MyLesPaul.com
Go Back   MyLesPaul.com > Music Gear > Tonefreaks > Pickups
Thread Tools Display Modes
Old 02-13-2009, 04:03 PM   #1
SpinWheelz
SpinWheelz's Avatar
Replacing a soapbar P90 with a mini humbucker
If I understand correctly, a mini humbucker can slot into a pickup cavity of a soapbar P90. If so, how? Soapbar P90s don't use pickup rings and screw right into the body. Mini humbuckers do use pickup rings, so does one need to drill holes into the top to mount the pickup rings?
SpinWheelz is offline   Reply With Quote
Old 02-13-2009, 08:17 PM   #2
gmacdonnell
gmacdonnell's Avatar
Location: Somewhere on the East Coast, far from home...
Re: Replacing a soapbar P90 with a mini humbucker
A mini-humbucker or Firebird (they're different in sound and build, the Firebird's don't have screw-poles showing,) will fit into a P-90 rout, but only with the right pickup ring.
The story is that Gibson had a ton of left-over mini-humbuckers from Epiphone, (who they were moving to Asia,) and decided to use them up by installing them in Les Pauls. The LP's had been designed for P-90's, so Gibson simply cut the P-90 covers to make mini-humbucker rings.
These are the kind of rings you need (notice the rounded corners):
They're usually about $5-10 bucks for one or a set, like they are here:
(2) Cream Mini Humbucker Pickup Rings Les Paul Deluxe - eBay (item 350164886209 end time Feb-12-09 11:28:27 PST)
I love P-90's but Mini-HB's are a great tone too. Peronally, I think Lollar makes just about the best mini-huckers, (his P-90's are the best too, IMO.)
Gibson's newer mini's, I don't know what the exact specs are, but they're much more hot than vintage units, and lack a lot of the sparkle, clarity and chime that make them such a unique pickup.
BTW, another option are the several kinds of P-90-sized humbuckers available. Duncan, Dimzario and Lace all offer some great designs with their own sounds.
Lindy Fralin just launch his humbucking P-90, and i'm sure it will be another world-class pickup from him.
Good luck!
"In our culture we have such respect for musical instruments, they are like part of God."
- Ravi Shankar
“Sounds like the blues are composed of feeling, finesse, and fear.”
-Billy Gibbons
gmacdonnell is offline   Reply With Quote
Old 02-13-2009, 09:15 PM   #3
SpinWheelz
SpinWheelz's Avatar
Cheers, mate. Thanks for the explanation. I didn't realize there were soapbar-sized humbuckers out there.
With regards to mini humbuckers and their pickup rings, how would that would in the space of the soapbar P90? On the pickup rings you show, I only see the holes that would attach to the pickup itself. How would the entire pickup and pickup ring assembly mount onto the body?
Old 02-13-2009, 11:19 PM   #4
captain tightpants
Location: In the pit rubbing the lotion on it's skin. It doesn't like the hose.
A little hard to describe, but it's really a simple setup....
1. Screw goes thru the ring.
2. spacer of some type (cut-to-length chunk of a drinking straw works great) goes over screw, under ring.
3. Screw goes thru the pickups ears, but does not screw into the ears.
4. S small nut is threaded onto the screw until the pickup is snug against the spacer.
5. nut is soldered to the screw so it won't come loose
6. you now have a pickup/ring assembly, which in turn will screw into either an adapter plate (see pic below), which is attached at the bottom of the cavity, or into threaded inserts which are pressed into the bottom of the guitars pickup cavity.
Here's a picture of the plate I'm talking about, it works for both P-90's and minihumbuckers. The Mini would use the holes on the outside of the plate.
It is attached to the bottom of the P-90 so I wouldn't lose it here, but it actually screws into the cavity first, then the pickup screws in afterwards.
The ring is for looks alone
Old 02-14-2009, 08:12 AM   #5
SpinWheelz
SpinWheelz's Avatar
If I understand you correctly, the pickups are still mounted to the body? Regular humbuckers are typically mounted to the pickup rings and the pickup rings are mounted to the body. You're saying that with mini humbuckers, the pickup ears are secured to the body? Surely those holes don't line up with P90 holes 'cause P90s' mounting screws are in the middle of the pickup, not the ends of them. I think I'm still missing something here, sorry.
Old 02-14-2009, 09:07 AM   #6
EFK
EFK's Avatar
The special plastic mini ring is attached to the mini, NOT to the body. The whole assembly in turn slides right into a p90 cavity as if the whole mini assembly - ring included - were a p90. The adapter plater shown above attaches the whole mini assembly - ring and pickup - to the bottom of the cavity just like a p90. Does this clarify things? P90 and old-style minis (with the original-type 'floating' rings, I mean) are interchangeable in the same guitar.
EFK is offline   Reply With Quote
Old 02-14-2009, 05:30 PM   #7
gmacdonnell
That's the best answer, I hope that helps, Spinwheelz?
