MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > The Custom Shop
Thread Tools Display Modes
Old 03-19-2008, 02:44 PM   #1
GuitarFace
GuitarFace's Avatar
Dyeing a rosewood fingerboard to ebony?
Has anyone done this?
I am thinking about doing a full blackout on my 05 standard. I thought I would check and see if it's an option. If there is a chance that it will ruin it then I will pass. It's not worth it. Option B is to get the board replaced with ebony. But that is 250 and he says he cant be sure the binding will match up. Thanks for any help.
GuitarFace is offline   Reply With Quote
Old 03-19-2008, 04:12 PM   #2
5F6-A
5F6-A's Avatar
Re: Dyeing a rosewood fingerboard to ebony?
Why would you do that?
if you dye it nothing will change sonically. it'll look darker and that's that. Also it might leave a nasty black trace on your fingers as you play.
if you have it swaped for ebony the tone will be brighter; you might like it or you might hate it. Too risky and too expensive IMO.
My option: get some Fret Doctor and give that rosewood board a treat. It'll look better, it'll play better and it'll authentic. Plus it'll won't be too expensive.
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
5F6-A is offline   Reply With Quote
Old 03-19-2008, 04:56 PM   #3
GuitarFace
GuitarFace's Avatar
Old 03-19-2008, 05:09 PM   #4
stryker59
stryker59's Avatar
id leave it alone or go w/ the recommendations above! to much risk to mess with/ it to much!
you've been weighed, measured, and found wanting!
stryker59 is offline   Reply With Quote
Old 03-19-2008, 05:53 PM   #5
WildeStarr
WildeStarr's Avatar
Thumbs down Re: Dyeing a rosewood fingerboard to ebony?
WildeStarr is offline   Reply With Quote
Old 03-19-2008, 07:19 PM   #6
Mike60
Mike60's Avatar
you can dye it or stain it if you wish,but eventually you will be wearing it on your hands...
Old 03-20-2008, 10:59 AM   #7
GuitarFace
GuitarFace's Avatar
Originally Posted by WildeStarr View Post
nice.
Looks like my kids cat when I shut the door on it's tail. That cat still hates me. I feel the same.
Old 03-26-2008, 11:16 PM   #8
taypeng
taypeng's Avatar
I did think of the same thing too but I've never tried it. i'm just oiling the fretboard now and it darkens a little so im pretty satisfied..
taypeng is offline   Reply With Quote
Old 03-26-2008, 11:31 PM   #9
ArchEtech
ArchEtech's Avatar
clean of the fret board. Use a black water based dye. Go to the Woodsmith store - get premium dye. Ask about wood prep, them may have some tips on preparation.
I used some black dye on a charvel neck through. The rosewood was way too light, and the grain too open, and just looked terrible on the jet black body. I used water based dye, then top coated it with ebony minway stain (thinned with mineal spirits)
It looked killer, and I never had any of the dye come off on my fingers. The key is making sure the fret board is really clean. I used a tooth brush and some rubbing alchy to get finger scum, and oils out of it. Then I wiped it down with a damp cloth a few times (don't saturate the wood). Then applied the dye, let it dry for an hour then then stain. I never had any problem with it. It looked great. I don't know that I'd try it with a $3000 guitar, but if you dye it too dark you can wash it out with water before it is dry. Start with a diluted dye so you don't go too dark. You can always add more powder and make it darker. Just take your time, don't make a mess, and start very light until you get a shade you like. Then seal it with a stain.
I also got a nice piece of scrap wood and practiced before I stained a whole guitar. You might consider that as well.
2007 Les Paul Custom
2007 Jackson RR1T Mike Shannon
2007 61 SG reissue Classic White
2008 Fender Custom Classic V-Neck Daphne Blue
2003 MIM Strat Faded Green Metalic
2010 Les Paul Tribute
A couple of Alvarez Acoustics
AMPS: Vetta II, VOX AD60VTX, Micro Cube
ArchEtech is offline   Reply With Quote
Old 03-26-2008, 11:32 PM   #10
ArchEtech
ArchEtech's Avatar
Not true. I've tried this and never got any on my fingers. Not a smudge. You just have to use diluted dye and stain, and let everything dry.
Old 03-27-2008, 07:51 PM   #11
Weldaar
Weldaar's Avatar
If you want an Ebony fret board, buy a different guitar. Dying it won't change the tone or playability.
Play your guitar, dye something else.
