MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Thread Tools Display Modes
Old 06-30-2010, 08:10 PM   #1
cricket_mstr
Question Toggle Switch Issue on Epiphone Les Paul
G'day I'm new to this forum, so hello from Melbourne, Australia
I've had an Ephiphone Les Paul for about a year and a half now, but today was the first time I noticed the toggle switch messing up. For a while the bridge pickup was struggling to get any sound on the treble and middle setting. The neck pickup was also getting a fair bit of sound on the treble setting which it normally doesn't.
It was great that after I put it down for a while and picked it up later it started working back to normal, but I'm not convinced that I can rely on it not to mess up.
I reckon I'm good at playing guitar, but in terms of reworking a guitar's setup I'm an absolute beginner. I changed the strings on it for the first time yesterday (I'm not sure if this is related to the toggle switch problem or not).
I've read some threads about toggle switches and people talk about replacing it manually or cleaning it.
My questions are I guess: Is it worth it to open up a guitar when you don't know what you're doing? Is there a good website out there or thread that shows how to change a toggle switch? and may it just need a clean?
Cheers,
James
cricket_mstr is offline   Reply With Quote
Old 06-30-2010, 08:27 PM   #2
07LPStandard
Re: Toggle Switch Issue on Epiphone Les Paul
The switch is relatively easy to work on or replace. Simply remove the 3 screws of the switch cavity cover to access it.
If you know how to solder, then I reccomend buying a new Swichcraft switch and installing it. If not, I would take it to someone and have him install it. The stock switch is not very good and it's simply not worth cleaning.
'07 Epi Les Paul
-SD JB & '59/Gotoh bridge/Switchcraft toggle & jack/CTS pots/2 push-pulls for coil-split/Orange Drops/Reflectors/Schaller strap locks/Custom cavity covers/Removed gloss from neck, pup rings, poker chip, fretboard, TRC
'04 DSL401
-Bad Monkey/DS-1/Monster Cables/casters
07LPStandard is offline   Reply With Quote
Old 06-30-2010, 08:32 PM   #3
NoStatic
James- toggle switches seem a common failure on Epis. I fixed one for a friend recently- he had bought a new switch. It didnt fit. Be aware that the switch is a metric sized switch in an Epi- an Imperial (gibson or gibson aftermarket like switchcraft ) switch wont fit through the hole in the top of the git. You can widen the hole a little. Dont drill - use a file or sandpaper round a pencil, work from the back. Be careful.
But I fixed that one, possibly temporarily, simply with contact cleaner. Get a can of electrical contact cleaner, remove the backplate and hit the switch. Do the pots at the same time.
If that doesnt work, change the switch. Simple job- just get the right part.
NoStatic is offline   Reply With Quote
Old 06-30-2010, 08:32 PM   #4
TeleDog
TeleDog's Avatar
I had an Epi LP and the switch started giving me crap right away! So... replaced the darn thing with a switchcraft, problem solved.
They put some crappy parts on those Epis or so it would seem, so, you might as well go and get a new jack and new pots and caps while you're at it, if you wanna upgrade all those things and get rid of the less-than-quality stuff.
“Teledog. Telecasterus Fanaticus Dogius".
Got a Mac or iPod? Join our Apple Dogs group!
TeleDog is offline   Reply With Quote
Old 06-30-2010, 08:47 PM   #5
Raz59
Raz59's Avatar
Yep, same thing happened to my guitar. Some positions had low output even though the volume was on full blast. Now I have a long Switchcraft and seemingly no problems...
ἀ θ ε ό τ η ς
Raz59 is offline   Reply With Quote
Old 07-01-2010, 07:57 PM   #6
GerryL98
It should be covered under the lifetime warranty. Just bring it back to the dealer. They should be able to take care of it for you. I had an issue with toggle switch right out of the box. Just need to toggle back and forth every once in a while. I almost always use the bridge pickup so it doesn't really bother me that much.
