MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Thread Tools Display Modes
Old 07-01-2010, 11:14 PM   #1
HarryScallywag
Les paul junior 50's wiring question
Hello all:
firstly let me apologize if his question has been answered before or sou ds dumb, but i have searched to know avail on the forums and have had no luck finding an answer...or maybe i am too thick to understand. In any event here are my questions
I have a 2010 les paul junior and wanted to have it done with 50's wiring.
My question is it it simply a matter of my guitar guy rewiring the existing componenets a certain way or will i have to purchase a new cap?
I realize the volume should be 500 and the tone 250 but is there certain brands or types i need to get? And finally does it have to be a bumblebee cap or can it be any cap with the same value (022/ 400v)
again sorry if these are dumb questions just wanted to know if i have to order a new cap or anything like that .
Thanks for any replies
HarryScallywag is offline   Reply With Quote
The Following User Says Thank You to HarryScallywag For This Useful Post:
Old 07-01-2010, 11:54 PM   #2
SG Lover 94
SG Lover 94's Avatar
Cool Re: Les paul junior 50's wiring question
You can do it with all the parts you already have, but many like to switch the pots to CTS as they are the best sounding, and have the nicest taper(to me).The tone cap can be any value you want that sound best to your ears, The higher the cap value the more treble is cut off, For single coils the standard is 0.47uF, for P-90s im not sure. below is a diagram of 50's wiring just disreguard the other volume and switch. Good Luck!
Correction: The way ive got my SG wired Yellow is to switch, and Red is Hot from pickup. not sure of the difference.
SG Lover 94 is offline   Reply With Quote
Old 07-02-2010, 07:35 AM   #3
Indyclone
Indyclone's Avatar
In a Junior you won't have a switch.
Use the above diagram and the yellow is your hot output and will connect to the center lug on your output jack.
Then run a ground wire from both of the pots to the outside connection on your output jack.
Of course assuming your Junior is already wired up, all you need to do to acheive 50's wiring is switch which lug the capacitor is connected to on the tone pot.
Modern has the cap connected to the center lug and the outside lug connected to ground. 50's has the capacitor connected to the outside lug and the ground from the center lug.
Indyclone is offline   Reply With Quote
Old 07-02-2010, 11:43 AM   #4
Dan
Dan's Avatar
Dan is offline   Reply With Quote
Old 07-02-2010, 11:44 AM   #5
Dan
Dan's Avatar
Old 07-02-2010, 11:54 AM   #6
HarryScallywag
Thanks so much for the diagrams....so i dont have to buy a new cap? Or do i need o e to get that 50's tone? Also do you know if the current 2010 ones like mine have the 500 volime and 250 tone pots?
Old 07-02-2010, 12:03 PM   #7
Indyclone
Indyclone's Avatar
I'd try just the wiring change first... then if you still want more, try a PIO cap, then if maybe you want your tone a little brighter try a 500k tone pot.
Old 07-02-2010, 12:04 PM   #8
Indyclone
Indyclone's Avatar
but no, I don't know what comes stock as a Jr tone pot
Old 07-02-2010, 12:49 PM   #9
lukemacauley
Mac Guitars
lukemacauley's Avatar
I build my Jr rigs with a CTS 500k volume pot, a 250k tone pot, a 0.022uF paper in oil K40Y-9 cap and a Switchcraft jack, wired together with vintage style braided wire.
Mac Guitars - Custom Wiring & Electronic Upgrades.
Sign up to the mailing list for an update on new products as they become available.
My eBay store: drumbrae4.
10% Sale—Mac Guitars—Guitar Electronics and Celluloid Nitrate Inlays.
lukemacauley is offline   Reply With Quote
Old 07-02-2010, 01:46 PM   #10
HarryScallywag
Just got off the phone with gibson, and stock les paul jrs come with 300 vol 500 tone, so im gonna switch both pots.. My guy suggested if i wanted to toss a lemon drop cap in there as well, anyone have any insight regardibg tossibg the lemon drop in there?
Old 07-02-2010, 02:11 PM   #11
Indyclone
Indyclone's Avatar
is a lemon drop cap like an orange drop but more sour/less sweet?
I'd go with a Paper in Oil cap... but that's me.
Old 07-02-2010, 02:12 PM   #12
Indyclone
Indyclone's Avatar
Why are you wanting to change the pots, is there a problem with them?
Something in particular you are looking to get out of new pots?
Old 07-02-2010, 02:22 PM   #13
HarryScallywag
I want the tone a little brighter plus if i am gonna do the 50s wiring i want the same variables (500 vol 250 tone)
Old 07-02-2010, 02:30 PM   #14
Indyclone
Indyclone's Avatar
for brighter, I'd think 500k on both would be what you'd want.
Old 07-02-2010, 02:42 PM   #15
HarryScallywag
Thanks for the advice , how would having the 500 tone impact the 50's wiring?
Old 07-02-2010, 02:51 PM   #16
Indyclone
Indyclone's Avatar
the 50's wiring really only affects one thing, In my experience... and that's that you won't lose any brightness when you lower your volume on the guitar.
