew that you worked on the Epi amps, so I hoped you would have some insight.
Chris
Digitech RP500
Boss SD-1
Digitech Bad Monkey