GerryL98 is offline   Reply With Quote
Old 07-02-2010, 12:06 PM   #7
Dolebludger
Dolebludger's Avatar
In addition to my Epi LP, I have a number of other guitars. Some are higher-end brands, and I have owned some for in the 30 to 50 year range. I have found that using contact cleaner on these switches is sort of like changing the oil in your car. Just routine maintenance. I realize that a lot of Epi toggles have broken, so replacement is not a bad idea. But as your problem is intermittent, it sounds more like dirty contacts to me. And cleaning these is just maintenance.
'62 Gibson LP SG Standard
'09 Epi Goldtop LP P 90
Ibanez Artcore AF85 hollow body
Three Carvins
Custom Strat
Electra Strat type
Hondo Longhorn
Durango Guitar Works "Contender"
Sterling SUB AX3
PRS SE "Orianthi"
Michael Kelly Tele type
Soul Tramp Wraith
Genz Benz El Diablo 60 TS.
Bugera V22
Dolebludger is online now   Reply With Quote
Old 07-02-2010, 05:00 PM   #8
Dkr84
The toggle switches on Epis aren't the best. When I switch to neck pickup it occasionally doesn't put out sound. I just have to switch it to bridge then switch back.
Dkr84 is offline   Reply With Quote
Old 07-03-2010, 01:38 PM   #9
TinyBlackCat
TinyBlackCat's Avatar
I've this problem too. Have to keep switching it to make it work. However it tends to happen more at home then during jamming practices. I guess it's related to the larger force i used to change the switch during jamming.
TinyBlackCat is offline   Reply With Quote
Old 07-03-2010, 07:10 PM   #10
edselman
edselman's Avatar
I bought a new Epi Sheraton about two months ago and the switch is now starting to go. It seems like a common problem. While I am at replacing it, I will probably yank all of the electronics and upgrade. Love the guitar though.
edselman is offline   Reply With Quote
Old 07-03-2010, 07:18 PM   #11
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
The switches that come in the epi's are pretty cheap and upgrading them is a good idea if you plan on keeping the guitar. Also epi's are not wired up like a Gibson so when you upgrade keep that in mind.
I have also learned that the paint inside the epi switch cavity is often conductive, so if any part of the switch lugs or bare wires are touching the cavity it will cause a short. The switch craft switches are slightly bigger so you allow for that when mounting the switch in there. I normally take a needle nose pliers and carefully bend the switch tabs out to the sides to keep them from hitting the sides of the cavity.
Old 05-28-2012, 07:33 PM   #12
toa
Hi I have a problem my lp custom i got yesterday and when i put it from middle to rythem it makes a poping noise somtimes is it normal or should i get it replaced because its under warranty
toa is offline   Reply With Quote
Old 05-28-2012, 07:54 PM   #13
MyLeftyPaul
The Islander
MyLeftyPaul's Avatar
Hi toa, firstly, the thread is more than two years old. Imo, you just have to refer to this kind as reading material/reference. That being said, better create a new thread than resurrect this one. Anyway, just an advice.
Off to your question, switching it up and down should be making that popping sound like all other switches does. Unless when you switch it up/down and pops back to the middle, or worse it makes no sound, then it's a different story. But if it stays up/down when you switched it then you should be fine.
Gil
2003 R9 | 2010 V3| 2011 LP 100 | 2010 Takamine TAN16C| 2011 Backtop Stratocaster | Ibanez RG2550Z
MyLeftyPaul is offline   Reply With Quote
Old 05-28-2012, 08:09 PM   #14
Samantha
MLP Cub Reporter
Samantha's Avatar
could just be dirty, I find spraying a bit of lens cleaner (not water) into the top of the toggle and giving it a little work back and forth fixes it, if not I'm in melb too, if you feel like coming over to hoppers crossing I've got a couple spare toggle switches and I'll chuck a new one in your Epi for free.
