MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Thread Tools Display Modes
Old 12-31-2007, 01:06 PM   #1
LesPaulHDXPro
Does hanging a guitar from the neck/headstock do damage?
Here's something that has puzzled me for quite some time about guitar stores and the way that they hang or display their priceless guitar on a hook wrapped around the neck/headstock of a guitar.
A LP weighs about 8 to 11 pounds, depending on the model, size, # of pickups, tremolo, etc., not to mention the amount of tension from the strings which may counteract the weight, but who knows?
So why do they insist on hanging these guitars from the neck/headstock area and add added stress to this area of the guitar? Isn't there a better way to hang these guitars that doesn't put so much stress on that particular area?
How many guitars have you seen where the neck/headstock area is damaged or the finish has marred due to the anchor around that area? To me, this is a waste. Plus, those hangers are a bit dangerous and one bad move and the guitar can come crashing down and ruin a guitar.
Somebody has got to come up with a better way to display and hang these marvels of beauty. Any ideas or inventors out there?
I just cringe when I see a $6k Les Paul AAAA-top hanging on a display like that! If that were my guitar, I would hold it from the body and never put weight or stress on that part of the guitar. Makes no sense to me.
Comments?
LesPaulHDXPro is offline   Reply With Quote
The Following User Says Thank You to LesPaulHDXPro For This Useful Post:
Old 12-31-2007, 01:20 PM   #2
ArchEtech
ArchEtech's Avatar
Re: Does hanging a guitar from the neck/headstock do damage?
Well if guitar stores do it with $7000 guitars 20feet off the ground, then I guess I can trust it's ok to do at home. I don't know about finish issues, I myself put a polishing rag on the hook then the guitar so that it doesn't contact the finish. As far as the structural issue, I don't know I guess. I will say that they sort of seem to stay in tune better sitting on a stand, but I don't know if its a "real" correlation. I hear what you're saying though. When you think about it, it probably isn't the best because you are putting tension on the truss rod the more bow you have in the neck. I'm planning on using wall mounts soon that actually hang the guitar sideways so as to not put tension on the neck. I think its pretty safe, but maybe not the best. Long term, who knows but again since all guitar stores do it, it can't be that bad. When you see a $7000 Les Paul or a $3000 Martin acoustic hanging on the wall, You'd thin like I said it can't be that bad.
2007 Les Paul Custom
2007 61 SG reissue Classic White
2008 Fender Custom Classic V-Neck Daphne Blue
2003 MIM Strat Faded Green Metalic
2010 Les Paul Tribute
A couple of Alvarez Acoustics
AMPS: VOX AD60VTX, Micro Cube
ArchEtech is offline   Reply With Quote
Old 12-31-2007, 01:30 PM   #3
Roman
Master Luthier V.I.P.
Roman's Avatar
Guitars are more durable than people think.
Factories build guitars for profit, Luthiers build them for players
Roman is offline   Reply With Quote
Old 12-31-2007, 02:42 PM   #4
red2rider
I've got ibanezes with very thin wizard necks and the guitars are fully loaded with 3 pickups, floyds and straps hanging on them for more than 6 months, not any issues so far. I love the wall hangers for ease of access, but I don't hang my custom on em. When I go after it, it's coming out of the case. I keep it there just for more safety and security....
RB.
red2rider is offline   Reply With Quote
Old 12-31-2007, 03:48 PM   #5
Axeman16
Axeman16's Avatar
i only hang my guitars with bolt necks.
Axeman16 is offline   Reply With Quote
Old 12-31-2007, 04:00 PM   #6
GibsonGuitars119
GibsonGuitars119's Avatar
Ive been hanging my guitars for a couple years now, nothing happened yet, but im going to put a polishing rag around the hanger, so it doesnt do anything to the finish, like ArchEtech said.
KB-GIBSON
GibsonGuitars119 is offline   Reply With Quote
Old 12-31-2007, 05:36 PM   #7
LoKi
LoKi's Avatar
This is absolutely true. Ever see a baseball bat warp after being thrown in the closet or garage for winter? Wood is tough. People build houses out of it, I'm sure it can handle holding its own body weight.
LoKi is offline   Reply With Quote
Old 01-01-2008, 09:03 AM   #8
Pushead
Pushead's Avatar
The tension of the strings is so high that the additional stress of holding it's weight isn't noticable.
