MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Thread Tools Display Modes
Old 05-02-2008, 08:56 AM   #1
MJG
Best Straplocks for Les Paul
What does everyone think?
What looks best?
What are the most practical/do the job best?
I've never had strap locks. I know, I know its a sin More so seeing as I've played almost all the gigs I've ever done with my LP. Although I should say my guitar has never fallen from the strap except for one time in my house when I was holding the guitar up at a dodgy angle. Anyway (after reading countless threads here) it does seem that there is no good reason not to have them.
Will they just screw in easily though? I have a Les Paul Standard (from 2003). I don't fancy drilling new holes in my pride and joy if the new strap button is too big. And on the other hand if it's too small - I've seen this method of filling the existing hole with match sticks. I'm sorry but I just don't believe in that!
MJG is offline   Reply With Quote
Old 05-02-2008, 09:00 AM   #2
Cantu
Cantu's Avatar
Re: Best Straplocks for Les Paul
I like Schaller but Dunlop are nice also!
You shouldn't have to drill new holes!
Cantu is offline   Reply With Quote
Old 05-02-2008, 09:04 AM   #3
db1408
db1408's Avatar
Schaller, you wont have to re drill
db1408 is offline   Reply With Quote
Old 05-02-2008, 09:12 AM   #4
Belzeebub
Belzeebub's Avatar
schaller for style as well as function IMHO
2008 Gibson Les Paul Classic Heritage Cherry with Guitarforce Vintage '57s
2010 Fender American Standard Stratocaster Maple Olympic White
2006 Epiphone Dot Cherry
2009 Taylor 214CE
Marshall JCM 2000 TSL602 60W 2x12
Epiphone Valve Junior combo
Acoustic AG15
Digitech RP1000
Belzeebub is offline   Reply With Quote
Old 05-02-2008, 09:14 AM   #5
GibsonSlash
GibsonSlash's Avatar
I'm using pair of these, they do the job fine.
GibsonSlash is offline   Reply With Quote
Old 05-02-2008, 09:21 AM   #6
MJG
Currently I never put my guitar in it's case with the strap attached. The bass player in a band I used to be in had these really good looking strap locks and he just clipped his strap to his buttons each time we played. There was no need for unscrewing or having to arrange components with the strap and the button or any of that. Wish I knew what they were...
Old 05-02-2008, 09:43 AM   #7
General Disarray
They were most likely Dunlop or Shaller straplocks
I use the Dunlop ones on my LP because they just feel so much sturdier than the Schaller ones that can pull through the strap...
General Disarray is offline   Reply With Quote
Old 05-02-2008, 09:55 AM   #8
MJG
They may be practical but I don't think they look very attractive...
Stringsdirect - Online Guitar Strings and Accessories
Are these the Dunlop ones people are reffering to?
Old 05-02-2008, 10:01 AM   #9
GibsonSlash
+1
It doesn't look attractive at all, but what I like best is, I can still leave them intact with the strap when storing my guitar in the case.
Old 05-02-2008, 10:08 AM   #10
GibsonSlash
Is this something that your old bass player had?
Old 05-02-2008, 10:20 AM   #11
antei
antei's Avatar
ditto on the Schallers! Work great and look good too.
When the levee breaks, mama you got to move.
antei is offline   Reply With Quote
Old 05-02-2008, 10:24 AM   #12
Samantha
MLP Cub Reporter
Samantha's Avatar
just get schaller like everyone else and when ya do you'll understand why
I play a stratamacasters.
Samantha is offline   Reply With Quote
Old 05-02-2008, 10:40 AM   #13
MJG
+1
Thanks for telling me that because that's the opposite of what I want so I can rule them out
It does look similar. Was very handy and exactly what I need now.
Will I?? From what I found when I searched this forum many people had problems with their existing holes being too big or too small. And that you don't appear to be able to just clip your starp on and off (as I've seen with other locks) without faffing about with washers etc. And some of those JD ones do look nicer...
Old 05-02-2008, 10:42 AM   #14
sapi
sapi's Avatar
Location: Malta, somewhere in the mid of the Med Sea. Beyond that, everywhere & nowhere.
i like the classic dunlop cos they look a bit more... classic, not huge.
best,
jo
~ Shanti ~
"Without the buzz and the feel, we can go to sleep..."
sapi is offline   Reply With Quote
Old 05-02-2008, 10:42 AM   #15
Lyrica
Songwriting Machine
Lyrica's Avatar
i use ones very similar to that. don't even have to remove the screws from the guitar.
