MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Epiphone Les Pauls
Thread Tools Display Modes
Old 01-19-2009, 02:47 AM   #1
HDuncan
Are Guitar Necks Built Straight, or Curved?
I am just curious if guitars are built with a straight neck, with which the truss rod is adjusted to allow curvature, or if the guitar neck is built with inherent curvature and the truss rod allows you to straighten it?
Me thinks that the neck comes curved and the truss rod allows it to be straightened, which is why tightening the truss rod (to make it straighter) seems to take more effort (because its working against the natural tendency of the guitar neck).
HDuncan is offline   Reply With Quote
Old 01-19-2009, 03:19 AM   #2
klohiq
klohiq's Avatar
Re: Are Guitar Necks Built Straight, or Curved?
My take on it is this:
The strings are what makes a neck curved. The neck and fret board are straight/flat when the guitar is made. Tightening the truss rod puts pressure against neck and helps to fight the natural tendency for the neck to bow due to the string tension.
'04 Epi LP Ebony Studio - JB / Kramer Quadrail
klohiq is offline   Reply With Quote
Old 01-19-2009, 03:20 AM   #3
Sinmastah
Epi Verification Expert
Sinmastah's Avatar
tightening is harder because you are working against string tension. Think about it. The strings naturually want to make the neck snap up, soif you are loosening it, the strings will helpp you loosen, and vice versa for the other way. Necks should be build straight, because fretboards are as well. It would be a lot more complex to make a curved neck IMO.
Epiphone Elitist SG Faded Cherry(Jonesey'd and WB'd)
Epiphone Elitist SG Faded Brown (EMG's)
Epiphone MIJ Les Paul Ebony LQ
Fender Mexi Oly White Strat
Squier Natural Vintage M Jazz bass
Peavey Classic 50
SG's FTW
Sinmastah is offline   Reply With Quote
Old 01-19-2009, 08:13 AM   #4
vladmaximus
vladmaximus's Avatar
its about..strings + tension...
hmmm...
set it as u desire...
I am VladMaximus,a musician from Malaysia...ROCK ON!!!
My Soundcloud audio works --> https://soundcloud.com/mijiero
follow my TWITTER --> mijiero666
Music Tools --->
- 1978 TOKAI REBORN LES PAUL
- GODIN ARTISAN ST6
- FENDER STRAT 50s CLASSIC 1993
https://soundcloud.com/mijiero/holy-diver-demo-by-mijiero
vladmaximus is offline   Reply With Quote
Old 01-20-2009, 12:32 AM   #5
HDuncan
So, when a luthier does a fret-dressing, do they take off the strings and loosen the truss rod so that the neck is totally flat?
Old 01-20-2009, 02:56 AM   #6
klohiq
klohiq's Avatar
yeah...there is actually a thread about that exact thing, it's a sticky in this forum
http://www.mylespaul.com/forums/epip...tom-setup.html
post #6 specifically...pretty cool stuff.
Old 01-20-2009, 10:45 AM   #7
Hedcrash
Hedcrash's Avatar
Actually, for a perfect fret job the luthier needs to dress and level the frets with the neck bowed into whatever position it's going to be in when the guitar is strung up and setup the way the player likes it. Think about it - Levelling frets on a perfectly straight neck won't address any problems that creep up when the neck relief (truss rod) is set correctly. Almost all guitar necks will have some relief in them to varying degrees, and "level" will change as the neck bows.
Stewart Macdonald even sells a jig for assisting with this:
Erlewine Neck Jig at Stewart-MacDonald
Hedcrash is offline   Reply With Quote
Old 01-20-2009, 03:58 PM   #8
HDuncan
But, if you level the frets when the neck is bowed, then your frets will be straight while the neck is bowed- so, the relief in the neck (that is supposed to help make way for the elliptical pattern of the strings) wouldn't do you any good.
My point is- wouldnt a bowed neck with frets leveled while it was bowed = the same thing as a straight neck with the frets levels while it was straight?
Heres an image of what i'm talking about:
Old 01-21-2009, 01:32 AM   #9
HDuncan
Maybe we could get Roman or other luthiers in here to answer this one!
Forum Jump