EDIT: Wow, I just read how old this thread is
I play a stratamacasters.
Samantha is offline   Reply With Quote
Old 08-20-2013, 02:24 PM   #15
jimmy_jo
Originally Posted by MyLeftyPaul View Post
HUnless when you switch it up/down and pops back to the middle
I've got the same problem with my Firebird V. When I switch it down, it pops back to the middle. I've just noticed that the plastic tip on the bottom of the switch post that presses against the flanges doesn't press enough, that's why it pops back, I suppose. What should I do to solve this problem?
jimmy_jo is offline   Reply With Quote
Old 08-20-2013, 02:35 PM   #16
Barcham
Elitist Club Member
Barcham's Avatar
Try unscrewing your switch tip until it is higher than the collar around the switch. If that solves the problem, just stick a bit of paper or a broken piece of a matchstick in the tip and screw it down until it tightens up and is still above the rim of the switch.
'04 Epi Elitist '61 SG Faded Cherry
Roland Micro Cube
The Guitar Dater web site does NOT help you determine if a guitar is real or fake. It ONLY decodes the serial number according to a set formula. They have no database of guitars.
Barcham is offline   Reply With Quote
Old 08-20-2013, 03:25 PM   #17
jimmy_jo
How should I unscrew the tip? It is surrounded be these flanges. Sorry for being newbie and thank you for being helpful
Old 08-20-2013, 03:34 PM   #18
Barcham
Elitist Club Member
Barcham's Avatar
The tip is just a plastic cap that is screwed onto the switch shaft. Just grab it and unscrew it by turning it counter clockwise.
Roland Micro Cube
Old 08-20-2013, 03:49 PM   #19
jimmy_jo
Well, I unscrewed this. What's next? I can't understand, where should I stick a piece of paper or a piece of a matchstick
Old 08-20-2013, 03:57 PM   #20
Barcham
Elitist Club Member
Barcham's Avatar
Just unscrew it enough so that it does not interfere with the rim and see if the switch will stay in the proper position. If that seems to solve the problem of the switch returning to center, then stuff something into the tip so that when you screw it back into place and snug it down, it no longer comes in contact with the edge of the switch.
If you simply unscrew it a bit, the tip will be loose and will probably fall off and get lost.
Roland Micro Cube
Old 08-20-2013, 04:11 PM   #21
jimmy_jo
But it doesn't interfere with the rim even if the tip is not unscrewed. I unscrewed the tip and it is still pops to the middle. Are there any ways to solve the problem?
Old 08-20-2013, 04:16 PM   #22
Barcham
Elitist Club Member
Barcham's Avatar
Oh! In that case, I think your switch need to be replaced.
Roland Micro Cube
Old 08-20-2013, 04:49 PM   #23
MyLeftyPaul
The Islander
The wire in the switch is broken, so it pops back. If you are not sure how to remove and replace it but a crafty enough I think you can just put a thin wire (paper clip I think) in it. But you have to remove the switch first.
Gil
Old 08-21-2013, 03:44 AM   #24
NovaSDF
I would be very careful about bending the prongs on a Switchcraft switch. There will definitely be clearance issues. Did that once, to make it fit, and one of the prongs on the switch snapped off as soon as I started to gently apply pressure. Since the Switchcraft switches were a bit pricy, I was pissed for sure. Never had problems bending prongs on any other switch. Seemed like the metal in this one prong was really brittle.
I suspect it's better to enlarge the hole just a bit. There is plenty of lip where the cap will cover it, and lots of ways to safely file/sand a small groove for the prongs of the switch.
Two things you should never forget: 1 - The only time it's okay to work with amateurs is if you're making porn 2 - If you want to work with clowns, join a circus!
NovaSDF is offline   Reply With Quote
Old 08-22-2013, 06:12 PM   #25
jimmy_jo
Thank you people! I finally coped with the problem
Tags
toggle switch
Forum Jump