Pushead is offline   Reply With Quote
Old 01-01-2008, 09:32 AM   #9
scozz
There is very little stress on the headstock from hanging. Most headstock damage is caused from a blow to the upper backside of the headstock where the serial# is. Also, (something you should never do) if you rest your LP on the floor flat with no support under the body, the weight on the headstock is much, much more likely to cause damage compared to hanging.
scozz is offline   Reply With Quote
Old 01-01-2008, 08:55 PM   #10
BobbyK
BobbyK's Avatar
very true.
I only cringe when I see a les paul laying on it's back !
I put a pillow under the neck, to keep the headstock off the ground. or bed.
BobbyK is offline   Reply With Quote
Old 01-01-2008, 09:00 PM   #11
im_b0r3d_
im_b0r3d_'s Avatar
Originally Posted by BobbyK View Post
very true.
Would it be fine to put it upside down?(like on a bed) Whenever mines out of the case its in my hands, but I'm wondering now. I've got friend that always rests his guitar on things with the strings touching. Then again, he is the friend with a $500 guitar with no hardshell case.
im_b0r3d_ is offline   Reply With Quote
Old 01-01-2008, 09:34 PM   #12
stryker59
stryker59's Avatar
one thing i did notice on my classic was two divots on the headstock veneer where it hung in the store. but i dont think thre are any concerns as far as it supporting its own weight!
stryker59 is offline   Reply With Quote
Old 01-01-2008, 10:09 PM   #13
Samantha
MLP Cub Reporter
Samantha's Avatar
Comments?
for one your lucky their about 9-12 grand over here in australia and i hang all my guitars on wall hangers and i have seen no problems what so ever i would be more worried about having guiatrs on a guitar rack leaning it on one side on the neck its liable to bend the neck sideways under the weight of the guitar over a long period of time at least hanging the guiatr keeps the neck straight.
i'v seen headstocks snapped allong the middel from the stress of the strings allone allong witht he headstock compleatly snapped off from the tension of the strings.
it is allways best to stoore your guitar in its case when your not using it.
but guitar stoors arent going to spend tonnes on guitar racks that just support the body. my gibson dealer has all of their guitars hanging on hooks which lock and wrap around the neck at the headstock but they cost a fair bit and take a bit to get the guiatr off the wall. imagine all the space you would need if they used floor stands that supported the bottom and back of the guitar.
I play a stratamacasters.
Samantha is offline   Reply With Quote
Old 01-01-2008, 10:31 PM   #14
coldsteal2
coldsteal2's Avatar
I just yesterday watched the videos about the Stradavarius
violins and a luthier said the worst thing that musicians do
was hang thier instruments up by thier neck and heads,
so maybe the same advise would be good for guitars???
Maybe thats only because a violin is so small though
coldsteal2 is offline   Reply With Quote
Old 01-01-2008, 11:39 PM   #15
WildeStarr
WildeStarr's Avatar
Yeah, well that STRAD guy is dead, so what the hell does he know.
WildeStarr is offline   Reply With Quote
Old 01-03-2008, 06:05 AM   #16
Samantha
MLP Cub Reporter
Samantha's Avatar
strad-who-varius?
Old 01-12-2008, 11:35 AM   #17
mojofilter
mojofilter's Avatar
as long as I have been playing i have never seen anything happen to a guitar unless it fell out the hanger /which is not likely
mojofilter is offline   Reply With Quote
Old 01-04-2010, 12:29 PM   #18
mmk8283
Hi there, I was thinking about hanging my guitars and was worried about these same issues. I am a mechanical designer and I think I might design my own style of hanger. any input will be considered, I'm planning on using the lower strap hook and supporting the guitar mainly from the bottom. I will be sure to share what I come up with.
mmk8283 is offline   Reply With Quote
Old 01-04-2010, 12:36 PM   #19
bullpentherapy
bullpentherapy's Avatar
i have had many a problem haging mine i went back to a 7 guitar syand after three day experiment i am tellin you its just better to keep any tension off the joint!
bullpentherapy is offline   Reply With Quote
Old 01-04-2010, 12:43 PM   #20
LPGeoff
LPGeoff's Avatar
I doubt it hurts them as long as wall hangers have been around.
The Alpine White Les Paul I saw at GC had black stains in the finish from the hanger that wouldn't rub off.
It's never as good, or as bad, as it seems...