You will lose a little volume when you turn down the tone.... sometimes it's not as noticable depending on the quality of the pots. It's basically a trade off.
Old 07-07-2010, 10:14 AM   #17
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
When I built the 50's style wiring Harness for my own LP Jr. clone I used a 10% CTS500K (550K specs)with a custom taper for the volume pot and CTS250K No Load Tone pot and a .022 400v Bumble Bee cap that had drifted a little dark. I have a Sheptone P-90 installed in this guitar and this wiring worked out good with it.
The No Load Tone pot gives you all the raw P-90 Tone, and then when you roll off the Tone control the Bee really sweetens it up. The P-90 is wound fairly hot at around 8.7K so the 500K Volume pot helps gets the most gain and clarity out of it.
Old 07-07-2010, 03:06 PM   #18
HarryScallywag
Wow thanks for all the tips guys! Im taking her in tommorrow to toss 500 cts volume pot and have the 50's wiringdone.... I might also change the cap depending on what my guy reccomends. I think im gonna change the tone also but probably the same value (500) just because i hear the cts ones are better than the stock. Im using super slinkys on her and she needs a truss adjustment as well.I will post results tommorrow night.
Old 07-07-2010, 03:31 PM   #19
whytheflyband
whytheflyband's Avatar
The 500K tone pot on a P90...just doesn't sound like a P90 to me. The originals were 500k vol and 250K tone. It really has that mid-range grind with this setup.
I wired mine with 500k vol 250k tone and a Jensen PIO and installed a Fralin P90. Sounds amazing. Very much like this JR here which is what I was aiming for)
Shawn
www.myspace.com/nobodysdarlingsmusic
1995 Epihone Sheraton II
Fender Tele
Greer Thunderbolt 30
whytheflyband is offline   Reply With Quote
Old 07-09-2010, 03:31 AM   #20
HarryScallywag
Ok so i went with a cts 500 vol and cts 250 tone.had to use the existing cap as he had no bumblebees( so that is my nExt project trying to get one). And did the 50's wiring .... Totally happy with it and i noticed a brightness increase in the tone because of the 500 k volume pot as xpected... I love ths gutar and it is now my number 1
Old 07-09-2010, 06:11 AM   #21
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Glad it worked out good for you, and I think using the 250K for the Tone pot vs 500K was the right choice
Old 07-09-2010, 12:27 PM   #22
snaredrum
snaredrum's Avatar
the '50s wiring really brightens the guitar up as well. i'm going to have to try these different pot values. anyone know a reasonably priced P90? my Jr got molested (humbuggered?) in the early 80s and i want to put him back to original. am terrified of paying a ton of money for a p90 though, for some reason
NYXL1152 Ravenclaw Nerd Squad
NYXL1254 Death Eater
offsets/floor thingies/solid state loudness
Electro-Harmonix can go to hell
snaredrum is offline   Reply With Quote
Old 07-09-2010, 12:30 PM   #23
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Originally Posted by snaredrum View Post
<snip> anyone know a reasonably priced P90? my Jr got molested (humbuggered?) in the early 80s and i want to put him back to original. am terrified of paying a ton of money for a p90 though, for some reason
MLPF member Zhang has a sale on hand-wound P-90's right now.
Old 07-09-2010, 12:34 PM   #24
River
River's Avatar
I'm very happy with my SD Antiquity.
Old 07-09-2010, 08:44 PM   #25
HarryScallywag
Soemthing i just notced: when i turn the volume down seems like the taper is uneven and when the knob is at "one". Its actually at "zero". Also theres seems to be a signifigant difference between "10" thru about "8" and then more of a very quck gradual taper to where the voulme dissapears completely at "1" and i had to turn the amp to r
Not complaining just making sure its normal .
Old 07-09-2010, 09:24 PM   #26
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
That could be partially due to the 50's wiring, but also the taper on your 500k pot. Is it an audio taper CTS and where did it come from? WD, Allparts, RS etc.??
Old 07-09-2010, 09:28 PM   #27
HarryScallywag
Its a cts pot i got at the shop thay did the wiring
Old 07-09-2010, 11:09 PM   #28
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
OK, just curious because CTS Makes 500K pots for a lot of people and they are all a little different as far as tolerance and taper goes. That's why I was asking.
Old 07-10-2010, 12:53 AM   #29
HarryScallywag
Cool no problem... After searhing and readi g all the 50's wiring threads i think that it is a result of the 50's wiring ... Just wanted to make sure. Thanks for alll the help!
Now i am contemplatig getting one of th faded sg's as well and having my tattoo artis paint some sort of custom mural on it.... I swore that this lp jr, wouldnt make me buy another gibson and turn me into a gibson guy but....
Old 07-10-2010, 03:34 AM   #30
whytheflyband
I have the original Gibson P90 that came out of my JR...Id sell it for a good price...its brand new. I installed a Fralin immediately as I got the guitar.
Shawn
Fender Tele
Forum Jump
