MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Luthier's Corner
Thread Tools Display Modes
Old 03-29-2010, 02:20 PM   #1
RAHAZ
RAHAZ's Avatar
Florentine Les Paul?
I asked this question in the Les Paul area but thought some on there might know as well. Is there anyone on here with a Gibson Les Paul Florentine? The semi-hollow body type with F-Holes. What I'm looking for is the older one made in the 90's like this one:
I am in need of some gut shots, specs and/or measurements if it is possible. I own an Epiphone version of this guitar and love it but I want to try my hand at building one out of real woods vs. plywood.
Specifics: Perimeter and back thickness, What does the bridge support area look like through the control cavity? What do the pickup and control cavities look like on the inside?
If I can get enough information I will create a PDF file to aid anyone else wanting to make one.
1932 Gibson L-00 "Stacy" (Needs Restoration)
2003 Epiphone Les Paul Custom Elite "Elly"
2008 Epiphone J-200 "Noel"
???? Tacoma Acoustic-Electric "Ruby"
2011 Gibson SG 60's Junior
Under Construction
2008 Hilleboe 5-String Bass "Amethyst"
2010 Hilleboe Mjöllnir
2010 Hilleboe Redwood Mjöllnir
RAHAZ is offline   Reply With Quote
Old 03-29-2010, 03:16 PM   #2
Raz59
Raz59's Avatar
Re: Florentine Les Paul?
It's not exactly specs of a Florentine BUT I hope it helps - John Catto made some plans based of the '59 Les Paul and they're available on the net:
http://www.mondocatto.pwp.blueyonder...-ver10full.pdf
Originally Posted by John Catto
The measurements to go with the template
All measured with the usual digital caliper.
Body binding: height 5.96mm thickness ranged from 1.58mm to 1.91mm (for instance in the cutaway).
Neck binding: height 3.91mm thickness .84mm
Exposed body depth (from bottom of binding to back 42.9mm (1.688")
Headstock thickness top: 15.37mm bottom: (nearest nut) 15.58mm
Neck width: At nut 42.91mm At body Joint 54.82mm at fingerboard end 56.92mm
Gap between heel and guitar back 13.24mm (.52")
Depth of heel from bottom of binding (body top edge) to base 37.56mm (1.478")
One more for all those you wonder about toggle switch placement.
Level with 21st fret and 40.32mm from the edge.
ALSO
50's Humbucker Cavity depths
Bridge PU cavity legs: 1.384" deep
Bridge PU cavity depth: Angled from 1.015-.971(bridge side deepest)
Neck PU cavity legs: 1.463" deep
Neck PU cavity depth: 1.097"
ἀ θ ε ό τ η ς
Raz59 is offline   Reply With Quote
Old 03-29-2010, 03:40 PM   #3
RAHAZ
RAHAZ's Avatar
Thanks RAZ59.
Under Construction
Old 03-29-2010, 09:01 PM   #4
xsouldriverx
xsouldriverx's Avatar
maybe its just the binding but what you posted seems too round to be florentine
this is more like what i think of a florentine
i do really like the guitr you posted though. love pauls with f holes. it seems natural
Helvick Guitars
set-ups, tuneups, repairs & custom work
helvguitars@gmail.com
xsouldriverx is offline   Reply With Quote
Old 03-29-2010, 09:25 PM   #5
MikeGates
MikeGates's Avatar
I thought it was called an Elitist or something tho that effect. I am building a Spanish Cedar Cloud 9 LP with DC and thought since its already hollow on the inside to put f-holes on it. The f-holes look really nice on the LP, and its kind of a mesh of my favorite two guitars the ES-335 and the LP.
-Epiphone Les Paul Custom WR w Bigsby
-Takamine Acoustic/Electric Jumbo
-Oscar Schmidt Semi Hollow ES-335 style with Hot rodded Seymour Duncans (Getting stripped and put in a new guitar)
-Applause cheepy acoustic/electric
MikeGates is offline   Reply With Quote
Old 03-29-2010, 10:21 PM   #6
w666
w666's Avatar
Try Gibson "Bantam Elite"
"Life is like a box of bees......"
w666 is offline   Reply With Quote
Old 03-29-2010, 10:31 PM   #7
w666
w666's Avatar
Or, try "Florentine"
Old 03-30-2010, 03:56 PM   #8
RAHAZ
RAHAZ's Avatar
I agree, I love the F-holes on a Les Paul.
I say do it, that'd be sexy as hell.
Love it!
Under Construction
Old 02-14-2011, 11:19 PM   #9
Imsomaha
I just purchased a 2001 custom shop florentine. is there any ref sites to determine color. Prod run etc. mine is a solid color no burst. Honeysuckle I believe. There is just no info I have found. Ser. Cs11204. called gibson direct
Imsomaha is offline   Reply With Quote
Old 02-15-2011, 12:43 AM   #10
zontar
zontar's Avatar
I believe you mean solid wood--plywood is real wood--it's particle board & mdf that, while it contains what once was wood, that wouldn't be real wood--or at least pure wood.
But I get the point--sounds like a cool idea.
I've been a pilgrim on this earth since the day of my birth, I'm a long way from my home.
zontar is offline   Reply With Quote
Old 02-15-2011, 02:34 PM   #11
RAHAZ
RAHAZ's Avatar
I do not know of any database short of emailing Gibson customer service.
Yeah. I've started on a Semi Hollow build inspired by mt old guitar but it isn't a Les Paul. You can find the link in my signature. It's one of three current builds I am working on.
Under Construction
Forum Jump
