MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks
Thread Tools Display Modes
Old 03-16-2008, 04:46 PM   #1
Fixxxer
Fixxxer's Avatar
Wiring a three way switch (Help guitar tech's)
Can anyone help me out?
One of my guitars was basically raped at the last shop I brought it too. I think they used the EMG 3 way toggle, anyway, it was the sh!tiest wiring job I ever saw. Had I not spazzed out, I would have taken pictures.
Anyway, can somebody point me in the direction of a wiring diagram for a three way switch?
Specifically, how do I know what wire goes to the neck, and what goes to the treble?
Also, what type of wire do I need to connect all the pots together on the outside?
Finally do I need to ground the tail piece to the neck volume pot?
Please help...:confuse d:
Everything turns into something else.
Fixxxer is offline   Reply With Quote
Old 03-16-2008, 06:09 PM   #2
FLICKOFLASH
FLICKOFLASH's Avatar
Re: Wiring a three way switch (Help guitar tech's)
did you look here ? :
http://www.mylespaul.com/forums/tone...g-library.html
FLICKOFLASH is offline   Reply With Quote
Old 03-16-2008, 06:31 PM   #3
Fixxxer
Fixxxer's Avatar
I did, it was very helpful. In fact the modern diagram s basically taped to the baseplate of my lamp.
How do you wire a 3 way switch on a lester?, and
what wire(s) go to the jackplate.
I am basically a novice when it comes to wiring, unfortunately the guy that re-wired my custom, did a bad job.
Also for a cust will any size 3 way switch work? (they sell long and shorts)
Old 03-16-2008, 06:39 PM   #4
Fixxxer
Fixxxer's Avatar
Was looking here: Guitarelectronics.com Inc. Universal Wiring
Can anyone share pictures?
Old 03-16-2008, 06:46 PM   #5
FLICKOFLASH
I would say you need a long switch
Old 03-16-2008, 06:51 PM   #6
FLICKOFLASH
Old 03-16-2008, 07:00 PM   #7
FLICKOFLASH
Old 03-16-2008, 07:13 PM   #8
Fixxxer
Fixxxer's Avatar
Can I ground the lug to the input jack and be OK? Some verbal response would work instead of all the pics.
Old 03-16-2008, 09:25 PM   #9
FLICKOFLASH
not sure what you mean by lug but any grounding points are connected & should be fine
Old 03-16-2008, 09:58 PM   #10
captainbraindamage
captainbraindamage's Avatar
This shows a switchcraft type switch with shielded wire. Push the two hot wire lugs together and solder the hot wire. Then use a pigtail for the ground from the middle lug on the switch and wrap it around the shielded wires and solder all together.
She was built for comfort, not for speed.
captainbraindamage is offline   Reply With Quote
Old 03-16-2008, 10:54 PM   #11
Fixxxer
Fixxxer's Avatar
How important is it to ground to the bridge of a les paul?
Old 03-16-2008, 10:56 PM   #12
WBPickups
Guest
Posts: n/a
ground it..
Old 03-16-2008, 10:59 PM   #13
FLICKOFLASH
Have you ever had your lips shocked with 120 volts off a microphone ...I have !!!
Old 03-16-2008, 11:27 PM   #14
Fixxxer
Fixxxer's Avatar
oh man hommie..
No, and I don't even want to know what that is like.
Thanks for the feedback guys, I have some work to do.
Last questions, what type of wire is ground wire? Can I use basically anything?
Old 03-17-2008, 12:19 AM   #15
captainbraindamage
I use 22 gauge. It has the plastic insulation on it that I strip off where I need to.
Old 03-18-2008, 09:52 AM   #16
Sinmastah
Epi Verification Expert
Sinmastah's Avatar
How do you ground something to the bridge, I thought you can just ground it to the top of the pots?
Epiphone Elitist SG Faded Cherry(Jonesey'd and WB'd)
Epiphone Elitist SG Faded Brown (EMG's)
Epiphone MIJ Les Paul Ebony LQ
Fender Mexi Oly White Strat
Squier Natural Vintage M Jazz bass
Peavey Classic 50
SG's FTW
Sinmastah is offline   Reply With Quote
Old 03-18-2008, 11:37 PM   #17
Fixxxer
Fixxxer's Avatar
agreed, pictures please
Old 03-19-2008, 12:46 AM   #18
FLICKOFLASH
all electric guitars are grounded to the bridge or tail maybe except EMG equipped guitars
Old 03-19-2008, 12:57 AM   #19
Fixxxer
Fixxxer's Avatar
how do you get the wire from the bridge to the pot?
