View Poll Results: Phaez sub forum? Yes or no?
Yes 34 48.57%
No 36 51.43%
Voters: 70. You may not vote on this poll
Like Tree12737Likes
Unread 01-02-2012, 08:02 PM   #4381 (permalink)
re: Phaez Amps [merged]
Originally Posted by singlecut View Post
my early dragonfly covers it all
Do you have any clips of it? I can only find one YT clip, and I'm interested in hearing more of it.
Bob1 is offline   Reply With Quote
Unread 01-02-2012, 08:58 PM   #4383 (permalink)
Great thanks!
Unread 01-02-2012, 10:07 PM   #4384 (permalink)
V2
V2's Avatar
Re: Phaez Daisycutter DC10 kit build
Fired up the DC10 with a couple of different power tubes, first an EL34 and then a 6V6. Had the amp mated with a single 12" Eminence Texas Heat in an open-back combo cabinet (my Allen). Played through my two guitars (see my sig). The Schecter has 'monster coil' single coils with a coil tap; the Ltd has two standard HBs.
Here are some initial impressions; keep in mind this is the very first time I have heard a Phaez amp live, let alone played one. I was surprised in many ways. First off, this thing is surprisingly loud. It was difficult to turn up the master beyond 9 o'clock when the gain was also up (in my typical home/basement setting).
I immediately bonded with the clean sounds, which were very full sounding. I was quite surprised by the touch sensitivity. With the gain up at around 9 or 10 o'clock, I could go from clean to hairy just by changing my pick attack. Going from tapped to non-tapped PUPs opened up the range even more, of course.
The overdrive was also surprisingly rich in harmonics. I haven't experienced anything like this before, actually. I'm not sure it suits my tastes, but I'm eager to try the amp with different speakers and hopefully get the MV turned up beyond 2 with the gain up.
singlecut likes this.
1997 Schecter Traditional, ESP Ltd
Traynor Mark 3, Phaez Daisycutter 10, HG18 Denogginizer
Barber Launch Pad, Super Sport, Ltd v2 with mod board
V2 is online now   Reply With Quote
Unread 01-02-2012, 10:57 PM   #4385 (permalink)
...on the Nightrain
matmont1305's Avatar
Congrats on a successful build! I hear you about the volume, it took me by surprise too.
What tube did you prefer, I tried the same two as you and preferred the EL34. It sounded like it was being held back with the 6V6, though I'd still like to try a nice old one.
matmont1305 is offline   Reply With Quote
Unread 01-02-2012, 11:24 PM   #4386 (permalink)
Perhaps 2 different phaez amps with a/b switch would give u the different tones u require. Am considering it.
pstar is offline   Reply With Quote
Unread 01-02-2012, 11:26 PM   #4387 (permalink)
Hey Jim did u carve that neck or just install ?
Unread 01-02-2012, 11:34 PM   #4388 (permalink)
dennq's Avatar
Originally Posted by ANEAS View Post
Denng ..."Greatest Hits Live" will be playing on the cosmos stage ...and I will be starting your cab this week...JIM
It's getting close. I can't wait
"If it floats, flys, fornicates or drives, it's cheaper to rent it"
http://www.phaezamp.com/ampshop/en/
dennq is offline   Reply With Quote
Unread 01-02-2012, 11:36 PM   #4389 (permalink)
dennq's Avatar
Originally Posted by huffdaddy View Post
I may check that out too.
And a heads up.... Peter Frampton is playing there February 24th.
Peter Frampton - Frampton Comes Alive! 35 Tour
I have my ticket!
Unread 01-03-2012, 06:09 AM   #4390 (permalink)
rocknhorse1's Avatar
That is usually the first thing everyone notices, the volume. It's a real ear opener. They are very harmonically rich, and I have found through my experience that the chinese preamp tubes don't suit my tastes. If you are running the chinese tubes, then try some JJ's or some vintage tubes. That will smooth out the gain, and it won't be so messy when playing chords. With a nice set of preamp tubes, my amp is very nice in OD department. The DC does have a lot of gain too, and will smooth out with more volume from the power section. But yeah, LOUD.