LPGeoff is offline   Reply With Quote
Old 01-04-2010, 12:53 PM   #21
twinrider1
twinrider1's Avatar
Going to have to call BS. What could possibly happen to a guitar hanging on a hook for 3 days?
Some dealers hang their guitars by string around two tuning pegs! If that doesn't hurt a guitar, hanging by the neck isn't (assuming the material is lacquer-safe)
twinrider1 is offline   Reply With Quote
Old 01-04-2010, 02:18 PM   #22
LedZepRulz
Look at it this way, it can't possible help to hang a guitar by it's headstock, it can only hurt. Why take the chance? I leave mine on stands with seatbelts as upright as possible without tipping forward so there is almost no pressure on the neck at all. I've always wanted to hang em to conserve space and cause it looks cool, but I'm afraid
LedZepRulz is offline   Reply With Quote
Old 01-04-2010, 03:06 PM   #23
Shane
Shane's Avatar
Forgive me for working in Metric but it's what I know.
The problem is that the weight force acting upon the joint is a component of the force acting vertically and horizontally on the headstock. I'm going to assume a 17 degree headstock angle since this is the Gibson section.
m = 5kg (approx assuming 11lb)
g = 9.81 ms^-2
mg = 5*9.81 = 49.05 Newtons
This is the actual weight of the guitar itself, the force acting upon the joint is a function of the cosine of the angle from the vertical, or the sine of the angle from the horizontal. I'm going to take the angle from the vertical, 17 degrees as per the headstock angle
adjacent = cosine(17)
hypoteneuse
hypoteneuse*cosine(17) = adjacent
The adjacent is what we're looking for to find the force so
49.05 * 0.9563 = 46.9065 Newtons
So the force acting upon the headstock joint is only 46.91 Newtons
Funnily enough on an Epiphone with a 14 degree headstock angle (Norlins are like this too are they?) for a guitar of the same weight the force would be approximately 47.6 Newtons so it's better to hang a Gibson rather than the equivalent weight Epi.
Last edited by Shane; 01-04-2010 at 03:16 PM. Reason: Fixing units, acceleration has a squared in it
Shane is offline   Reply With Quote
Old 01-04-2010, 03:13 PM   #24
diceman
diceman's Avatar
I'd also like to point out that ALL of those sunburst guitars in the photo are real 58-60 Bursts (and Mary Ford's GT and a few other unique ones as well)... Dirk Ziff with his multi million dollar Burst collection and this Perry guy as his pro have probably looked in to this sort of thing. Again, see the above pic!
Old 01-04-2010, 03:24 PM   #25
Agave_Blue
Agave_Blue's Avatar
Originally Posted by Paul View Post
strad-who-varius?
STRAT O. Various.
He's the guy that invented all of these various strats:
FenderŪ Guitars
Originally Posted by Ben Franklin
Beer is proof that God loves us and want us to be happy.
Agave_Blue is offline   Reply With Quote
Old 01-04-2010, 03:27 PM   #26
Agave_Blue
Agave_Blue's Avatar
g = 9.81 ms^-2
What is the weight/force per unit area at the headstock/neck transition point. Isn't that the weak spot because of the truss rod cutout?
What is the effect of string tension?
Old 01-04-2010, 03:34 PM   #27
Shane
Shane's Avatar
I have an Epi so don't know that area unfortunately. Divide the force across the area and it can be gotten with accurate measurements of the divide.
I would think string tension is more of a torque force would it not be, trying to pull the headstock around from the tuning pegs? What gauge strings, what brand strings, what material strings and what tuning you have it in would have an effect (or affect, not entirely sure) on that I'd assume also
Old 01-04-2010, 03:34 PM   #28
tnvol
tnvol's Avatar
I dont think it hurts anything. I dont do it but I wouldnt not do it because I was afraid of hurting my guitars.
tnvol is offline   Reply With Quote
Old 01-04-2010, 03:50 PM   #29
GibsonByBirth
Innappropriate post
GibsonByBirth is offline   Reply With Quote
Old 01-04-2010, 04:10 PM   #30
Ferrarimk13
Ferrarimk13's Avatar
no.
if you want to baby your guitar even further, get one of these.
Mandolin Brothers uses these little mounts which are nailed into a wooden piece with one little angled nail, and then the leather strap is around the tuners (which i thought would be harmful) and is just hanged, all their guitars are like that, even the $75,000 1957 LPGT. Apparently it does no harm and works great.
Ferrarimk13 is offline   Reply With Quote
Forum Jump