Old 03-19-2008, 01:05 AM   #20
FLICKOFLASH
should be a hole that runs to the tail bushing hole .Need to pull the bushing
Old 03-19-2008, 06:58 AM   #21
Bowhunterwt
Bowhunterwt's Avatar
If you have EMG's active pickups (one that requires a battery) DO not ground to the post. If you have passive EMG's (the one that don't required battery) you have too ground
And the Meek Shall Inherit the Earth
Rush 2112
http://www.myspace.com/blackdungeoninc
2007 Gibson Les Paul Classic Zebrawood
2007 Brian May Red Special
1995 Fender Strat w/Lace Sensor Gold PUPS
Dean Accoustic
Fender P-bass 60th Anniversary Model
Bugera 333XL 212 Tube Amp
Fender Bassman 250 head with 4x10 Cab
Bowhunterwt is offline   Reply With Quote
Old 06-19-2008, 06:16 PM   #22
Frit
Frit's Avatar
This is a great thread, and I have all of the above schematics. However, I have a 3 pickup LP Custom that I was modifying to 3 volumes 1 tone. The customer decided they didn't want the guitar, so I went to restore it. I had meticulously drawn all of the connections....except to -- am I a bonehead -- the switch. It's a 3-way toggle, but it has an extra leaf that I haven't seen on a 3 way toggle. I've rewired the whole thing, but I can only get the neck pickup to make a sound. WTF am I doing wrong?? Can I rewire to a regular 3 way toggle? Is there some extra connection that I don't know about?
Sorry for all the questions, but this is driving me bat****.....
Thanks,
Frit is offline   Reply With Quote
Old 06-20-2008, 11:24 AM   #23
Big John
korina is good
Big John's Avatar
Frit, you say it has an extra leaf. In the schematic already posted for this mod (3 vols/1 tone), the extra leaf isn't being used. Also, since you're not getting any signal from the bridge and middle pups, that means those signals are getting shunted to ground through resistance. You might want to re-check the wiper connections on all the pots, and make sure everything is going to where it's suppossed to.
Also, a pic is worth 1,000 words. If you can post a clear jpeg of what you have, that may help.
Big John is offline   Reply With Quote
Old 06-22-2008, 05:03 PM   #24
Buffleheid
Thanks,
holy crap thats the exact thing that happened to me...
now im redoing the connections following this instead.
GuitarElectronics.com WDU-HHH3T22-01
should be interesting...
Buffleheid is offline   Reply With Quote
Old 07-01-2008, 05:44 PM   #25
Frit
Frit's Avatar
Thanks for the replies-I'll try to post a pic of what's going on. And thanks for the schematic, I have that one, too, but the toggle is different on the guitar I am working on.
Old 03-31-2011, 07:59 PM   #26
gadgetfreak
Hello Gentleman,,
I have just purchased a pre-wired switchcraft switch and Jack,etc... I understand and have directions on what to do except for 1 little point.
On my switch I have a wire labeled white which is supposed to be soldered to the hot lug on the output Jack. Do I have to soldered the braided outer jacket to the other lug? Or does the lug only need one wire connected because I have another wire labeled black that is my ground that is going to a pot. Make sense??
My current epi output jack has 2 wires connected, 1 on each lug but this new switchcraft only has 1 wire labeled for the jack so I just want to be sure.
I'm laying it all out before I even break the soldering Iron Out, Doing it right this time.
Thanks in advance for any help, Yes I have read all wiring pages but this is a unique question to my particular jack and switchcraft I guess. Thanks
gadgetfreak is offline   Reply With Quote
Old 03-31-2011, 08:11 PM   #27
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Your output jack has a hot lug that goes to the tip + and another lug that connects to the inner sleeve that is ground-
If you are using the vintage braided wire the outside shield is ground and the inner lead is hot. Solder braided to ground lug and inner lead to hot lug on output jack
Old 03-31-2011, 08:18 PM   #28
gadgetfreak
Thanks Jonesy,, I just read in my directions under vintage wiring that they provided a seperate wire coming off the switch with black tape marking it and it says to wire the tip and the outer braid to the pot they have marked, Then they said to just use wire marked with white and connect just tip to output jack,, seem's wierd to me not having something on that other lug, does that make sense?? I understand what you said, I'm just trying to explain what I just read in my directions. Thanks again, let me know if that doesn't make sense
Old 03-31-2011, 08:29 PM   #29
jonesy
GLOBAL WIRING GURU
jonesy's Avatar
Output jack has to have hot from switch and ground to back of pots. Not sure what type of switch wiring you have, you could always contact whoever you bought it from if you are note sure how to install it
Old 03-31-2011, 09:55 PM   #30
gadgetfreak
I have the switch in and all the wire's fished, I am putting in the assembly now, have to soldered the pup's and couple other thing's and will see how she sound's.
For the hell of it I am wiring in the original epiphone pup's to see how they sound with a real wiring harness, I'm using all bournes 500k pots, vitaim T caps etc.. If I don't like the pups after this it will be because I don't like the pickups and not because of cheap korean electronics.
THis epi was made in Korea in late 90's, plus top great neck, worth me doing all of this. Thanks again
Forum Jump