Lyrica is offline   Reply With Quote
Old 05-02-2008, 10:49 AM   #16
BluesZep
BluesZep's Avatar
+1 for Schallers!
http://www.youtube.com/blueszep
BluesZep is offline   Reply With Quote
Old 05-02-2008, 11:06 AM   #17
Cantu
Cantu's Avatar
These are good cause you don't have to change your strap buttons, the downside would be that they don't connect to the strap or guitar so you have to keep track of them, sorta like picks!
Old 05-02-2008, 11:09 AM   #18
Cantu
Cantu's Avatar
Never had a problem with them pulling through a strap if they are mounted correctly with the washers, that should never happen!
Old 05-02-2008, 11:13 AM   #19
Slapjaw
Slapjaw's Avatar
Looks like Dunlaps. I've got them on all my Lesters.
Slapjaw is offline   Reply With Quote
Old 05-02-2008, 11:13 AM   #20
General Disarray
As a strap leather loses it's ridigity the whole assembly can pass through SOME straps. I'm sure I have seen the same issue reported on this forum.
I got round it by drilling a new hole at the same OD of the assy or by using Levy's straps.
Another advantage of Dunlops is the strap button is similar yo a standard button and can be used without the straplocks.
Old 05-02-2008, 11:25 AM   #21
Cantu
Cantu's Avatar
The hole would have to be 3/4 of an inch to pull thru. If they are installed correctly and tightened down and checked occasionally, they should be fine.
Both Dunlop and Schaller are great products, can't go wrong with either!
Old 05-02-2008, 11:30 AM   #22
GibsonSlash
This will also act as an Emergency-Pick, if you had ever lost your final pick while gigging.
Old 05-02-2008, 11:34 AM   #23
Adwex
Adwex's Avatar
That's what I got, Dunlop.
I had to do the toothpick/glue trick to accommodate the smaller diameter screw, but now it's solid and strong.
Lot's of people loyal to the Schallers also. Personal preference.
Adwex is offline   Reply With Quote
Old 05-02-2008, 11:42 AM   #24
MJG
I'm actually swaying towards these now after what someone in the other thread (strap lock install) said about cracking the finish And also part of it is probably due to the fact that I don't really like changing anything about my LP unless I have to. All i've ever changed are the jackplate (cos the original plastic one broke) and my machine heads (something I now regret).
They're still ugly things tho!
Old 05-02-2008, 11:46 AM   #25
AndyC
AndyC's Avatar
I use the Schallers on all my guitars. There's no "faffing about" once the strap locks are on your strap and guitar. You just unhook the strap from the guitar - it clips into place. The only faffing is when you first put the strap locks on the guitar and the strap.
I've never had a problem with the Schallers, and I personally like the look. Nothing against Dunlops - again personal preference.
Historics:
2003 R9 "RoadWorn"
2006 R8 "Sweet Cherry"
2005 R7 Goldtop
2002 TV Model DC Jr.
Production Gibsons:
2006 Explorer
2004 Flying V
1986 Les Paul Custom
1973 Les Paul Recording
AndyC is offline   Reply With Quote
Old 05-02-2008, 03:16 PM   #26
Pellow
Pellow's Avatar
Schallers are excellent - I was in a similar situation to you - i did a lot of reading about this and found good reasons to go for either dunlop or schaller - the main thing that swung it for me is that Slash uses Schaller - If there good enough for him, there gonna be more than fine for me
Pellow is offline   Reply With Quote
Old 05-02-2008, 03:31 PM   #27
GibsonSlash
When using Schallers, do you keep the original strap button or has to replace with the Schallers Strap Buttons?
Old 05-02-2008, 03:37 PM   #28
stonevibe
stonevibe's Avatar
I use Warwick strap locks, fantastic strong and well built
stonevibe is offline   Reply With Quote
Old 05-02-2008, 03:39 PM   #29
Basman
Basman's Avatar
I used to have dunlops on my les paul until it dropped and broke the headstock...the dunlop mechanism failed on me @#$%$!!!! The schallers are double secure because your guitar really hangs in a cup.
Basman is offline   Reply With Quote
Old 05-02-2008, 03:47 PM   #30
diceman
diceman's Avatar
Thats exactly what I've worried about with the Dunlops (and why I use Schallers) - there IS NO SECONDARY RETENTION! If the lock mechanism were to fail on a Schaller, you're still fine. All you have to do is a quick check to ensure that the nuts are tightened down and you're safe.
As for the Dunlop plastic clips, I tried them for a minute, and on several of them (I'd gotten a few sets), the center ring popped out of the triangle base plate, rendering them absolutely useless.
Schallers are the only way to go in my mind.
Forum Jump
