View Poll Results: Phaez sub forum? Yes or no?
Yes 34 48.57%
No 36 51.43%
Voters: 70. You may not vote on this poll
Like Tree12781Likes
Unread 08-27-2010, 11:31 AM   #301 (permalink)
Benguitar's Avatar
re: Phaez Amps [merged]
Because I don't like analog/tube stuff much anymore.. Starting to move over to digital completely.
Phaez amps are pretty cool amps though, I must admit, Maybe someday in the future when I want an amp to just play around with.
Benguitar is offline   Reply With Quote
Unread 08-27-2010, 07:11 PM   #302 (permalink)
Gtarzan81's Avatar
I'm talking to Randy about doing a 2xEL84 version of the Marshall 1987x circuit. I love the cranked Superlead sound, but have no place to crank one. I'm looking forward to talking to Randy further on this one.
Gtarzan81 is offline   Reply With Quote
Unread 08-27-2010, 07:16 PM   #303 (permalink)
rocknhorse1's Avatar
It will be right on the money as far as tone and feel. The guy knows his stuff. He did me a 2 X EL84 18 watt JTM45 thing and it is awesome. I still cant believe how right on the tone is, even with EL84s Not to mention if an ant were crawling on the strings I could hear it
"Distortion, bless it's fuzzy woolen socks" Dave Hunter
"Yesterdays anger, is the sadness of today" Warren Haynes
rocknhorse1 is offline   Reply With Quote
Unread 08-30-2010, 07:18 AM   #304 (permalink)
Bartlett Retrospec Member
Bubbletonic's Avatar
I'd consider one if they worked on English voltage =p
Bubbletonic is offline   Reply With Quote
Unread 08-30-2010, 11:18 AM   #305 (permalink)
DrakeZero's Avatar
After talking with Randy a bit more we switched my order from a lightning cutter to one with a blackface an daisy cutter side. Wonder what kind of name could it get? A Deluxe-Cutter? Either way with the heavy gain on the daisy side, and the cleans on the blackface I can get a more wide spectrum.
He also offered to add more gain onto the blackface circuit for a SRV tone, but then I think it would ruin the cleans. Besides with it being powered by EL84 we figured it'll break-up sooner.
Now I have to figure out what I am going to do about funds as my employer or ex-employer has flipped again and has put me on temporary lay off pending on the workload. So no money coming for the moment...
DrakeZero is offline   Reply With Quote
Unread 08-30-2010, 12:25 PM   #306 (permalink)
DaisyFace?
Originally Posted by v8ko View Post
I'm going to save so much money Ill probably go broke.
Mr_Wormwood is offline   Reply With Quote
Unread 08-30-2010, 01:17 PM   #307 (permalink)
kingedb's Avatar
Black Daisey
kingedb is offline   Reply With Quote
Unread 08-30-2010, 01:32 PM   #308 (permalink)
arkamps's Avatar
Originally Posted by kingedb View Post
Black Daisey
arkamps is offline   Reply With Quote
Unread 08-30-2010, 02:27 PM   #309 (permalink)
JakeM's Avatar
face cutter
Aut Vincere Aut Mori
Epiphone Les Paul Standard Red Flake
Blackstar HT 40
TC Electronic Polytune
EHX Big Muff Pi
MXR Carbon Copy
Proud Member of Teen Axe Dudes
JakeM is offline   Reply With Quote
Unread 08-30-2010, 03:51 PM   #310 (permalink)
DrakeZero's Avatar
Black Daisey
Oh very good.
Unread 09-01-2010, 05:02 PM   #311 (permalink)
DrakeZero's Avatar
Well I spoke to Randy recently about the construction, and dropped the name BlackDaisy to him. Really liked the name and is going to put in a switch so I can go between the sides. One being labeled Black and Daisy, and he's going to have the front panel look simliar to a fender deluxe. Can't wait for it. .
So thanks Kingedb for your awesome name suggestion.
Unread 09-01-2010, 05:36 PM   #312 (permalink)
kingedb's Avatar
You got it. Congrats! You're going to love that amp.
Unread 09-03-2010, 12:56 AM   #313 (permalink)
rhythm's Avatar
I have been exchanging e-mails with Randy about a new 2-channel amp. Like DrakeZero, one channel will be Blackface. After some discussion about my interests, tastes, etc. Randy agreed that the Daisycutter might be more high-gain that I'm after, so the second channel will likely end up being JTM45 or Plexi. He did mention that he could do a "dialed-back" Daisycutter also, which would reduce the gain but still be a bit more gainy than the two Marshall options mentioned. So that's a possibility also. I like the warmth of the JTM45, but a Plexi sounds great too and might be a better choice to pair with the Blackface for a wider range of tonal options.