With the rings and the adaptor, or with a P-90 'bucker, you shouldn't need to drill any holes in your guitar, and you'll have a wide range of possible tones from classic rock, sweet blues and jazz, to clear and modern sounds.
- Ravi Shankar
-Billy Gibbons
Old 02-14-2009, 07:57 PM   #8
hillbilly
hillbilly's Avatar
I like the Epiphone mini-humbuckers...they use alnico magnets...
The Gibson Firebird ceramic pickups are so bright & harsh they can stun a wildebeast.
I think myself that we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious.
Thomas Jefferson
hillbilly is offline   Reply With Quote
Old 02-14-2009, 11:44 PM   #9
gmacdonnell
Yeah, I don't know what Gibson is thinking with those pickups. The originals are so good, but it's like they're trying to make the Firebird pickup into a Super Distortion. It just doesn't work.
Lollar and Fralin make incredible Firebird and Mini-humbucker pickups and P-90's. I'm really psyched about the new Fralin humbucking P-90's and will probably order a set later this year, (I love P-90's but the vintage ones are way too noisy in many clubs I play.)
Just curious, Spinwheelz, but what kind of tone are you looking to get, and what kind of guitar are you thinking about the pickup swap on?
There are a lot of great options out nowadays, from the relatively cheap, to custom wound handmade pickups.
Duncan makes some great stuff for bluesier rock. Dimarzio's P-90 sized humbuckers come in hot-rodded humbucker types, but also some very nice, more vintage sounding units.
The Lace P-90's sound like a really nice P-90, but without any hum or noise.
Their new Alumitones are actually really cool pickups: they're sort of a wide-frequency, high-output design, but are very clean and single-coil sounding, and are really quiet and versatile. They work great for everything from jazz, to blues to hi-gain rock.
Gibson's H-90's are nice but I haven't seen them outside of the limited edition guitars.
And like I said, Fralin and Lollar make some of the best stuff in the world (P-90 or mini-hb), but they cost a little bit more.
- Ravi Shankar
-Billy Gibbons
Old 02-15-2009, 12:27 AM   #10
captain tightpants
Look again at the pic. See the holes on the OUTSIDE of the plate? NOT the ones the P-90 is mounted to? The holes on the outside is what the mini's line up with.
Another pic of the plate
This...
screws to the plate.
Old 02-16-2009, 09:19 AM   #11
SpinWheelz
SpinWheelz's Avatar
Thanks for the explanation, fellas. That plates makes a ton of difference in helping me understanding it. Now I think I get it. Pickup and ring assembly is mounted to the plate and the plate it mounted to the body. That makes sense now.
gmacdonnell, I didn't have any particular tone in mind. I've been fishing around for another guitar to noodle around with, and I've come across quite a few P90-shod candidates. Problem is, I've already got two other guitars with P90s (one's packed with three of them!), so I wanted to see what my options might be. It maybe cool to try one with two mini humbuckers set out of phase with each other!
Old 02-16-2009, 10:15 AM   #12
gmacdonnell
mini-hums always go nicely with P-90's: a well-balanced diet for sure.
If you're a vintage-gear/tone guy, I think you should contact Lollar, or Fralin.
Both are real nice guys and will know exactly how to get it right the first time.
One alternative, is the up and comer Vintage Vibe pickups, made by Pete Biltoft. Pete custom winds just about every imaginable kind of pickup, and does some really interesting and great sounding things with the classic designs. (Charlie Christian pups that fit in P-90 or Humbucker slots, for example, which just got stellar reviews in UK's Guitar and Bass mag)
He makes mini-humbuckers, but also the P-90 sized humbuckers.
His website: Vintage Vibe Guitars: Humbucker Pickups
doesn't do full justice to his pickups: they're easily some of the best-made, highest-quality I've ever seen, (Jason Lollar agrees, btw!) And they sound terrific.
What the website doesn't really indicate, is that
you just call Pete up, explain your guitar, the pickup choice, and give a detailed description of the tone you're after, and he'll nail it
for a great price. An incredible set of custom-wound "semi-humbuckers" I got from him cost me $150, shipped.
He also can make easily exchangeable magnets, and gives you two sets. So you can choose between, say, Alnico II and V, or mix and match.
Definitely worth looking into.
- Ravi Shankar
-Billy Gibbons
Old 02-17-2009, 09:14 AM   #13
SpinWheelz
SpinWheelz's Avatar
Thank you so much for the leads, gmacdonnell. As and when a candidate for modding comes up, I'm gonna need to look into these options you've suggested. In the meantime, I need to find out where you're "working in NYC"!