"Distortion, bless it's fuzzy woolen socks" Dave Hunter
"Yesterdays anger, is the sadness of today" Warren Haynes
rocknhorse1 is offline   Reply With Quote
Unread 01-03-2012, 11:13 AM   #4391 (permalink)
IT was a new Warmoth neck ..just needed to be fitted and shimmed to line up the dots on the bridge ...the screw holes needed to be realigned ,other than that it worked out good ...the old neck had a small twist it was 30 years old, this is go to guitar..there was a few players in the band that I did some guitar work ,replacing pickups, necks and new anchor post for the floyd rose....I have built a new guitar for Randy ,,he gave me the parts ,swamp ash body ,new neck and machine parts ...I finished the raw body and assembled all the parts ..it turned out great....It seams odd for a Person to do work on Guitars when I never played or know how ...they are just mechanical devices to me ....And if thats not odd enough ..I don't play golf but I designed a driver and a new style putter that is sold on the market , built it for a friend who sold them....JIM
ANEAS is offline   Reply With Quote
Unread 01-03-2012, 01:56 PM   #4392 (permalink)
singlecut's Avatar
Rosco did you take the HRM/Hotcat out of the CRATE cab...JIM
yes jim, it's in a slightly larger box that lets me swap other speakers around. the previous cab was very tight
[SIGPIC]
singlecut is offline   Reply With Quote
Unread 01-03-2012, 10:07 PM   #4393 (permalink)
Randy sent me this pic today and it should be heading my way soon. Can't wait!
jiveturkey1 likes this.
57Goldtop is offline   Reply With Quote
Unread 01-03-2012, 11:19 PM   #4394 (permalink)
onioner's Avatar
I love that look. That cab is awesome.
That's my favorite "Phaez" font too. IMO, that should be the logo.
Armstrong and dennq like this.
This post is the view of the author, and should be considered with all the usual acronyms implied, including, but not limited to, IMO, IMHO, IMESHO, FWIW, IIRC, and YMMV. In addition, whenever in doubt of the intent of the author, assume the presence of an appropriate smiley to imply that any questionable statement was not intended to offend. The author is not liable for anything stated in this or any other post. Thank you for your cooperation.
onioner is offline   Reply With Quote
Unread 01-04-2012, 05:11 PM   #4395 (permalink)
I really like the Ash cab. When I saw it on the 6v6 Sibly clip on Youtube I knew that was what I wanted. It makes it more unique kind of like the Trainwreck's. It shipped today so I can't wait to try it out.
Unread 01-04-2012, 06:57 PM   #4396 (permalink)
MLP Anchorman
Led Zep Fan's Avatar
Ok guys, I'm finally joining the Phaez crew after much procrastinating!
I've been in contact with Randy, and he's building me a 50 watt Asheville, that'll be going into a 2 x 12 combo from Bob over at Sour Mash! And can't begin to start to tell you guys how excited I am!!!
huffdaddy, kingedb, LPV and 10 others like this.
Led Zep Fan is online now   Reply With Quote
Unread 01-04-2012, 07:08 PM   #4397 (permalink)
This cab was built by Matt of ARk Amps he makes a great wood cab and for anyone interested in a cab like this I think Randy only has one left...I used to make wood cabs but don't do now.....JIM
Armstrong likes this.
Unread 01-04-2012, 07:23 PM   #4398 (permalink)
MLP Anchorman
Oh, and a big hats off to Rich (Rocknhorse1) for answering my dumb questions that helped me through the process!
rocknhorse1 likes this.
Unread 01-04-2012, 07:27 PM   #4399 (permalink)
And my Asheville is going to get a make over I think. IF, my Martin acoustic I have for sale in the classifieds sells. Im goin 3D on that som bitch.
Led Zep Fan likes this.
Unread 01-04-2012, 07:37 PM   #4400 (permalink)
Bartlett Retrospec Member
kingedb's Avatar
Congrats LZF!!
I know you've been wanting one for a bit. Going back and forth with Randy and creating a cab with Bob is a LOT of fun!! I can't wait to see the cab and hear your thoughts.
kingedb is offline   Reply With Quote
Unread 01-04-2012, 07:40 PM   #4401 (permalink)
MLP Anchorman
I can't wait either! Rich's Asheville sounds amazing, and this is going to be my main gigging amp... Finally the tone I've been after for years will be at my fingertips!
singlecut and rocknhorse1 like this.