DrakeZero, he mentioned an extra gain stage option in front of the Blackface circuit to me also, but it sounded like it would have its own trim control and would be completely transparent if the trim were all the way down. I haven't decided if I'll do this or not.
A few more decisions to be made, but we're getting closer to making it happen!
-Greg
rhythm is offline   Reply With Quote
Unread 09-03-2010, 03:12 AM   #314 (permalink)
GibsonByBirth's Avatar
Location: Well I never been to heaven but I've been to Oklahoma
-Greg
It sound like you both should tip the OP for his useful thread.
Damn it! Watch the video!
GibsonByBirth is offline   Reply With Quote
Unread 09-03-2010, 09:52 AM   #315 (permalink)
R8R6Ben's Avatar
i think we've got the idea for mine worked out pretty well. ~15 watts, 6v6, volume, tone (in center it's bypassed, to the left cuts treble and to the right it brightens up), master that is bypassed when cranked, a bass cut switch, and an overall tweed feel but with tighter response. I can't wait still deciding between making it a 1x12 combo or a head with2x10 cab. Leaning more towards a 1x12... I play slide most of the time and i want raw and gritty. Planning on getting a tweed sourmash cab with crimson grill cloth if I can and a weber speaker
2007 Gibson Les Paul R8 "Jamie Leigh" OTPG'd
2001 Gibson Les Paul R6 "Aimi" '53 Soapbars
2007 PRS Hollowbody Spruce " Clara" Skatterbrane'd
2001 Fender AmStd Telecaster "Sharon" Lollar'd
1960's Gibson J50 "Imogene"
Phaez 15 Watt 6v6 "Rising Sun"
all pots, caps, and harnesses by Jonesy@ tonemojo
R8R6Ben is offline   Reply With Quote
Unread 09-03-2010, 10:04 AM   #316 (permalink)
Tell us what made you decide to buy a Phaez?
Unread 09-03-2010, 10:34 AM   #317 (permalink)
Originally Posted by JM Vasek View Post
Easy, chief. You need to understand that your story is slightly hard to believe. You don't need to flare up. Otherwise, happy banning to you.
And if you did indeed play a Phaez, I can respect that it wasn't your thing. Doubt it though.
I think I have a right to flare up when other people are rude...
Rang Rang likes this.
MrTommy is offline   Reply With Quote
Unread 09-03-2010, 10:35 AM   #318 (permalink)
Originally Posted by rocknhorse1 View Post
Wouldn't strings of that gauge put a huge amount of stress on the neck? If I had a guitar that was expensive (like a Gibson) I don't think I would put them on there....call me crazy.
You adjust the truss rod before putting heavy gauge strings, You also need to widen the spaces withing the nut.
Unread 09-03-2010, 10:37 AM   #319 (permalink)
Originally Posted by captain tightpants View Post
I'm almost certain this is the same guy who went head to head with BCRGreg and claimed to have been given a bunch of Bugera amps at the Behringer factory.
If I recall, his last stay here ended similarly.
Last stay?...Okay then...
Unread 09-03-2010, 10:59 AM   #320 (permalink)
You had no right to cuss and that's why you got shown the door.
Unread 09-03-2010, 11:03 AM   #321 (permalink)
That's BS again. You tighten the truss rod after stringing the guitar.
Unread 09-03-2010, 11:06 AM   #322 (permalink)
I do it before to straighten it up, Then I slowly adjust with strings on, If I did it completely with the strings on I risk cracking the neck because of the thick strings And I cussed because I got pushed to it .
Unread 09-03-2010, 11:10 AM   #323 (permalink)
Unread 09-03-2010, 11:11 AM   #324 (permalink)
MLP Anchorman
Led Zep Fan's Avatar
One more flare up and you'll be going on a permanent vacation.
Led Zep Fan is online now   Reply With Quote
Unread 09-03-2010, 11:16 AM   #325 (permalink)
Sure, Laugh at something that works better than your stupid method
Unread 09-03-2010, 11:16 AM   #326 (permalink)
Yet it was your fault I flared up...Hmm
Unread 09-03-2010, 11:18 AM   #327 (permalink)
MLP Anchorman
Unread 09-03-2010, 11:19 AM   #328 (permalink)
Well done...Immature f*ck...
Unread 09-03-2010, 11:22 AM   #329 (permalink)
GP_Hawk's Avatar
And the survey says? bye bye
GP_Hawk is offline   Reply With Quote
Unread 09-03-2010, 11:23 AM   #330 (permalink)
Whatever old man