God Bless
Weldaar is offline   Reply With Quote
Old 03-28-2008, 10:14 AM   #12
dwagar
dwagar's Avatar
Stew Mac sells dye, but it's the same stuff you can pick up at a shoe repair shop, it's leather dye.
I think they use it to touch up ebony boards, I don't know what it'd look like on a rosewood board.
dwagar is offline   Reply With Quote
Old 04-01-2008, 02:02 AM   #13
3dmac
3dmac's Avatar
I will be doing this after the buff out of my project. Dying is done with a lot of ebony due to mineral streaks.
http://www.mylespaul.com/forums/luth...here-i-go.html
3dmac is offline   Reply With Quote
Old 04-01-2008, 02:16 AM   #14
Eddie
Eddie's Avatar
Basically, it will slightly darken the rosewood, but not really alter the color much. I used it after testing it on a rosewood box I have and it worked fine. I have a guitar with a prominent "skunk stripe" down the board and I dyed around the darker stripe to blend it some. Worked really well, but care needs to be taken to keep the dye off the binding harder to clean off there. I carefully applied the dye around the fret markers and binding and rubbed it off with a clean cloth after a few seconds. Mine looks much better now and has not come off on my hands after much playing. From 2 feet away, the skunk stripe is all but invisible.
Chicks don't care how long your tenon is, just that you know how to use it...
Eddie
2003 Faded DC Special
2003 B7 Custom Black Beauty
2004 R7
2006 Explorer
Join the Black Beauty Rockers!
http://www.mylespaul.com/forums/grou...y-rockers.html
Eddie is offline   Reply With Quote
Old 04-01-2008, 03:03 AM   #15
LoKi
LoKi's Avatar
Almost all current ebony on production guitars is dyed somewhere. Ebony is getting harder to find in its best looking form.
You can dye rosewood if you want a full blackout effect for your guitar. Don't listen to anybody about tonality and all that other stuff... It won't change the guitars tone at all, but it will make the fingerboard black, which is what you seem to be after going by your first post.
Those of you who think it'll come off on your fingers... Does your deck or hardwood flooring ever come off onto your feet? It's STAIN... Not paint. It goes into the grain of the wood, the only way to get it out of there once applied is to sand the wood down past the stained depth.
LoKi is offline   Reply With Quote
Old 04-01-2008, 11:20 PM   #16
3dmac
3dmac's Avatar
Just completed dying my project today and it came out great. A little scrapin the nut and markers and all was well. Now to continue spraying the nitro.
Flame on !
Old 04-01-2008, 11:44 PM   #17
bigalthethird
bigalthethird's Avatar
As some dude already said, Fret Doctor is the first thing I do to everything I own, and I keep them oiled regularly. It makes the wood about 400 times prettier, smoother and prettier.
bigalthethird is offline   Reply With Quote
Old 04-02-2008, 12:29 AM   #18
ArchEtech
ArchEtech's Avatar
Like I said I've done it myself. Turned out great no problems, and doesn't come off on your fingers - just let it dry and rub it out with a cloth.
Old 04-17-2008, 12:28 AM   #19
3dmac
3dmac's Avatar
This is what it looks like when done. And doesn't rub off on your fingers when done
http://www.mylespaul.com/forums/luth...tml#post125783
Old 07-14-2009, 07:37 PM   #20
monami
monami's Avatar
it seems some here have never used this stuff...so why bother "helping."
anyway i have an epi g400. it seems to be rosewood dyed very dark like ebony? if so i need this stuff after an inlay job and sand down?
monami is offline   Reply With Quote
Old 07-14-2009, 09:53 PM   #21
djwilbanks
djwilbanks's Avatar
I used the fiebing's dye that stewmac
sells. Check my thread on my BFG refinish.
I live my life one gif at a time. Nothing else matters: not the mortgage, not the store, not the forum and all its bull****. For those ten seconds or less, I'm free.
djwilbanks is offline   Reply With Quote
Old 05-19-2011, 11:29 AM   #22
DanL
DanL's Avatar
Not sure I understand the logic here. I suppose you don't like the bodies of guitars to be finished either? A lot of rosewood on epiphones and other cheaper models that don't employ real ebony dye it for this effect. Is it wrong even if the manufacturer does it? hmm
There are 10 types of people in this world, those who understand binary and those who don't.
Shacktown Music
DanL is offline   Reply With Quote
Forum Jump