Unread 01-04-2012, 07:44 PM   #4402 (permalink)
MLP Anchorman
Hey Kingedb! I just noticed you're in Lansdale, I work about 15 min down the road from you in Souderton, when I get my amp we'll have to get together and jam!
Unread 01-04-2012, 08:51 PM   #4403 (permalink)
kingedb's Avatar
Oh man, you're in Souderton!?!? I really am right down the road. My grandparents live in Souderton.
I will DEFINITELY down for that! I can even bring a few toys myself. My "MLP Collection" : A Phaez MLP/35, and 8 watt Daisycutter and even a Rist Tele. Maybe by the time you get your beauty and we set it up I'll have my 3rd Phaez in it's cab. It's a Blackface/Tweed style 3 watter. It's in the basement, sadly sitting it it's box. (Sorry Randy!!)
I wish I would have known you were that close. I could have let you sample a couple Phaez's before you made your decision. Though I KNOW you were set on the amp you ordered.
Unread 01-04-2012, 08:56 PM   #4404 (permalink)
MLP Anchorman
Lol, I am dead set on that amp, but who knows what the future holds for phaez #2...
I'm in Souderton 8a-4p Mon-Fri, we have to make a jam happen! I'd live to hear those amps, and check out that Rist Tele!
kingedb likes this.
Unread 01-04-2012, 10:48 PM   #4405 (permalink)
onioner's Avatar
Ah, yeah, that's got the Ark Amps look to it. Cool cab, but I've got an unnatural affection for good looking wood.
Speaking of, who did that original Winona cab? You know, the Boysden, or whatever his name is. It's finished wood, with metal grill ports on the top, and rounded corners. That you or Matt?
Unread 01-04-2012, 10:55 PM   #4406 (permalink)
V2
V2's Avatar
Update:
I had much more success with the DC10 tonight. I don't know what changed. I had it back on the bench to replace the LED dropping resistor, and when I connected it to the speaker and plugged in, my impression was totally different. Great low-gain tone with the gain and MV each at 9 o'clock. Well I call that low gain. The overdrive sounded good too with the gain around noon. Maybe it took some time for the caps to "break in" or something. Dunno.
Some more photos below. Notice the chrome input jack. Please don't make fun of my poor grill cloth job. That will be replaced
Unread 01-04-2012, 10:56 PM   #4407 (permalink)
onioner's Avatar
Also, y'all East Coasters kill me. I was born and raised in Baltimore, but I've been out west for six years now. Don't tell anyone I said so, but the music scene in NoCal kinda sucks. It's so much better back east. I miss that.
If we did a MLP meet out here, like three people would come, and at least one of them would be more interested in the cabs than the amps. We'd probably have to have cheap California wine instead of beer, or if we did have beer, it'd be Miller High Life, instead one of the myriad of cheap drinkable beers one finds on the Atlantic. Food would be better though. I know, 'cause I'd cook it... Maybe spit roast a pig or something. But aint gonna happen, 'cause aint no one who really cares out here.
Alright. I'm gonna go cry in the corner for a while.
Unread 01-04-2012, 11:06 PM   #4408 (permalink)
...on the Nightrain
Congrats man, that really does sound like a cool amp.
And the best part is if anyone comes in here hatin' on Phaez from now on, you can just ban 'em, straight up, no questions......lol
Unread 01-05-2012, 02:02 AM   #4409 (permalink)
This too has always been my favorite Phaez logo but I am thinking it would be hard to do a nameplate for a traditional head cab with that logo. It is by far my favorite though.
Originally Posted by v8ko View Post
I'm going to save so much money Ill probably go broke.
Mr_Wormwood is offline   Reply With Quote
Unread 01-05-2012, 07:35 AM   #4410 (permalink)
Matt made that cab ...it was unfinished and needed some touch up on the ash ....I stained it walnut and did a gloss lacquer finish on it ....it turned out quite nice... Matt dosen't do high gloss finish ,just toung oil....It would be possible to do that logo ,but the program doesn't have that script...not sure how Randy could do program .... Those wood cabs by Matt were payments for amps Randy made for ARK.......JIM