Old 02-20-2009, 01:06 AM   #14
jason lollar
I am happy you guys like my minis but I am suprised more people havent seen this
its all in there if you can wade through 5 parts including mounting plates
there are at least three different mounting plates gibson used and I hjave drawings for all of them but usually I dont use them- its easier not to use a mounting plate as in parts 1 through 4!
jason lollar is offline   Reply With Quote
Old 02-20-2009, 01:19 AM   #15
captain tightpants
And there you have it! Thanks, Jason, i didn't know there were 3 different plates!
Oddly enough, my '77 Special above has the plates for the P-90's, while my '77 Deluxe uses the inserts pressed into the wood for the mini's, go figure!
Old 02-20-2009, 01:20 AM   #16
jason lollar
There are 4 other parts search on you tube Mini humbucker mounting
YouTube - mini humbucker mounting
I am trying to get up better videos than what is availible for the common items and to get up more odd stuff than anyone thinks about like mini buckers DOH!
Old 02-20-2009, 01:23 AM   #17
jason lollar
Damn you guys are fast! I was just writing that last thing while you already replied!
Old 02-20-2009, 01:28 AM   #18
captain tightpants
I literally just logged on and saw your post!
I like your way of using the wood screws with springs on the bottom rather than soldering the damned nut unto the machine screw, what a pain in the ass that can be!
Old 02-21-2009, 09:13 PM   #19
jcg
I have a Custom Shop 56 Les Paul and want to replace the P90s with a set of Lollar minis.
Has anyone had any luck getting hold of the mounting plates that Jason referenced? Is Parts is Parts still selling the plate pictured above? It's different than the plates that Gibson uses, from what I can tell. Has anyone had any luck with these?
I'd really rather not drill any holes into the guitar if I can help it.
Thanks.
jcg is offline   Reply With Quote
Old 02-21-2009, 10:44 PM   #20
gmacdonnell
Wow, Jason Lollar himself!
Love your pickups, Mr. Lollar. Many thanks for such great tone!
Hi Spinwheelz,
No problem with the help- just glad I could be of some assistance. I've got an apartment in the manhattan, but to be honest, lately i haven't spent too much time in the city. i've been on three short tours in the past few months and am recording in Macon whenever I get the chance. Just feel lucky to be busy in a time when so many are struggling.
- Ravi Shankar
-Billy Gibbons
Old 02-22-2009, 12:21 PM   #21
captain tightpants
Thanks.
Actually, Gibson did use these plates, too. I have no idea where they are available, tho. I can't find them on Parts is Parts anymore.
Old 02-23-2009, 09:30 AM   #22
jcg
Thanks anyway, Captain.
Old 02-23-2009, 10:35 AM   #23
jcg
For the record, Parts is Parts has no more of the above in stock, but a gentleman I spoke to there is going to try and get his hands on some. I'll let you know.
Old 02-26-2009, 01:01 PM   #24
rick13
WB winds a wicked mini-hum. I modified a spare set for use in my goldtop....fantastic.
Rick
rick13 is offline   Reply With Quote
Old 02-26-2009, 04:52 PM   #25
Grand Pappy
Grand Pappy's Avatar
I guess I'm lucky. My 76 LP Deluxe had P-90's installed when I aquired it, but was equipped w/ threaded insets in the bottom of the pup routs. I went the opposite and replaced the P-90's w/ S.D. mini's. The best of both worlds!
Grand Pappy is offline   Reply With Quote
Old 02-28-2009, 09:56 PM   #26
gmacdonnell
I haven't seen those plates around in awhile, but my repairman pal sent me this template. He says he'd made a few in his day, and many repairmen have as well.
http://terrydownsmusic.com/Archive/M...to%20scale.pdf
- Ravi Shankar
-Billy Gibbons
Old 03-01-2009, 08:59 PM   #27
Birdy
Birdy's Avatar
its all in there if you can wade through 5 parts including mounting platesYouTube - Installing mini humbuckers Part 1
Yo Jason. I bought some of your mini-hums a couple years ago to replace
the stockers in my 96 Firebird V. I gotta say, everyone that plays/hears it
just raves about them. I can't believe the difference they made !
Birdy is offline   Reply With Quote
Old 03-02-2009, 05:33 AM   #28
joek86
joek86's Avatar
If you were going from a P90 to a mini Hum,other than noise cancelling, what would you say the tone differences in general terms are?
~Joe
joek86 is offline   Reply With Quote
Old 04-21-2010, 03:41 PM   #29
Tonedog d' Bluescat
I have a Gibson PAF mini hummer as well as an early Firebird pup. For the last thirty some odd years I've planned to install them in a gutted Hagstrom III solid body, (my first electric). Since the mini runs hotter on the ohm meter I'll likely stick it at the bridge and wire it like a Les Paul. In your opinion what will be the difference in sounds between the two?
Any suggestions or ideas will be tolerated well on my part and even appreciated if I can bring myself to stop typing.
Tonedog d' Bluescat is offline   Reply With Quote
Forum Jump
