MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Thread Tools Display Modes
Old 03-07-2010, 03:26 AM   #1
pete
3 pick up les paul wiring
I want to wire up a 3 pickup custom for 3 volumes/ 1 master tone. Does anyone have their guitar wired this way that could post a pic of their wiring. I know that the diagrams are in the wiring thread but they are confusing. In this style, is the middle pickup on all the time? I want to get it so I can use the middle pickup with the neck, by itself, and with the bridge. Any tips would be great and please post pics if you have some. Thanks.
pete is offline   Reply With Quote
Old 03-07-2010, 06:57 PM   #2
pete
Re: 3 pick up les paul wiring
I tried using the wiring diagram from the sticky thread above, but now I have no sound. I don't understand how the hot jack lead is supposed to work. In the diagram it looks like it runs through the middle volume and the master tone po before it goes to the jack. Also, the stock Gibson historic wiring, the middle p/up lead went to the switch with half the shield stripped off, then it grounded to another lead coming from the switch, which went back to the pot. The diagram shows two of the prongs bridged together(I think), and then that wire weaves through the middle volume and the master tone on its way to the jack. The middle pickup lead then goes directly from the pickup to the pot? I am not very good at reading these diagrams, so any help would be awesome. Here is pic of what I have now:
Old 03-07-2010, 06:59 PM   #3
pete
The pots are: top right is bridge volume, top left is the master tone, bot right is neck volume, bot left is the middle volume. Also, the wiring diagram also says that the middle p/up is "out of phase" with the bridge pickup. This is not true, and I was told by Gibson that this was not the case with the 50's guitars either. The thin strat like sound produced by the middle/bridge combo is due to their close proximity to each other. This was news to me. Thanks in advance.
Old 03-07-2010, 07:38 PM   #4
dynabite
dynabite's Avatar
Can you point us to the the diagram you used ?
Originally Posted by Ilya-v View Post
Some people just too opinionated and biased (too brainwashed) to try something new even if its better.
dynabite is offline   Reply With Quote
Old 03-07-2010, 07:42 PM   #5
pete
I used this one:
Old 03-07-2010, 07:53 PM   #6
dynabite
dynabite's Avatar
I marked the hot wiring points from the jack, check again.
Old 03-07-2010, 08:37 PM   #7
pete
Thanks for the response. I guess I don't understand if the second and fourth prongs from the top of the switch, are wired together or are there two different leads, one for the middle pickup and one for the jack. The line just runs together in the diagram. Thanks.
Old 03-08-2010, 10:17 PM   #8
captainbraindamage
captainbraindamage's Avatar
Here's another diagram, hope it shows things better.
What I was thinking of doing was run 2 hot wires from the input, one to the tone pot and the other to the switch. Then for the middle pickup run a wire from the hot lug of the switch to the volume pot.
Haven't tried it yet, waiting on the pickups. Just my way of interpreting things.
She was built for comfort, not for speed.
captainbraindamage is offline   Reply With Quote
Old 03-09-2010, 10:47 AM   #9
pete
Why do these diagrams use the middle lug for the pickup lead when Gibson always uses the first lug?
Old 03-09-2010, 08:56 PM   #10
pete
Thanks captainbraindamage, your method worked like a charm. problem solved.
Old 03-09-2010, 10:00 PM   #11
captainbraindamage
Glad you got it going. At least I know now that it works. If things don't work when I do it, it'll be operator error.
Old 11-21-2012, 09:55 AM   #12
maxflex2
On these wiring diagrams of the switch. The switch I have has 3 posts either side,not all 6 in a row. What colour wire from switch is used for what pickup? Switch has red,black,yellow on one side,and green,blue,white on the other. Having a hell of a time wiring the LP. Seems I always get middle pickup working but none of the others. Any help would be greatly appreciated..thx.
maxflex2 is offline   Reply With Quote
Old 11-21-2012, 06:05 PM   #13
DPaulCustom
DPaulCustom's Avatar
I found this diagram, may suit what you're trying to do
I play like I shvt, slow & sloppy
DPaulCustom is offline   Reply With Quote
Old 11-23-2012, 03:49 AM   #14
J2011
Here is how I wired my 3 humbucker epiphone les paul (switchcraft switch).
http://www.mylespaul.com/forums/tone...ring-work.html
There are some in-progress versions of the diagram on that thread, so be sure to use the final version (if you decide to go this way).
The wiring has 3 volumes, 1 master tone. It enables the following combinations: Neck, Middle, Bridge, Neck - Middle, Neck - Bridge, Middle - Bridge, Neck - Middle - Bridge, None (mutes the guitar). So you can combine the humbuckers any way you want.
In addition I have done (lately) a treble bleed mod (designed by Aki) for this. http://muusikoiden.net/dyn/articles/706.jpg
J2011 is offline   Reply With Quote
Old 11-26-2012, 04:56 PM   #15
lineboss58
lineboss58's Avatar
I believe the gibson three pickup sg custom is wired in just this way, none of the three pickup les paul customs are but someone may know different.
lineboss58 is offline   Reply With Quote
Old 01-08-2015, 03:25 PM   #16
LpCustom2007
LpCustom2007's Avatar
I recently used this diagram for my 3 pickup LP, thanks!
Now Iīm wondering, can I obtain 50īs wiring by just changing the pickup hot leads from the middle lug to the left lug on the volume pots, or do they have to interact with the tone pot in a specific way to get the 50īs wiring effect?? I.E is 50īs wiring obtainable with this kind of diagram?
Thanks!!
LpCustom2007 is offline   Reply With Quote
Old 01-09-2015, 06:40 AM   #17
LpCustom2007
I also get some weird leekage with this wiring. When switch selector on bridge, bridge volume on zero and neck volume on full, I still get a low signal of the neck volume leeking through. This canīt be right, can it?
Forum Jump
